EAGLE User Support (English) "Flip View" button
  • Replies 38 replies
  • Subscribers 190 subscribers
  • Views 6441 views
"Flip View" button
When routing the back of a board, it would be really nice to be able to
flip the view to see the back of the board as it really is.
It would be extremely useful when debugging a board, as it's really painful
to find a signal in eagle, then mentally flip it to find it on the physical
board.
It would also be useful for checking text layout on the back of the board.
Mentally flipping text is a bit of a pain, and almost impossible when
you're trying to evaluate its aesthetic appeal. Yes, I do consider
aesthetics important in PCB design!
I know I can print out the board mirrored, or group-then-mirror, and
various other hacks, but if this button existed, I'd click it every minute
or so when routing a complex design.
In fact, I'd prefer the board view to immediately mirror when I changed
routing layer to add a via! Other people probably wouldn't, so this would
have to be an option that defaulted to "off".
I've been using eagle for ten years, always wanting this feature, but only
just realised there was a suggestions forum!
gEDA, Orcad, Altium Designer, and probably others support this so I can't
be alone in desiring this feature! (see
http://wiki.altium.com/display/ADOH/AltiumDesignerViewer-ViewingPCBDocuments#AltiumDesignerViewer-ViewingPCBDocuments-FlippingtheBoard
for example)
  • kikoun
    kikoun over 11 years ago in reply to e14 Contributor
    hello,
    That would be a great feature for 2 particular task:
    - adjust text on bottom (silk layer)
    - debugging a board. (I know, I know, I can print, but on a printed paper highlight and search feature is very very limited...)
    Just one thing: a good visible indication must warn us if this mirrored mode is activated.
    Guillaume.
    +1 For quick board flip in view.  Board flip should also draw layers so that bottom obscures top layers, this would make routing traces and placing text on bottom just as easy as on top.
    ULP is not a good solution.  I just script ran it twice and diff'ed the before and after, and there some missing vertex's in the board that was flipped twice.
    As mentioned before, this doesn't work when there are locked components (although the script could probably updated to fix this).
    The script I used:
    https://github.com/sparkfun/SparkFun_Eagle_Settings/blob/master/ulp/mirror-board.ulp
    The before and after diff showing some missing vertex lines:
    @@ -3502,14 +3502,12 @@
    </polygon>
    <polygon width="0.254" layer="16" thermals="no">
    <vertex x="71.247" y="27.559"/>
    -<vertex x="82.677" y="27.559"/>
    <vertex x="82.931" y="27.559"/>
    <vertex x="82.931" y="15.367"/>
    <vertex x="71.247" y="15.367"/>
    </polygon>
    <vertex x="71.12" y="51.435"/>
    -<vertex x="82.55" y="51.435"/>
    <vertex x="82.804" y="51.435"/>
    <vertex x="82.804" y="39.243"/>
    <vertex x="71.12" y="39.243"/>
    @@ -3945,7 +3943,6 @@
    <wire x1="30.039" y1="18.626" x2="30.039" y2="18.126" width="0.3048" layer="16"/>
    <vertex x="29.972" y="34.163"/>
    -<vertex x="29.972" y="32.893"/>
    <vertex x="29.972" y="32.766"/>
    <vertex x="31.369" y="32.766"/>
    <vertex x="31.369" y="34.163"/>
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:ikbml3$kuu$1@cheetah.cadsoft.de...
    >> "Jeff Gough"wrote in message
    The ULP mirror-board.ulp is useful for this.
    If you create a Text Command menu button that runs this ULP you can flip
    the
    board with a single click.
    and what's happening with locked components?
    e14 Contributor over 15 years ago in reply to kcadsoft
    On 3/1/2011 12:20 AM, Klaus Schmidinger wrote:
    On 02/28/11 22:29, Gary Gofstein wrote:
    >> the only thing I would add is that it should be very clear that you are
    >> in flipped view, not requiring checking coordinates direction, pushing
    >> buttons, issuing commands. this should go without saying, but just to be
    >> sure, I'm saying it!
    Do you have any particular idea on how this could be made "very clear"?
