EAGLE User Support (English) Eagle- How do I put a hole in my PCB?
  • Replies 24 replies
  • Subscribers 190 subscribers
  • Views 10400 views
stevemann
stevemann over 6 years ago
This is likely a silly question, but I am asking anyone with more Eagle PCB experience than I, which would be just about anyone, how do I put a hole for a 4-40 screw into my PCB?
I tried placing a hole using the command HOLE 0.125 *
But the PCB manufacturer bounced the order because the holes were only 0.003mm.
    autodeskguest over 6 years ago in reply to stevemann
    Stephen Mann wrote:
    Thanks, Lorenz.  I'll try hole 0.125 in on my next board.
    but without the blank between value and unit
    Lorenz
  • dukepro
    dukepro over 6 years ago in reply to dukepro
    On 1/15/20 15:56, Chuck Huber wrote:
    True, at least to an American.  I immediately recognized that "4-40"
    was a SAE screw size.
    Not "SAE".  Freidrich pointed out correctly that it's "UNC".
    Enjoy,
        - Chuck
    5102.att1.html.zip
  • dukepro
    dukepro over 6 years ago in reply to stevemann
    On 1/14/20 15:03, Stephen Mann wrote:
    So, yes, my question was quite precise, even if our Country's measurements aren't.
    True, at least to an American.  I immediately recognized that "4-40" was
    a SAE screw size.  However, one must also consider the audience.  In
    this case, it's pretty much world wide, with emphasis on Europe and
    North America.  I've seen posts from other countries, to be sure.
    The built-in help does not tell me that the unit is my grid units,
    Well, to be precise, the /default/ unit is whatever your grid units
    are.  Linear units assume the grid units unless specified otherwise.
    or that I can put the units in my hole command.
    Any command that accepts a linear dimension also accepts a unit.
    Furthermore, coordinates can be in mixed units:
    hole 0.125"   (1.0" 25.4mm);
    I'll leave it to you to find the hole.
    But, I really do appreciate the prompt suggestions.
    Glad to help out.
        - Chuck
    4213.att1.html.zip
  • omega-5
    omega-5 over 6 years ago in reply to stevemann
    Am 15.01.2020 um 15:55 schrieb Stephen Mann:
    Really?  The About page says Eagle by Autodesk, and to open Eagle, I log on to an Autodesk account.  Autodesk is based in San Rafael, California.
    Long, long time ago image
    https://en.wikipedia.org/wiki/EAGLE_(program)
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • omega-5
      wrote:
    That's a bit of a translation problem in the documentation (remember
    EAGLE is a German product).
    Markus
    But, growing up in this moronic Imperial system of inches and pounds, a 4-40 screw is remarkably normal and generally needs no further definition. To be honest, I still don't know how to describe an American Standard 4-40 screw any other way.  (In hindsight, I should have gotten my calipers and measured the hole size I want in proper units and this hole (sic) thread would be much shorter.
    https://www.element14.com/community/message/287184
    4-40 is not the full name for the screw thread.
    It should be UNC 4-40.
    The UNC thread (Unified Coarse Thread Series) is the American
    coarse thread. It has a flank angle of 60 ° and is measured in
    inches. ... The corresponding fine thread is known as a UNF
    thread (Unified National Fine Thread Series).
    Friedrich
  • stevemann
    stevemann over 6 years ago in reply to autodeskguest
    Markus
  • stevemann
    Don't worry if you don't find the answer in the "Help". The eagle
    community is always willing to help.
    Joern Paschedag
    That's the best answer of all.
    Am 14.01.2020 um 21:03 schrieb Stephen Mann:
    If the actual unit is "inch", the hole will have a diameter of 0.20 inch. "
    Until this thread, I did not know that the "actual unit" was the grid size.
    In the German version of the manual this sentence is
    'Falls die eingestellte Maßeinheit "Inch" ist, hat das Hole einen
    Durchmesser von 0.20 Zoll.'
    which I would translate to
    'If the unit is currently set to "inch", the hole will have a diameter
    of 0.20 inch.'
    In German there is a word "aktuell", which sounds similar to "actual",
    but most of the times translates to "current"/"currently" (false friend).
    HTH
    Markus
    OP here.
    Back in the 70's I was installing brain scanners in hospitals around the US. The company was all metric which I really learned to love. (Metric, not the company).
    While I would love to be all metric here, American 4-40 screws are a fraction of the price for 3mm screws.  In our common home improvement stores a package of ten 3mmx10mm machine screws cost as much as fifty #4-40 screws.  If I go to a hardware store, the differential is even larger.  I did buy some metric hardware online, but the shipping cost wiped out any savings. Worse, 3mm is the smallest they stock.
    In my eyes it was not. If  there is no description it is just a number
    of nothing (even if it is well known in a special job).
    A similar thing (in articles and forums i.e.) is the use of
    abbreviations without explaining what is meant.
    In some earlier days it said:"Massachusetts Institute of Technology"
    with the abbreviation (MIT) .
    During the article the abbreviation was used but everybody knew what was
    meant.
    Nowadays some just write the abbreviation alone  but check out for what
    MIT alone may stand also.
    Here are your own words:
    "Remember, what is obvious to you may be someone else's mystery".
    And in reply to the anonymous poster who said: "The built-in help is quite good on most of this, as is the PDF manual."
    There are no anonymous posters. The problem is the element14 interface
    with the newsreader. Appendages and other things  are not transmitted.
    Remember, what is obvious to you may be someone else's mystery.
    The built-in help does not tell me that the unit is my grid units, or that I can put the units in my hole command.
    The only example is ambiguous: "
    HOLE 0.20 •
    Until this thread, I did not know that the "actual unit" was the grid size. I am still learning.
    The PDF manual has a single line to explain the hole command: "Define a mounting hole (not plated-through).", but no examples that I could find.
    Steve
    https://www.element14.com/community/message/287201
    Joern Paschedag
  • stevemann
    stevemann over 6 years ago in reply to dukepro
    OP here.
    HOLE 0.20 •
    Steve
