    • Avnet Boards Community
EAGLE User Support (English) "Flip View" button
  • Replies 38 replies
  • Subscribers 175 subscribers
  • Views 4415 views
"Flip View" button
When routing the back of a board, it would be really nice to be able to
flip the view to see the back of the board as it really is.
It would be extremely useful when debugging a board, as it's really painful
to find a signal in eagle, then mentally flip it to find it on the physical
board.
It would also be useful for checking text layout on the back of the board.
Mentally flipping text is a bit of a pain, and almost impossible when
you're trying to evaluate its aesthetic appeal. Yes, I do consider
aesthetics important in PCB design!
I know I can print out the board mirrored, or group-then-mirror, and
various other hacks, but if this button existed, I'd click it every minute
or so when routing a complex design.
In fact, I'd prefer the board view to immediately mirror when I changed
routing layer to add a via! Other people probably wouldn't, so this would
have to be an option that defaulted to "off".
I've been using eagle for ten years, always wanting this feature, but only
just realised there was a suggestions forum!
gEDA, Orcad, Altium Designer, and probably others support this so I can't
be alone in desiring this feature! (see
http://wiki.altium.com/display/ADOH/AltiumDesignerViewer-ViewingPCBDocuments#AltiumDesignerViewer-ViewingPCBDocuments-FlippingtheBoard
for example)
    Aargh!
    I'm currently populating and testing a board, looking at my eagle layout.
    I've just spent half an hour debugging my power supply.
    I've soldered a capacitor across the wrong two pads because I was looking
    at the bottom side and failed to mirror it in my brain!
    And before someone tells me to print out my layout before assembling it:
    1) many of the boards I make are too dense for unambiguous silkscreen
    labels
    2) It's 2011. I don't own a printer.
    3) Paper is not CAD. I can't say "show c1 c6 c39" to see all of the places
    where I should be mounting a 100nF cap.
    So I can add another reason to my original post - useful for assembling
    boards.
    Former Member over 14 years ago in reply to kcadsoft
    Klaus Schmidinger wrote on Tue, 01 March 2011 03:20
    Do you have any particular idea on how this could be made "very clear"?
    I guess any small icon indicating this will be overlooked, and a thick
    "yellow/black" border around the draw window indicating "Caution - you're
    in flip mode!" will be overkill...
    Yes, and annoying.
    Whatever you do, make sure it can be easily disabled.  I don't want yet
    another indicator cluttering up my screen or using up more precious
    pixels.
    While I think being able to flip the view (mirror left/right) would be
    quite useful (I'm looking forward to making a hot key for that command), I
    really don't see a problem with it causing confusion.  If there is any
    text, it will be immediately obvious.  Even if not, when you're working on
    a board you'll know it well enough to easily recognize whether you're
    looking from the top or the bottom.  There is no problem to solve unless
    you create one by adding nanny-ware.  Sometimes doing less is more.
    Former Member over 14 years ago in reply to Former Member
    Silviu Epure wrote on Tue, 01 March 2011 04:28
    What about if you colorize with yellow (for example) the background
    EXCEPT the board?
    Yucc.  Please, no!  That would be very annoying.
    Boards have two sides, sometimes with components on each.  It isn't any
    more right or wrong to view the board from the top than the bottom when
    you're doing placement and routing.  That's just a convenience choice that
    should be changeable easily without penalty.  I plan on setting up a hot
    key for it.  It would really piss me off if each time I toggle to bottom
    view I have to dismiss some warning or put up with a obnoxious background.
    Cadsoft: This brings up one point though.  A natural way to use this new
    command is to set up a hot key to toggle the top/bottom view state.  Every
    time you hit the button it switches to the other orientation.  That means
    it would be useful for the native command to toggle the state, not just
    explicitly set it to top or bottom view mode.  Otherwise I'd have to write
    a ULP that gets the current state, flips it, writes a script with the new
    state, then runs the script.  That's doable, but I can't imagine it would
    be much trouble to allow the command toggle the state natively if this is
    considered from the start.
    Does it really matter if it's clear or not? People may want to draw the
    board from bottom instead from top and should be allowed to.
    Agreed! Let's just get it implemented as cleanly, minimally and, above all,
    as quickly as possible!
    When it's released and 90% of Eagle's user base is breathing a collective
    sigh of relief, the other 10% can submit new suggestions of ways to
    "improve" the appearance, behaviour and "user friendliness" of our simple,
    humble Flip Board button.
    Olin wrote on Tue, 01 March 2011 14:23
    EXCEPT the board?
    Olin, I'm not sure this is such a bad idea.  Now maybe not yellow
    background (maybe dark grey), but it would be good to have some sort of
    visual clue as to what orientation you are currently looking at.  And I
    rarely have text visible during intense routing sessions, so just looking
    at text isn't enough for me.
