EAGLE User Support (English) Devices on Schematic, but not on PCB
  • Replies 15 replies
  • Subscribers 189 subscribers
  • Views 2817 views
How can I have devices on the schematic diagram, but not on the PCB ?
On my schematic I want to draw some devices who are external to the PCB,
essentially to have the complete thing on the same diagram. Some of the
devices are external to the PCB. What do I have to do for Eagle to know
about that and not to insist the I place an route them ?
Markus
    autodeskguest over 9 years ago in reply to wheelthru
    Jim Williams wrote:
    I know this is an old post, but I'm facing exactly the same
    situation:  I'd like to include parts in my schematic that are
    external to the board.  Here's one more vote for adding a less arcane
    facility than having to replicate and modify lib parts with no pins or
    package.
    search for "Devices without packages" or "external" in the online help
    Lorenz
  • wheelthru
    wheelthru over 9 years ago
    I know this is an old post, but I'm facing exactly the same situation:  I'd like to include parts in my schematic that are external to the board.  Here's one more vote for adding a less arcane facility than having to replicate and modify lib parts with no pins or package.
    On Wed, 16 Mar 2011 06:23:49 +0000, Lorenz wrote:
    Ing. J.M. Rafetseder wrote:
    yes I know, but the OP wrote "But when I want to add this device to my
    board I get the error 'Device has no Package'"
    Yes, I found that you can not have pins, that means I can not just copy a
    symbol to a library, remove the package and use it. You have to remove
    the pins too.
    For now I have placed the drawing into layer 97 (info). From scratch with
    no library involved.
    Markus
    >This is why I used the name "symbols not on board" image
    >r
    So I pointed that out again
    Lorenz
    r
    Markus Baertschi wrote:
    >On Sun, 13 Mar 2011 19:52:36 +0100, Ing. J.M. Rafetseder wrote:
    >> You can move the devices to the new lbr & then change their layers to
    >> the new one - I use layer 120. Use no packages. See the attached
    >> picture. r
    >I tried this, create new symbol & device in a library, but without
    >package. But when I want to add this device to my board I get the error
    >'Device has no Package'.
    devices without package can only be added to the schematic, not the
    board.
    Lorenz
    "Markus Baertschi" <markus@markus.org> wrote in message
    news:iln94i$34t$1@cheetah.cadsoft.de...
    >> picture. r
    Does your device have any pins? If so, it will probably expect a package.
    >> picture. r
    picture. r
    On 3/14/2011 7:37 AM, Oppie wrote:
    Good idea.
    I've been putting the 'off board' parts (transistors on external
    heatsinks) on the usual layers and just not routing them. I put a dotted
    line around the board and place these parts outside the dotted area. The
    Readme file that accompanies the board release tells the assembly house
    to ignore everything outside the dotted line. The BOM will show the
    off-board parts and we include any exceptions in the readme.
    Changing the off-board components to another layer will just require
    some modifications to the display aliases (calling out layer
    combinations in a given display view). This is called out along with
    layer colors and other options in a modified 'mylayers.scr' script.
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:iliu7j$cm6$1@cheetah.cadsoft.de...
    >> Define a new layer >100 (e.g. not-on-brd or similar) & draw your parts
    >> on that layer. It is also possible to create a new lbr if some parts
    >> are used very often. I made such a lbr, if you are interested, send a
    >> mail.
    >> r
    I will just reiterate my support for adding this capability in EAGLE so
    that the off board components and their connections can be documented,
    edited, moved like normal ones. There is more to schematic capture than
    producing a board. There could just be an off-board native package
    entity that is a null package and EAGLE ignores all connections to it. A
    native off-board layer would also work, neither requires changes to the
    UI and would make the capability available for those who desire it.
