EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 180 subscribers
  • Views 6136 views
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
    Former Member over 14 years ago in reply to Former Member +1
    Am 04.04.2011 21:58, schrieb Gary Gofstein: On 4/4/2011 7:00 AM, Olin Lathrop wrote: >> Klaus Schmidinger wrote on Mon, 04 April 2011 04:35 >>> Well, I'm sorry I got into contact with the GED before I…
    >> Well, I'm sorry I got into contact with the GED before I was
    >> "contaminated" with Windows,
    It's not a Windows thing.  The copy and cut convention was around well
    before that.
    Quote:
    >> To get this recurring discussion over with once and for all I suggest
    >> the following changes for version 6:
    The current problem is one of naming, not of how the commands actually
    work.  I think that changing anything now will cause too much pain to
    people that have managed to get used to how it works, and more importantly
    that have scripts and ULPs that rely on the existing names.
    The fix is therefore documentation, not changing code.  There should be a
    "Introduction to Eagle" section or something new users will find that
    explains the various unobvious things about Eagle.  CUT doing just a COPY
    should be prominently mentioned, and what COPY really does and when you'd
    use that over CUT also needs to be made clear.  That would have saved me a
    bunch of time back when I started.  (actually I'm still a little hazy about
    when to use COPY versus CUT, although I haven't spent the time to
    deliberately try and educate myself either)
    I think the problem is not the functionality of the commands, it's the
    misleading use of language to describe what they do. I agree that if
    copy is renamed to "duplicate", it is consistent with other software and
    obvious what it does. And cut then becomes copy, which would be
    misleading except that in all other software, copy has a consistent
    meaning of "place into paste buffer".
    These command names in English predate Windows by many, many years. I
    remember using a DEC CRT terminal (smart terminal) on a mainframe that
    had local editing capability with a cut/copy/paste buffer in the 1980's.
    Although "invoke" can be traced to the latin roots for "call in" ( which
    is exactly what it does), the word invoke, in american english, can not
    be used in this way. Changing the name to "Call Gates" or, even better,
    "More Gates" or "Add Gates" would be a good start for a workable name
    for this command. You could just leave the old "invoke" as well and not
    tell anybody about it.
    None of these changes have anything to do with experienced users, they
    just clarify things for new users. It seems rather unprofessional to
    have variances from accepted UI practice, /especially when it could be
    done without them/. So, some of EAGLE's odd use of mouse controls is
    much more acceptable, because it's not clear how it could be done with
    the established UI model. But misleading names = sloppy software in the
    new user's eyes.
    >> before that.
    >> Quote:
    >> importantly
    >> about
    new user's eyes.
    I think this should be discussed in a new thread since it has nothing to
    do with thermal pads.
    Joern Paschedag
    On Sun, 3 Apr 2011, Olin Lathrop wrote to us saying :
    However,
    >pretty universally when you see vertical text here it is written going
    >down, not up.  This applies to signs, the spines of books, and just about
    >everything else.  Vertical text going up looks stupid, at least here.
    Here in the UK that's not true. Sure, book spines are (usually) set to
    read down, but that's actually for a book-specific reason: if you lay
    the book down on a table with the front cover up, the text on the spine
    is right-reading. Vertical text on a page usually runs upward, because
    in the old days when it was a hand-written annotation a right-handed
    person will always find it easier to write upward.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    Former Member over 14 years ago in reply to kcadsoft
    Klaus Schmidinger wrote:
    >> It is pretty universally understood that CUT does a copy and delete.  This
    >> was well established before Eagle was written.  It is totally beyond me
    >> what Klaus and company were thinking when they named the copy command
    >> "cut".
    >The user interface of EAGLE was inspired by the "Valid GED", a graphical
    >editor I was working with during my time at Siemens. In that editor the
    Thanks for the insight. I always wondered where the naming comes from.
    Please don't change the behaviour of the commands this way. It would
    be a severe drawback!
    As others wrote, it's a naming problem - the main issue is that the
    current CUT command does "copy" to the buffer, not "cut".
    I'm not sure whether renaming of the commands is suitable (compromise
    "compatibility" vs. "new user friendliness"), and since I use Eagle
    for a long time, I'm not able to give an unbiased vote.
    If you ever think about changing the function, I strongly suggest to
    start threads in the relevant groups and get the opinions from a
    broader audience.
    We might consider the relationship between COPY and CUT, and the use
    of the left mouse button with CUT in this case.
    Oliver
    On Wed, 6 Apr 2011, Oliver Betz wrote to us saying :
    The command currently referred to as "cut" is the problem, but if
    renamed to "copy" then the existing command of that name causes trouble.