    I guess any small icon indicating this will be overlooked, and a thick
    "yellow/black" border around the draw window indicating "Caution - you're
    in flip mode!" will be overkill...
    Klaus Schmidinger
    All I mean is that it should be readable at any time without executing a
    command. A word (like top/bottom) or indicator in the status bar, or
    near the grid/coordinate display is fine. Just so that I don't have to
    do something to see it. It's not a warning I'm looking for, it's just an
    indicator, I hope I can overlook it if I'm not looking at it.
    Many mech cad software has such a view state indicator. Text in the
    status bar is the only way I've seen it implemented.
    warrenbrayshaw wrote on Thu, 03 March 2011 15:16
    No discussion has been had on the direction of the flip.
    It has been implied that the flip is horizontal, like MIRROR, but a
    vertical flip is just as valid.  If I'm handling a PCB the flip I perform
    depends on the aspect ratio so the option to flip vertically also may be
    desirable. - thoughts?
    I suppose the full featured case would be to either mirror or not and
    rotate any 90 degree increments.
    However, if all that fanciness holds things up and makes it more difficult
    to use, I'd rather just get a simple toggle mirror view command.
    Tilmann Reh wrote:
    Warren Brayshaw schrieb:
    >> My preference is to have the indication just outside of the design
    >> area. ...
    >> 2) Change the background colour of the STATUS bar. The status bar is
    >> usually always visible and in the attention grabbing position below
    >> you sight line. Words should also be added to indicate that the
    >> BOTTOM view is active.  A simple XY graphic could also be added.
    >> indicating X increases to the left. The colour, words and icon
    >> should not be lost when  ULPs use the status command.
    >> I favour this last option.
    Tilmann Reh wrote:
    I second that.
    Currently, the status bar is almost always completely empty, or used
    to display only rather short information. It could be segmented (as
    known from many other programs), with the rightmost part showing the
    current view status - maybe bold and/or colored when not "normal".
    While thinking about it, this (another segment in the status bar)
    would also be a fine place for the annotation status: "Annotation
    active" in regular font resp. "NO ANNOTATION" in red, bold letters...
    Tilmann
    Attached is a mock up of this idea. It's very close to 'do nothing' and
    satisfies those who would like something.
    It has been implied that the flip is horizontal, like MIRROR, but a vertical
    If I'm handling a PCB the flip I perform depends on the aspect ratio so the
    option to flip vertically also may be desirable. - thoughts?
    Warren
    M_]C_X `02D9)1@`!`0$!+ $L``#_VP!#``@&!@<&!0@'!P<)"0@*#!0-# L+
    M#!D2$P\4'1H?'AT:'!P@)"XG("(L(QP<*#<I# Q-#0T'R<Y/3@R/"XS-#_
    MVP!#`0D)"0P+#!@-#1@R(1PA,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R
    M,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C_P `1" !`-H#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1 ``@$#`P($`P4%
    M! 0```%]`0(#``01!1(A,4$&$U%A!R)Q%#!D:$((TQP152T? D,V)R@@D*
    M%A7J#A(6&AXB)BI3E)66EYB9FJCI6FIZBIJKSM6VM[BYNL#Q,7&
    MQ\C)RM+3U-76U]C9VN'BX3EYN?HZ>KQ\O/T]?;W/GZ_\0`'P$``P$!`0$!
