EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 181 subscribers
  • Views 6384 views
Former Member over 15 years ago
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
    Former Member over 14 years ago in reply to Former Member +1
    Am 04.04.2011 21:58, schrieb Gary Gofstein: On 4/4/2011 7:00 AM, Olin Lathrop wrote: >> Klaus Schmidinger wrote on Mon, 04 April 2011 04:35 >>> Well, I'm sorry I got into contact with the GED before I…
    Olin Lathrop wrote:
    warrenbrayshaw wrote on Mon, 26 September 2011 16:48
    >> The request is for documentation and CAD drawings practices  and not
    >> the spines of books,
    As I said before, down-reading vertical text is a strong convention
    here. The book spines are merely a way to illustrate this and point
    out that there really is a difference.
    You're not going to find a standard document, but the fact that's how
    it's done here should be good enough.  I don't know what fraction of
    Eagle users are in the US, but that's got to be a significant number.
    I too would have guessed there were a large number US resident Eagle users
    but alas not one has responded to confirm your assertions.
    I was only curious. I went looking for an example and found none. I was not
    asking for a standard document, just a link to a document or attachment that
    provides anecdotal evidence that the convention exists beyond individuals
    choosing to use that practice. You are requesting the feature and have not
    in the interrum provided examples.
    To me it seems that Cadsoft would be justified in not catering for it as the
    business case has not been made.
    Warren
    news.cadsoft.de
    warrenbrayshaw wrote on Mon, 26 September 2011 18:20
    users
    I don't think many people watch these forums, particularly in the US where
    they are not well known.  Haven't you noticed that particularly the NNTP
    users are disproportionately European?  Also note that nobody from the US
    has disagreed with me either.  Most people don't want to use NNTP,
    Element14 is widely disliked, and few people know about Eagle Central.
    I can tell you that I've mentioned this to others and have pointed people
    to my TEXTFLIP ULP that tries to fix vertical text after the fact.
  • kcadsoft
    kcadsoft over 14 years ago in reply to Former Member
    >> users
    And I am still waiting for you to provide a
    concrete example of a diagram, data sheet
    or whatever (preferably, of course, a schematic diagram)
    that has vertical text reading downwards (or "from the left
    side"). Since this is, according to you, what everybody
    does in the US, it shouldn't be hard to come up with something.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    Former Member over 14 years ago in reply to kcadsoft
    >>> users
    >> where
    Klaus Schmidinger
    I (in the US)  Like NNTP. Clear Concise, no frills and searchable.
  • justinhotban
    justinhotban over 9 years ago
    I think you should use SinoGuide TCP110U thermal pad for test, one side with fiberglass reinforcement;  TCP110U has a 1.1 W/mK thermal conductivity for exceptionally low thermal resistance. Naturally tacky on one side for easy assembly,  A special resin material that is easy to pull from the liner and place in the application enhances handling.