    I've used Altium which have this as a nice feature and it can be a bit
    disorienting.  So having some way to give yourself a mental framework would
    be helpful I think.
    that should be changeable easily without penalty.  I plan on setting up a
    hot key for it.  It would really piss me off if each time I toggle to
    bottom view I have to dismiss some warning or put up with a obnoxious
    background.
    A normal background and flipped background colour would serve both of us.
    I could set the flipped background to grey and you could set it to black.
    Viola, we both get what we want image
    new command is to set up a hot key to toggle the top/bottom view state.
    Every time you hit the button it switches to the other orientation.  That
    means it would be useful for the native command to toggle the state, not
    just explicitly set it to top or bottom view mode.  Otherwise I'd have to
    write a ULP that gets the current state, flips it, writes a script with
    the new state, then runs the script.  That's doable, but I can't imagine
    it would be much trouble to allow the command toggle the state natively
    if this is considered from the start.
    Good point Olin.  All commands should be like that, including turning
    layers on and off.  I have ULP to do just that but the layer command should
    toggle directly.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:ikjj4p$llv$1@cheetah.cadsoft.de...
    What's wrong with making your own indicator? Put the text "TOP" on your top
    copper layer where you got some space free.
    I agree with Olin that anything else than a normal view would be annoying.
    Maybe a middle way using an alternative palette in rear view would work for
    you?
    Klaus Schmidinger
    Klaus,
    First, please let me add my enthusiastic support for this idea.
    Second, here is my suggestion for what to do when you display the mirror
    image of the board:
    Nothing.
    I know my board designs. I know when I am looking at the front and when
    I am looking the back. A good tool stays out of the designer's way.
    Andrew Sterian
    Senior Designer
    Emsyde Design LLC
    "Andreas Weidner" <andreas.weidner@aei.mpg.de> wrote in message
    news:ikijgh$773$1@cheetah.cadsoft.de...
    In a drill program of my own invention, I use the attached pictures
    (plus others) to indicate the current view:
    Andreas Weidner
    Indeed, this is the widest used solution, and I tend to agree with the idea
    of replacing the crosshair in the origin with something like in the attached
    image. Mirroring the board will change the X arrow to the other direction.
    Silviu Epure
    "Dunarea de Jos" University of Galati, Romania
    http://www.etc.ugal.ro/sepure
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#`!(,#A ."Q(0#Q 4$Q(5&RT=&QD9
    M&S<H*B$M0CI%1$ Z/SY(46A82$UB3CX_6GM<8FMO='9T1E> B7]QB&AR='#_
    MVP!#`1,4%!L8&S4='35P2S]+<'!P<'!P<'!P<'!P<'!P<'!P<'!P<'!P<'!P
    M<'!P<'!P<'!P<'!P<'!P<'!P<'!P<'#_P `1" $U`4X#`2(``A$!`Q$!_\0`
    M&P`!`0`"`P$```````````````4#!@$"! ?_Q `Z$ $``0,!! 8(! 8"`P``
    M`````0(#$00%$B$Q,T%A<I'1!A,5(C)14G%3@;'!%$)SLN'PH?$V8H+_Q `:
    M`0$``P$!`0```````````````0(#! 4&_\0`*!$!``(!`P,#! ,!````````
    M``$"$0,$,10A,A(S82)!8J$345)Q_]H`# ,!``(1`Q$`/P#1@ ``````)C',
    M`````````````````````````````````````````"0GL ``````````````
    M````````````````````````<Q$S,1$9F>40X&3I?ZG]W?U_.%HC/:.6.8
    MQS<XG&<</FYHIWLS,XICG)75O8B(Q3'*`QVS+J E4 ``````````````````
    M`<XG=BK$XF<1+@````````````````!EU%4S73$SPW:9_.8C,L3O=JBNJ)CZ
    M8CPB(=$1POJ3F\R )4 `````````````````````````````````````)C',
    M9+MFNU%$U1PJC,>7W8Q,Q,3B0 0`````````````````````````````````
    M```,VEMLNQF/=IXRPJ6EMKM1F/>JXRI>V(=.UTOY-3OQ#/>L?Q&@KBFGW[
    M<[U/;\X_WL1FSZ28]7,1B)CY0A;1T\Z?551CW:N-*NG/;#7>4^KUP\H#5P@`
    M``````````````````````````````````,NGIIJNQOS$4QQG,\UFJXS3,
    M51V<4A1V;T-7WG]F6K7[O0V6KB?1A[M-7%%R)GA$QB9ETVK_``]_33,7K7K+
    M?&(WHSVPZS\$)%[IJ^]*NGWEMO)]-<_VZ -WD@``````````````````````
    M`````````````"CLWHJN]Y)RALWHI[W[,]3Q=>S]UZI^!(O=-7WI5_Y/S2+W
    M35]Z5-ET[_QAT ;O ```````````````````````````````````%#9O13
    MWOV3U#9O13WOV9ZGBZ]G[KU8]R4B]TU?>E8GX9Z/>Z:OO2II<NG?,.@#=Y
    M8 ```````````````````````````````````H;.Z*>]Y)ZAL[HI[WDSU/%U
    M[W7J^I(O=-7WI5_J2W35]Z5-ET[_QAT ;O `````````````````````
    M``````````````%#9W13WO)/4-G=#5V5>3/4\77LO=>N8^)'O=-7WI6)GAGY
    MH][IJ^]*FERZ=_XPZ -WE@```````````````````````````````````"CL
    MWHJN]Y)RCLWHI[W[,]3Q=>S]UZ9^"$B]TU?>E7GX$B]TU?>E32Y=._\`&/\`
    MKH W>6 ```````````````````````````````````*&S>BGO?LGJ&S>BGO?