    M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"! 0#! <%! 0``0)W``$"
    M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O 58G+1"A8D-.$E\1<8&1HF
    M)R@IC4V-S@Y.D-$149'2$E4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`# ,!``(1`Q$`/P#Y_J>2RNXD
    MR6LR.K-&0Z7PK?7TMS-<-J%X7A "?OVP-V<GK[?K6CI'C;6;O4(XYR98
    MW=)G# ) SGKQZ5%-RJU7"-K15VWV.&MBIPE)0C?EW_`#.6U2%1K%^TG_/Q
    M)Q_P(U6B@2=BL,3R,!DA%8G'X5N^,-1OK7Q=JMO!?7,<*7+[(UE8!03G``Z
    M9PT?[?U/1O#MK);WMR7EVDEYVQEADDX//I^5=E7,=-1CAZ:E?9R6K*J5VH
    M1E%7<MCG;>!(+?45FB>-C;*<.K X\V/UHT/R/^$@TW'7[5%CK_?%=I9ZIJ&N
    M>$]9FNKVX$D$!9"LC<,KQD$9/'!(A/K7+:)J&IKKFL-2NSB[B_Y;-_?'O7
    M7&6*E"7/0BK;Z+_,,/6]I=2T:=AWC:(GQ7>LO/W,C_MFM;-__P`BMX&_Z][K
    M_P!'257\7:QJ9\7:@/[1N\#R\?OV_P">:]:=]JFH+X8\$%;Z!:"Z+$3-R?
    M.D&3SZ ?E5TZ4(QI5(?:W]4FOQ._#/\`?Q7FOS.?E_X]]1_'_P!%K6'I'_(:
    ML/\`KXC_`/0A742ZOJ?V?4?^)C=]_P#ENW_/-?>L+2]4U"35[)'O[ID:= RM
    M,Q!&X<'FN;&[KY_F=^8_%'Y_F9%%7/[7U/\`Z"-W_P!_V_QH_M?4_P#H(W?_
    M`'_;_&N$\T(O0+=?]?$/_H,E4ZUX]4U`Z1<N;ZWB>(!O.;(!63(Z^P_*JG
    M]KZG_P!!&[_[_M_C0!/_`,P/_/\`>KK+/_D>M'_Z]Q_Z3"N?_M?4_P"P_P#D
    M(W?_`'_;^]]:ZNPU34$\<Z0$O[I1Y .!,PY-N"3U]:Y8_'\V>[6_W5_X(?FS
    MF%2:X\'QQVWSLKGS$49)&XG&/7E3]*T_!<$MJ-0:]B>.WS3';(IQ@0ON7Z
    M8M<_9>)];T4O;ZI=C.-RF9B&'OS6C'XMUW4IY8KC4[GR3!*WEK(VW(B8CO
    MGJ,_6IE0F[P5K-WOU/DIX:H^:FK<K=[]1;!E3P;:LS!576T)). !Y8JGK]E>
    MS:M(Z6\TD95=A52P`QTXZ<YK0_M?4_\`A7G_`"$;O_D*_P#/=O\`GE]:I6OC
    M7Q#:V_D)JERRA=J%Y6)3Z<_SSTK6I"?,IPWV-ZM.?.JE.S=K:FGXM^3PYX?C
    MG_XOL_)/)X>3=S]<5<U7<WB;Q!'$V)VBB\L!L'/E=1)%<]JNO:O=1V$\VI
    MW;2/;G<WFL,XD<=O85I^,==U>W\:WDL6J7B2*8R&$[?
    U]ZA4'['DOK_3(6
    M&:H>SOKOY;W^X@\$V5[#XPTQWMYHXQ.N\LI4$9''/7G%36#1MK/B0Q8V_P!F
    M3@X&.0%S^N:;8>-O$-SJ5C ^IW 1ID1]LC?."0#G)_ECK2>%=7U/_B=_\3&[
    M_P"05/\`\MV_V?>JITY\[J3[6T*I4JGM75J66EK(JZI#<76BZ8;9'EC6,!Q'
    M\W. .0/HP]JT;!6M/AYJ:7RF/=<H(DE'.2DF,#MSD_K68>-=TXGR-3NBA.
    M2C3,5)_/^7I5JY\4:WJ&D7#7&IW3;F8!*1MRLF1U]AUK/V$](:<M[WZF7U
    M:II3TY4[WZ]S91XTT3PP7.,^<%.[`R<_GZ?C6=V6O/>3M"\_E&1BF@`8SQ
    MQFM37-7U/_A"O#__`!,;O_EI_P`MV]?K6.OC7Q,BA1K=Y@# S)D_F:<J4W+G
    MA;YG7CJ-1UN>G;9K7U9G:9J4FFW/FJ"R$8>/. WI^5;9\1:;$7FM[%O/;J2B
    MKNR><D9-?3<O@_PQ#:W$B>&=%WJHP3IT1P=P'0I]?3OZ;4S/^$?T#_H7-#_\
    M%<'_`,16E3#TZCYI&=7"TJLN:2/F+79)KWQ)J<S!GD>ZD8A03CYC^E7M-U1X
    M;/[)?6<T\0^Z=F[CC P>WXU])_V-HV]W_L1M[G-_9L&6/J?DYI?[(T?_H!