    The best "fix" would be to alias the cut command to something clear and
    unambiguous that doesn't clash with an existing command. But I can't
    think of anything suitable. The existing "copy" command could be called
    "clone" or something like that, since its functionality is akin to
    duplicating individual components, but that in itself doesn't help
    because it's the "cut" command that confuses people. I suppose "cut"
    could be renamed to "clone" but that would, at least to me, still feel
    to be the wrong way round.
    Sorry, I'm not helping am I.
    this message are    |
    Don't believe a     |
    word.               |
  • kcadsoft
    kcadsoft over 14 years ago in reply to Former Member
    On 04/01/11 14:58, Olin Lathrop wrote:
    Another annoying "feature" that is due to Eagle's origin is that vertical
    text reads up not down.  That is the german convention.  However, I am
    using the english language version, and judging from the number of
    downloads and the activity in this forum, the english language version is
    much more popular.  Is this ever going to get fixed?  It's been reported
    as a problem long ago.  At the very least there should be a setting for
    default vertical text direction.
    I'm currently looking into this and would appreciate your advice on the
    exact details.
    The "German" convention is to have texts be readable from bottom
    or right, as shown in the attached image. So any text with an angle
    of '90 < angle <= 270' is drawn "upside down".
    I understand that the texts "ABC R90" and "ABC R270" would have to
    be drawn upside down in the American convention, but what's with
    the other texts? Can you give me an expression like the above one,
    which takes the angle and calculates whether or not to modify
    the orientation?
    Or can you point me to a web page that explains the American convention
    for text orientations?
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
  • kcadsoft
    kcadsoft over 14 years ago in reply to kcadsoft
    exact details.
    the orientation?
    Answering to myself: I guess the only two texts that need to
    be modified are those with rotation R90 and R270. All others will
    be left as is.
    The attached images show how this will look. Note that the pad names
    of vertical pins will be drawn on the opposite side of the pin wire,
    so that when looking at a pin the text is always "above" the pin wire.
    Klaus Schmidinger
    Klaus Schmidinger wrote on Wed, 21 September 2011 10:06
    The attached images show how this will look. Note that the pad names of
    vertical pins will be drawn on the opposite side of the pin wire, so that
    One way or another, vertically oriented text needs to read down, not up.
    If you look at a bookshelf here in the US, the titles on the bindings all
    read down, for example.
    What to do about text that is not exactly vertical or horizontal is a gray
    area that I think doesn't have a single right answer.  The example in your
    first picture is probably as good as any.  Your second picture is right
    on.
    Perhaps this whole thing is a problem only because of two unfortunate
    design choices:  Eagle wants to "fix" something it maybe shouldn't be
    messing with at all, and it doesn't have general text anchoring
    capability.
    Most systems that have to deal with graphical text allow at least the
    choice of the 9 common anchor positions.  The text string extent is
    considered a rectangle which can be anchored at any of the 4 corners, the
    centers of the 4 edges, or the middle.  With a system like that there is
    little need to automatically flip text orientation - in fact it's better to
    leave it alone and let the user do what he wants.
    To use a Eagle example, suppose I'm making the symbol for a horizontal
    resistor.  I want to have the part designator above the symbol and the
    value below, but each centered horizontally.  There is no way to do that in
    Eagle now.  You have to guess how wide each string is going to be and move
    it around so that it will be centered for the nominal width.  Short strings
    will end up a little to the left and long strings to the right.  What I
    really want to do is anchor the top string to its lower middle point and
    the bottom string to its top middle point.  Fortunately for a resistor
    there is usually enough room and a little misalignment can be ignored.
    However, that was just to illustrate the point.
    If Eagle doesn't automatically try to "fix" text orientation, this issue
    wouldn't be a problem.  I guess that's like saying the spin flag should
    always be on.  After laying out and routing a board, you always expect to
    clean up the silkscreen and move text around to where it will be visible
    and meaningful.  The text starts out a mess, but that's expected.  Having
    that also be upside down makes it no worse.  As you're moving the strings
    around with the mouse, a simple right click rotates it another 90 degrees
    left.  If it reads up and I want it reading down, two quick mouse clicks
    fix that.  The extra mouse clicks are irrelevant since it's a lot less than
    moving the text to a decent spot to begin with.  The problem is when Eagle
    decides to fix it and never allow the preferred vertical orientation
    without having to turn on the spin flag.  That is a bid deal since it's
    outside the simple workflow of moving the text around with the mouse.
    So I think a better answer is to get rid of the spin flag altogether, give
    us at least the 9 basic text anchor points, and never have Eagle think it
    knows anything about what direction text should be other than how the user
    set it.
    Of course I'd have to actually try that to know for sure image
    Would it make sense to keep your circle of labels independant on view
    rotation? If so, both are wrong, and you would need a flag to set
    direction.
  • kcadsoft
    On 21.09.2011 18:53, Olin Lathrop wrote:
    give us at least the 9 basic text anchor points
    This will be possible in version 6.
    Klaus Schmidinger
