EAGLE User Support (English) Swap level being ignored
  • Subscribers 178 subscribers
  • Views 573 views
Former Member over 15 years ago
I have a library components (dual FET, Si4834BDY) that has two electrically
halves, yet the pin names are the same and number of pins are same for the
two halves. One FET has a schottky diode in parallel in from S-D, and one
FET does not.
I choose to use swap level 1 for each half, even though they are internally
different. The external pinouts are mirrors of each other.
What is the problem in allowing me to swap the two halves, so long as there
are similar pin assignments?
My sugggestion is, unless there is some commanding reason why you cannot do
so, then HONOR a request for swap-level = 1, and swap two electrically
different device halves - so long as the pin-assignments are the same, even
if those halves use two different symbols!
    FET does not.
    you could make a single gate, each pair of pins swappable and then
    pinswap all 3 in turn, each pin having a different swap level...but then
    you are stuck with grouping the transistors together on the schematic.
    I agree with your suggestion, it's none of EAGLE's business if your
    gates don't match, at most a warning "Swapped gates are not equivalent"
    Former Member over 15 years ago in reply to Former Member
    "Gary Gofstein" <nospam@use.forum.net> wrote in message
    news:ib215s$m6v$1@cheetah.cadsoft.de...
    >> snip
    you could make a single gate, each pair of pins swappable and then pinswap
    all 3 in turn, each pin having a different swap level...but then you are
    I agree with your suggestion, it's none of EAGLE's business if your gates
    Gary, thanks for your suggestion, but "-ouch-".
    I got to thinking about this after I aired my beef... .
    It was a lost cause since before dinosaurs and beer.
    Minor annoyance. I fix.
    I was annoyed because I spent about 20 minutes trying to repair my library.
    It took me that long before I realized the problem was systemic. Maybe I got
    off easy.
    "Brett Holden" <bretth2o@bellsouth.net> wrote in message
    news:ibilb2$lf8$1@cheetah.cadsoft.de...
    >>> snip
    off easy.
    >>> snip
    >FET does not.
    since many years, my suggestion is to allow any swap on demand, IOW
    instead of the error message, there should be a dialog offering "swap
    anyway", maybe with some more information (see older postings, maybe
    in the German groups).
    And swaps should be possible from the board! Pinswaps are trivial,
    gateswap should highlight the pins belonging to the gate.
    Oliver
    >> FET does not.
    Oliver
    yeah, and pinswaps would be nicer if they would swap the pins on the
    schematic instead of the nets, especially if initiated in board view.