    MZ/\`^"Z#_P"(IU*2FN5K0Z)4,/4@HU$].Q\[R:K)+I6I6EC920P-:@-F/:?]
    M=&<`#@#U]<UE'HYUU[3U:*0+]IC.2IX85].KI>DJ&"Z+I ### :=#R,YP?
    ME]0/RH32]*C=731=(5U.0RZ=""#_`-\UKAN;#N\/GYE0HX:G'EA?\#YT\602
    MOXNU!EB=@?Y"D_\LUK8OK=_^$2\%NV5\NVN<J1SS/)7NLFGZ;(TDFD:4[M
    MU9K"$D_CMI9+#3IH8H9=)TMXH@5C1K"$J@))( V\`DD_C7='%VITX6^%O\36
    MEE3FIV;M_7YGS8SK):ZBR$%?FY'^XQ=(_Y#5A_U\1_^A"OJ@:-HRHR+H.C
    M!6Z@:;!@_P#CE,30M"C=73P]HBNIRKID (/J/DK$5E5::16(Q'MK.VJ/DZ
    MBOK#_A']`_Z%S0__``5P?_$4?\(_H'_0N:'_`."N#_XBN<YCY;B_Y MU_P!?
    M$/\`Z#)5.OK$:%H00H/#VB;"02O]F08)&<'[GN?SI/\`A'] P"A<T/`,%<
    M'_Q%`'S%_P`P/_/]ZNLL_P#D>M'_`.O<?DPKW/P]$\O9_PC^B[/[O]F08_
    M] J9=.TQ9TG71]*$R#"2#3X=RC&,`[<CCCZ5DJ;4K;/0J8R,J+IVZ17W,9
    M-.LK&WTL:G?J9 6PD8/7G'3C)X/&<8K6TZUT[7/M3V,!AN(K:; "A<_NGP,`
    MXYYYZ\5]`'1=%:%83H.C&)3D(=-@V@_39[FGV^EZ3:%C;:+I$)888QZ="N1@
    MC!POH3=9RH3;<E+6G8\.6&FVYJ7O7T[6[6/FV")I_ <<*D!I-8"@GIDQ8I
    M9CHFDN]G);23R;?G<J&(S[DC!P>WM7T@NDZ0D(A70]'6)7\P(-.@"A^F[&SK
    M[TR30]$F<O)X?T5W/5FTR D_^.5=2FYM7>AK5HNI)7=EY=SYR\4:9!;6&CW=
    MGG[--;'@GH?,D(Z
    C57]=T"
    9:K-=,1;VZQLX!Y/[M3Z=, ^]?04NEZ3
    M/#'#+HND211#$:/IT)5!SP!MXZG\Z5]-TN5Y7DT;27>4`2,VGPDN,8Y^7GCB
    MDJ<_9\O-KW$J53V7)S:]_P"NI\]Z`VAZIK^FVB6CQ/YR!&QM/4=P3D\9YJGH
    M5JUE>:_;N<E-G&?4?@_E7T;!HVC6LZ3V^A:-%,ARDD>FPRGU!"<4X:7I
    MO(XT72 \J%)&&G0Y=3U!7D<#BG3I.$M'IH4J+IR=I7CY]SYJM[?3=*LK:Z
    MOHVGFG7,X&!SQ]
    M/I]#2:HLJHLF@Z,ZH,(&TV A1[?)Q3X]TF*W>WCT72$@D.7C73H0K'&,D;
    M<'@G\ZCV,[\W-K^%NUC/ZO._/S/FO\K=K'S]<V7]H>&?#<!+!#YI=E&<`']/
    M3\:HM%X;@8PR$F2,[6)\S.1P>G'Y5])+I^FK&D:Z1I02,$(HL(<*#UP-O%5V
    MT'0G8LWA[1&9CDDZ9 23_P!\4Y492EK)I>1OB:<J]2_,TOU;.IO723;IY&
    M5%5%R6X`=1Z<=,=NF,<;4YW[?9_\_<'_?P5:U"6RU9!:7AVNH1QD2"*2S>
    M=4."H..0#@$?05G_`-A>'?\`H1M,_P#!,W_Q-:NI!.S9K8F^WV?_`#]P?]_!