    MLSU/%U[/W7J_D_-(O=-7WI5_Y9Z1>Z:OO2II<NG?,.@#=Y8 ``````````
    M```````````````````````YHIJKKBBBF:JJIQ$1&9F2BFJNN***9JJJG$1$
    M9F9?0M@[&M;L9JQ7J:X]^Y\NR.S]?TY]QNZ-<SRF(RA;-]$KUS%>T+GJ:?
    MPZ)B:NOKY1U?/\FP:38>SM+%.Y8WICKKJFK,XQF8Y?\`"D/%U-SJZG,M:_3P
    M\EW9NBNT[M6FMQ&<^[&[/_"/M#T2TU[?N:2[79N3.8IJG>HY<OG''KX_9L8I
    M37U*3FLIM:;1B9?,MH[.U6SKT6]5;W<YW:HG,51V3_LO(^J:FQ:U5BNS?HBN
    MW7&*J9?.]N;,KV7KJK7O39JXVJZOYH\XY?\`;V-KNXUOIMVEE,83P':J````
    M````````````````````````````V7T*T,7=9=UE<3BQ&[1PX35//CV1U=K<
    MT;T1M4V]@6:J8Q-RJJJKCSG,Q^D0LOGMW>;ZT_'9I' #%J+]&GM[]S.,XB(C
    MFYXC/:%XB;3B&4>+2[1HOW=RJGU<S\/'.7M3:LUG$K7T[:<XM F^D.AC7;(O
    M48F;EN/66\1F=Z(Y8[8S'YJ04M-+1:/LS?)QL6IV'I:=5=IHF[33%<Q$15'"
    M,_9C]BZ?Z[OC'D^@C<TF'#.ZTXG""WL33_7=\8\CVI_P`2[XQY)ZBAU6F@
    MB][%T_XEWQCR<>Q=/]=WQCR1U%$=7IH0O>Q=/]=WQCR/8NG^N[XQY'44.KTT
    M$7O8NG^N[XQY'L73_7=\8\CJ*)ZO301>]BZ?Z[OC'D>Q=/\`B7?&/)/44.JT
    MT%ZM%HJM93<WXIJHQB)Y3G_`5/8NG_`!+OC'D]NS=!;TOK/5U53O8SO8GY
    MJVUXF,5Y4ON:S&<M8OV+NGJW;M$TSU9Y3^;&W6YIJZ)IKBFJF><51P1]9L
    M.F<U::K=[)G,>/\`VFNO_I:FYCB\80AEOZ>[IZMV];FB>K/*?S8F\3$]X=,3
    M$QF',1,S$1&9GE$.!DZ7^I_=_G]?OS$SAC<XG&<</F[44QC>JX4QXSV0XKJF
    MJ<SPB.$1'* RZ@)2``````````A>BG_`(]I?_O^59JWH/JZ)LZC1SPKBKU
    ML=L<(GPQ'BVE\YN:S75M$_VUC@>7:5BN_IXIMQ$U15$XR]0QK/IG,TO-1:
    M/LBZ'17JK]%=5,T4T59S5&,X[%MP7O-YS*^MK6U9SD</+M/51H=G7]3,Q$
    MVZ)FG,3,35RB.';A6M9M.(8HNKJC^+O?U*OU8=Z&HCW(VF(Y>9.SS.?4V[>@
    MWH:B)Z7Y1T7Y?IMV\YWNUJ =\G1?E^FW[W:;T?-J =\G1?E^FWS5'S<;T-
    M1#I?DZ+\OTV[>@WH:B'2_)T7Y?IMV]#M17,9Q./LT]0V7J:--1>FNJ(SNX[>
    M:MMM-8S$JWVDUC,3E?JN8XS/BQ7-H6[%N)JN1$=4<YE#U.TKEW,4>[3\YYO%
    M,S5.9F9GYRM3;SS:4Z>TGFTJFMVS7?IFBW;HBB><UTQ5,_ER2NK .JM8K&(=
    MU12,01P=Z8QO5<8\9[(=8QF,\8Z\.:ZIJG,\(CA$1RA9R[U3Z^?_`'ZH
    M?\`G]?OSQ=6!WKJBNF)G._F=Z?G\I_,Q@B,.D<`$I)XG5@`(X``3Q.K ``
    M```SZ57=%J[>ILS$7<YC,9B>J8\'TG0:VQM#2TZC3U;U%7..NF?E/:^7O9
    MLS:>IV9?F[IJH]Z,545<::OO#CW6V_FC,<PM$X?3!'V=Z1Z#64>_=C37(C,T
    MW9B(ZN4\IY_?L6.;Q+Z=J3BT87 >76;1T>BB9U.HMVYB,[N<U3&<<(CC*L5F
    MTX@>IHWI7M>G77Z=IZXJT]J<S5$?%7QXQ/RCSY\#;?I=UU%>GTM,V=/5&)
    MF?CJ<3QX1_O7A >OM-I-)]=5)D`>DJ````````````````````````````
    M``````,MC4ZC3Y]1?NVM[GN5S3GP8A$Q$]I'HNZ[67[<V[VKOW*)YTUW)F)_
    M)YP(B(X`!( `````````````````````````````````````````````````
    M````````````````````````````````````````````````````````````
    %````_]D`
    end
    On 02/28/11 22:29, Gary Gofstein wrote:
    >> the only thing I would add is that it should be very clear that you
    >> are in flipped view, not requiring checking coordinates direction,
    >> pushing buttons, issuing commands. this should go without saying,
    >> but just to be sure, I'm saying it!
    clear"? I guess any small icon indicating this will be overlooked,
    and a thick "yellow/black" border around the draw window indicating
    "Caution - you're in flip mode!" will be overkill...
    Klaus Schmidinger
    Many replies so far but I feel many of the ideas do not address all use
    scenarios
