EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 180 subscribers
  • Views 6140 views
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
    Former Member over 14 years ago in reply to Former Member +1
    Am 04.04.2011 21:58, schrieb Gary Gofstein: On 4/4/2011 7:00 AM, Olin Lathrop wrote: >> Klaus Schmidinger wrote on Mon, 04 April 2011 04:35 >>> Well, I'm sorry I got into contact with the GED before I…
    On Wed, 21 Sep 2011, Olin Lathrop wrote to us saying :
    >One way or another, vertically oriented text needs to read down, not up.
    >If you look at a bookshelf here in the US, the titles on the bindings all
    >read down, for example.
    A bookshelf is a very poor model to use as referent. Book spines have
    the text that way round purely to be right-reading when placed on a
    table face-up. For annotations in margins (which is MUCH closer to the
    model we're looking for) the natural thing for a right-handed person is
    to write upwards, not down.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    up. If you look at a bookshelf here in the US, the titles on the
    bindings all read down, for example.
    I have watched with interest Olin's request for down reading verticle text.
    Living in New Zealand, a country with British roots, it maybe understandable
    that up reading text is normal. Due to our geograhic location and import /
    export habits we are equally exposed to the standards of the US and so
    become 'aware' of the many differences. That said, I have never come across
    down reading text on a document  or plan.
    So I searched some US companies for product pdfs to see if I could observe
    this down reading text and found none that qualify as Olin describes for a
    page that is to be read without rotating it.
    I've read a lot of datasheets and all graphs have the Y-axis reading up.
    The only time there was down reading  text, as the page was arrived at, was
    a page that had been rotated landscape to portrate clockwise. This is not
    normal if the documant is never expected to be bound into a book but happens
    when this page would be the left page of an open book
    Can soemone, a US resident I suspect, post some document links that show
    down reading text is a common convention somewhere.
    Warren
    news.cadsoft.de
    Robert Pearce wrote on Fri, 23 September 2011 12:55
    It was merely a example.  How is the text on the spine of german books
    oriented?  The only german book I could find right here where I am now has
    a wide enough spine that the text is horizontal, so no help.
    In any case, the point is that Eagle shouldn't be assuming a particular
    convention and let the user more easily rotate text as he likes.
  • kcadsoft
    kcadsoft over 14 years ago in reply to Former Member
    oriented?
    German books usually have the text reading upwards.
    Imagine a symbol with two pins, one extending to the right
    and one to the left (i.e. rotated by 180 degrees). Would you
    really want the pin and pad names of the left pin be written
    upside down?
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
  • kcadsoft
    That's a good point, Warren.
    So before we continue this thread, I'd like Olin to come
    forward with a concrete example of a diagram, data sheet
    or whatever (preferably, of course, a schematic diagram)
    that has vertical text reading downwards (or "from the left
    side"). Maybe I was a little too hasty spending all the
    time and effort in implementing this feature, while in
    real life nobody actually uses it...
    Klaus Schmidinger
    Former Member over 14 years ago in reply to kcadsoft
    Klaus Schmidinger wrote on Sat, 24 September 2011 04:59
    That's what I thought but wasn't sure.  Here in the US the spine of books
    when in a bookcase read down.  This means there definitely are different
    regional conventions.
    Again, the books are only one indication of the general preference.  The Y
    axis label is a special case because the Y axis "flows" upwards and the
    text is just going along with that.  Other than in such cases, upwards
    vertical text just looks strange or wrong.
    upside down?
    No I wouldn't, but this particular case is a lot easier because there are
    only 4 possible pin orientations so it's easy to say up front what the text
    orientation for each case should be.  In the two vertical cases I want the
    text reading down, not up as now.  This should probably be based on a
    global vertical text orientation switch.
    What I was thinking about more was arbitrary graphical text created with
    the TEXT command, like in the silkscreen layer coming from package
    definitions.  Those end up in arbitrary locations and orientations anyway,
    so I don't care how Eagle originally writes them as long as it's easy for
    me to move around and reorient.  Note that easy doesn't include having to
    set the spin flag.
    >> books oriented?
    Book titling is irrelevant but the following from Wikipedia  completes our
    education.
    QUOTE
    Spine titling.......
    ......Early books did not have titles on their spines; rather they were
    shelved flat with their spines inward, and titles written with ink along
    their fore edges. Modern books display their titles on their spines.
    In languages with Chinese-influenced writing systems, the title is written
    top-to-bottom, as is the language in general. In languages written
    horizontally, conventions differ about the direction in which the title on
    the spine is rotated:
    • In the United States, the Commonwealth and in Scandinavia, titles are
    usually written top-to-bottom on the spine. This means that when the book is
    placed on a table with the front cover upwards, the title is correctly
    oriented left-to-right on the spine. This practice is reflected in the
    industry standards ANSI/NISO Z39.41[22] and ISO 6357.[23]
    • In most of continental Europe, titles are conventionally printed
    bottom-to-top on the spine so, when the books are placed vertically on
    shelves, the title can be read by tilting the head to the left.[24]
    END QUOTE
    Latin America publications are not mentioned  but a quick search reveals
    they mainly follow Europe.
    Warren
    news.cadsoft.de
    Am 23.09.2011 23:13, schrieb Warren Brayshaw:
    In my office and our institute's library, we have several hundreds of
    English books, mainly from American publishers. Of this awful number of
    books, not more than about a handful have their titles printed upwards.
    Therefore, downward printing seems to be QUITE common in the US.
    Even quite OLD German books have their title pointing downwards, and
    only the 'younger' ones (from the 70s and later) seem to have adopted
    upwards printing. I myself prefer upwards, of course, because I only
    learned reading in the 70s (yes, of the LAST century, and NOT the one
    before that)...
    Andreas Weidner
    >> show down reading text is a common convention somewhere.
    of books, not more than about a handful have their titles printed
    upwards. Therefore, downward printing seems to be QUITE common in the
    US.
    before that)...
    Andreas Weidner
    The request is for documentation and CAD drawings practices  and not the
    spines of books, which has derailed the discussion. Interesting though.
    Warren
    news.cadsoft.de
    warrenbrayshaw wrote on Mon, 26 September 2011 16:48
    the spines of books,
    As I said before, down-reading vertical text is a strong convention here.
    The book spines are merely a way to illustrate this and point out that
    there really is a difference.
    You're not going to find a standard document, but the fact that's how it's
    done here should be good enough.  I don't know what fraction of Eagle users
    are in the US, but that's got to be a significant number.