    M1]OL_P#G[@_["H?["\._P#0C:9_X)F_)H_L+P[_P!"-IG_`()F_P#B:7M8
    M?S+OL_^?N#_OX*/M]G_P`_<'_?P5#_`&%X=_Z$;3/_``3-_P#$T?V%
    MX=_Z$;3/_!,W_P`31[6'\R^\+,FWV?_`#]P?]_!1]OL_P#G[@_["H?["\.
    M_P#0C:9_X)F_)H_L+P[_P!"-IG_`()F_P#B:/:P_F7WA9DWVS_`.?N#_OX
    M*/M]G_S]P?\`?P5#_87AW_H1M,_\$S?_`!-']A>'?^A&TS_P3-_\31[6'\R^
    M\+,FWV?_/W!_P!_!1]OL_\`G[@_["H?["\._\`0C:9_P""9O\`XFE&@^'"
    M>?!.DH.[/I!4#ZDC`IJI!NR:%8EWV?_`#]P?]_!1]OL_P#G[@_["J?]G>$
    M\D#PAHK8)4E=*R,@X/(%']F%/\`H3]&_P#!2?\`"K N?;[/_G[@_P"_@HW
    MV?\`S]P?]_!5/S?"G_0GZ-_X3_`(4?V;X4_P"A/T;_`,%)_P``+GVS_Y
    MX/_@H^WV?_`#]P?]_!5/\`LWPI_P!"?HW_`(*3_A1_9OA3_H3]&_\`!2?\
    M* +GVS_`.?N#_OX*/M]G_S]P?\`?P53_LWPI_T)C?^"D_X4?V;X4_Z$_1O
    M_!2?\* +GVS_P"?N#_OX*/M]G_S]P?]_!5/S?"G_0GZ-_X*3_A1_9OA3_H
    M3]&_\%)_PH N?;[/_G[@_P"_@HWV?\`S]P?]_!5/S?"G_0GZ-_X*3_`(4?
    MV;X4_P"A/T;_`,%)_P`*`+GVS_YX/_@HWV?_`#]P?]_!5/\`LWPI_P!"
    M?HW_`(3_A1_9OA3_H3]&_\`!2?\ +GV^S_`.?N#_OX*/M]G_S]P?\`?P53
    M_LWPI_T)C?"D_X4?V;X4_Z$_1O_!2?\* -FSU&'2(-;U.X5VAL[);B18P"
    MQ5!*Q R0,X'K6SI>LC4;BXM9K&ZL+R!$D>WN3&6\MRP5P8W9;[&/
    MLFHW:W%Q<+%,SSH9#)(#&\9VC.%R7R%#%F^;Q\(.O.[UT_)&T=CK=1UK3]
    MW_;;CRMEK->-\C-B&+;YC< ]-Z\=3G@'FK]>:7'@J]OTNS#I,%C;7%KJ%K86
    M<IC']G&>"! V$*BEXIB?']^#CYGVWV\/W:LDL.@1*UU9S6=[Y']G6L
    M:P9:Y#;UR(YAMC#(?-ZX9L<;HT[*TM2KL[RJ"ZQ:>?J44S_`&;S\-,TY"+
    MY90.)02?]7]Y=QP-T;C$UP>C"KW3++3##I,%M<VUKI'S1&-6CG68_;6!!^
    M\T04.P_UB@EL8KI?$6@7&I:A&;9MMMJ$0L=4& =UNICJ<C@RQ?+@_Z3NS^
    M[%)TZ:E;FO\`U_7S"[-O3;YM1LX[EK*ZM!(B.L=TJJ^&16Y4$E2"Q4@X.5/;
    M!-NO-_$'A/4-0UN^N9K.ZN=-DO7E6VMEM)6D)M[5$D*7(,>%,4RYX<;ACY6:
    MK">%]=L99+B&5YY;1(;^!9)5D:YNA!' \9E;:<F.&1?,90#]KW;08Q3=&#2?