    The TEXT on your design idea would not be workable. When you zoom, any
    TOP/BOTTOM text on the board would likely be outside of the current view.
    Changing the background color would definitely play havoc with  your color
    perception and may introduce colour mixing problems.i.e. when a via color is
    set to the background color
    A technique used in may applications is to toggle the look of an icon. Care
    is need here with placement and 'alerting' contrast if this is to work well.
    That  icon can often be outside your peripheral vision when included on the
    other toolbars. With a window reduced in size, the icon/button may be in the
    drop down extensions of the toolbar and not be visable at all.
    That said, the icon that toggles the view should toggle its face.
    The XY icon
    Added to the design area, be it solid or semi transparent, with a dense
    design it is likely the icon would be lost in the view. Many would not like
    this additional clutter in the design area.
    The icon would need to be positioned  so it remains in position relative to
    the window as you change zoom.
    Alternatively it could be positionalble by the user (floating toolbar style
    which permits it to be moved off the design area) and  transparency
    adjustable. Even the design being user definable using a user specified
    graphic.
    It should only be visable for the alternate view thus improving its alerting
    value.
    Outlining the design area
    You could add a boarder of 1 to 3 pixels to board design view. The colour
    would have to be customisable to cater for the vaious chosen backgrounds.
    This technique steals these few pixels from the design area.
    I can see the alerting effect being diminished in some density/zoom/color
    situations
    My preference is to have the indication just outside of the design area.
    Here are two ideas.
    1) Change the colour of the scroll  bars and their background. Workable but
    no way of quickly understanding why they changed colour
    2) Change the background colour of the STATUS bar. The status bar is usually
    alway visible and in the attension grabbing position below you sight line.
    Words should alo be added to indicate that the BOTTOM view is actrive.  A
    simple XY graphic could also be added. indicating X increases to the left.
    The colour, words and icon should not be lost when  ULPs use the status
    command.
    I favour this last option.
    Warren
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:ikmc0n$332$1@cheetah.cadsoft.de...
    usually
    command.
    What about an XY picture linked to the lower-left corner of the drawing
    area? (lower-right in the "view from bottom" situation)?
    It is highly visible, it is always there, it doesn't stay over the board
    unless high zoom is applied (and in this case zoom was activated to see
    something in the middle of the screen, not on the corner image )
    Silviu Epure