    M,M0NST"BJ&AZ;_8V@:;I?F^=]BM8K?S=NW?L0+G&3C.,XR:GAOK2X\CR;J"3
    M[1$9H=D@/FQC;EUQU7YEY''S#U%<[6N@R2>"&ZMY+>XB26&5"DD<BAE=2,$$
    M'@@CM7)^'9-/N_#6I7MGJ,&I2-<R0/=QSM,?CF(AC-S\L97V8LSY8N7;J/
    M]$U/3_\`EA=V5U%[21S1L/Q#*0?H0:Y/POI6G:=X5U1[&PM;5Y-0O$=H(50L
    MJ7LJH#@<A1P!V' KOP%E45Z_4B6Q%9?ZAONLG_`&U6KV7^H;_KK)_P"A
    MM5BOJ3$**** "BBB@ HHHH **** "BBB@ HHHH **** +^C20VMQ<S3SH@D2
    M-%7#$_*6)/ VA^M;']IV/\`S\K`-\-_A7R!_PL7Q=_T&Y_^^4_PH_X6+XN
    M_P"@W/\`]\I_A7%6R^C6FYRW92DUH?7_`/:=C_S\K_WPW^%']IV/_/RO_?#?
    MX5\@?\+%\7?]!N?_`+Y3_"C_`(6+XN_Z#<__`'RG^%9?V5A^S^\?.SZ__M.Q
    M_P"?E?\`OAO\*/[3L?\`GY7_`+X;_"OD#_A8OB[_`*#<_P#WRG^%'_"Q?%W_
    M`$&Y_P#OE/\`"CRL/V?WASLO\`T['_GY7_OAO\*/[3L??E?^^&_PKY _
    MX6+XN_Z#<_\`WRG%'_"Q?%W_0;G_P"4_PH_LK#]G]X<[/K_P#M.Q_Y^5_[
    MX;_"N5?P[I=Q8ZE9W6K,8]5MVCOC;PM"QD,VZ(J,HF7?,;;PV<G-*9/FK_
    M`(6XN_Z#<__`'RG%'_``L7Q=_T&Y_4_PJXY;0C\-_O%SLE=*\Z#IVC
    MV5BKZM*]M;QPM)'J=[$K%5 R$63"@XZ.!T%:R)I6FZ#)IVG2-LW,ZJ[R2,
    MS-)O8EWR222QR3WKY4_X6+XN_P"@W/\`]\I_A1_PL7Q=_P!!N?\`[Y3_``K2
    M."IQFIW=]]PYF?35K9I'#A[N`$NSXP_&6)Q]WWJ;[/%_S^0?D_\`\37R_P#\
    M%\7?]!N?_OE/\*/%BO\`H-S_`/?*?X5UDGU!]GB_Y_(/R?\`)HSQ?\
    M_D'Y/_\`$U\O_P#"Q?%W_0;G_P"4_PH_P"%B+O@W/_P!\I_A0!]0?9XO
    M?R#\G_\`B:/L\7_/Y!3_P#Q-?+_`/PL7Q=_T&Y_^4_PH_X6+XN_P"@W/\`
    M]\I_A0!]0?9XO?R#\G_`/B:/L\7_/Y!3__`!-?+_\`PL7Q=_T&Y_\`OE/\
    M/\`A8OB[_H-S_\`??X4 ?4'V>+_G\@_)__`(FC[/%_S^0?D_\`\37R_P#\
    M%\7?]!N?_OE/\*/%BO\`H-S_`/?*?X4`?4'V>+_G\@_)_P#XFC[/%_S^
    M0?D__P`37R__`,%\7?]!N?_`Y3_"C_`(6+XN_Z#<__`'RG^% 'U!]GB_Y_
    M(/R?_P")H^SQ?\_D'Y/_`/$U\O\`_"Q?%W_0;G_[Y3_"C_A8OB[_`*#<_P#W
    MRG%`'U!]GB_Y_(/R?\`)HSQ?\_D'Y/_\`$U\O_P#"Q?%W_0;G_P"4_PH
    2_P"%B+O@W/_P!\I_A0!__9
    end
    Andrew Sterian wrote on Tue, 01 March 2011 20:40
    Second, here is my suggestion for what to do when you display the
    mirror image of the board:
    Nothing.
    I know my board designs. I know when I am looking at the front and when
    I am looking the back. A good tool stays out of the designer's way.
    Hear, hear!
    My preference is to have the indication just outside of the design area.
    2) Change the background colour of the STATUS bar. The status bar is usually
    alway visible and in the attension grabbing position below you sight line.
    Words should alo be added to indicate that the BOTTOM view is actrive.  A
    simple XY graphic could also be added. indicating X increases to the left.
    The colour, words and icon should not be lost when  ULPs use the status
    command.
    I second that.
    Currently, the status bar is almost always completely empty, or used to
    display only rather short information. It could be segmented (as known
    from many other programs), with the rightmost part showing the current
    While thinking about it, this (another segment in the status bar) would
    also be a fine place for the annotation status: "Annotation active" in
    Tilmann
    news:ikmc0n$332$1@cheetah.cadsoft.de...
    usually
    command.
    What about an XY picture linked to the lower-left corner of the drawing
    area? (lower-right in the "view from bottom" situation)?
    It is highly visible, it is always there, it doesn't stay over the board
    unless high zoom is applied (and in this case zoom was activated to see
    something in the middle of the screen, not on the corner image )
    Silviu Epure
    "Dunarea de Jos" University of Galati, Romania
    http://www.etc.ugal.ro/sepure
    >> are in flipped view, not requiring checking coordinates direction,
    >> pushing buttons, issuing commands. this should go without saying,
    >> but just to be sure, I'm saying it!
    clear"? I guess any small icon indicating this will be overlooked,
    and a thick "yellow/black" border around the draw window indicating
    "Caution - you're in flip mode!" will be overkill...
    Klaus Schmidinger
    Many replies so far but I feel many of the ideas do not address all use
    scenarios
    The TEXT on your design idea would not be workable. When you zoom, any
    TOP/BOTTOM text on the board would likely be outside of the current view.
    Changing the background color would definitely play havoc with  your color
    perception and may introduce colour mixing problems.i.e. when a via color is
    set to the background color
    A technique used in may applications is to toggle the look of an icon. Care
    is need here with placement and 'alerting' contrast if this is to work well.
    That  icon can often be outside your peripheral vision when included on the
    other toolbars. With a window reduced in size, the icon/button may be in the
    drop down extensions of the toolbar and not be visable at all.
    That said, the icon that toggles the view should toggle its face.
    The XY icon
    Added to the design area, be it solid or semi transparent, with a dense
    design it is likely the icon would be lost in the view. Many would not like
    this additional clutter in the design area.
    The icon would need to be positioned  so it remains in position relative to
    the window as you change zoom.
    Alternatively it could be positionalble by the user (floating toolbar style
    which permits it to be moved off the design area) and  transparency
    adjustable. Even the design being user definable using a user specified
    graphic.
    It should only be visable for the alternate view thus improving its alerting
    value.
    Outlining the design area
    You could add a boarder of 1 to 3 pixels to board design view. The colour
    would have to be customisable to cater for the vaious chosen backgrounds.
    This technique steals these few pixels from the design area.
    I can see the alerting effect being diminished in some density/zoom/color
    situations
    Here are two ideas.
    1) Change the colour of the scroll  bars and their background. Workable but
    no way of quickly understanding why they changed colour
    command.
    Warren
