EAGLE User Support (English) vRestrict layer and DRC
  • Replies 8 replies
  • Subscribers 179 subscribers
  • Views 1856 views
I have a 4-layer board originally routed in Eagle V4 (Linux/Pro) that passed
ERC/DRC and went to production. It was discovered later that a connector had
issues (shorts) with vias under it. I'm now correcting that in V5.11.0
(Linux/Pro). I edited the connector symbol to include a vRestrict layer and
did a Library-Update All. The connector updated correctly and the vRestrict
layer now shows up as expected. Curiously, though, when I run DRC no errors
are flagged, even though nothing on the board changed except the connector
and the vias are still there, now clearly underneath the vRestrict layer.
I did a newsgroup search and the only possibility I saw was an issue with
blind vias. My stackup, however, is a simple (18+916) with no blind vias
defined. Is there some other setting I might be missing, or have I just run
into an Eagle bug?
    passed ERC/DRC and went to production. It was discovered later that a
    connector had issues (shorts) with vias under it. I'm now correcting
    that in V5.11.0 (Linux/Pro). I edited the connector symbol to include
    a vRestrict layer and did a Library-Update All. The connector updated
    correctly and the vRestrict layer now shows up as expected.
    Curiously, though, when I run DRC no errors are flagged, even though
    nothing on the board changed except the connector and the vias are
    with blind vias. My stackup, however, is a simple (18+916) with no
    blind vias defined. Is there some other setting I might be missing,
    or have I just run into an Eagle bug?
    Check within the DRC settings - 'Misc' tab that the checkbox for 'Check
    restrict' is ticked
    Warren
    Am 16.03.2011 00:16, schrieb Bob Johnson:
    into an Eagle bug?
    Please read manual_en.pdf; page 148 == vRestrict:
    Layer 43, vRestrict, is for drawing restricted areas where the
    Autorouter or the Followme router may not set vias. Manually placed
    vias in such a vRestrict region are not examined by the DRC and
    therefore not reported as an error.
    Alfred Zaffran
    _____________________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger, Bodo Badnowitz
    Former Member over 14 years ago in reply to Former Member
    "A. Zaffran" <alf@cadsoft.de> wrote in message
    news:ilpm2b$5tf$1@cheetah.cadsoft.de...
    Interesting. I wasn't aware of this. Are there any reasons for this
    behaviour? I would expect the DRC to warn about vias in vRestrict area.
  • Richard_H
    Richard_H over 14 years ago in reply to Former Member
    Am 16.03.2011 08:53, schrieb Morten Leikvoll:
    Let's call them historic reasons. image  Initally we wanted to have a
    possibitlity to tell the autorouter where it is not allowed to set
    vias. There was no DRC available at that times. The function of the
    vRestrict layer remained unchanged.
    Richard Hammerl
    Former Member over 14 years ago in reply to Richard_H
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:ilprsf$1us$1@cheetah.cadsoft.de...
    I assume there is a secret point in the secret todo list to change this then
    >> connector had issues (shorts) with vias under it. I'm now correcting that
    >> in V5.11.0 (Linux/Pro). I edited the connector symbol to include a
    >> correctly and the vRestrict layer now shows up as expected. Curiously,
    >> though, when I run DRC no errors are flagged, even though nothing on the
    >> board changed except the connector and the vias are still there, now
    >> vias defined. Is there some other setting I might be missing, or have I
    Alfred Zaffran
    Right you are. I was looking in the online help, where vRestrict is referred
    to as 'Nogo areas for via-holes', similar to tKeepout being 'Nogo areas for
    components, top side'. The latter does get a DRC warning when violated.
    Maybe the former description should include '(auto-router only)'. Anyway,
    thanks for clarifying the issue.
  • Richard_H
    Am 16.03.2011 09:32, schrieb Morten Leikvoll:
    "Richard Hammerl"<ric@cadsoft.de>  wrote in message
    >>> "A. Zaffran"<alf@cadsoft.de>  wrote in message
    I will forward this to our development people.
    Richard Hammerl
    Former Member over 10 years ago in reply to Richard_H
    >> Let's call them historic reasons.   Initally we wanted to have a
    I found this posting from four years ago after I'd noticed the same thing - I had a via in a vRestrict area, and was surprised that the DRC hadn't picked it up.
    If there's concern about breaking old board designs, perhaps a new layer (reallyVRestrict) could be introduced. Or even rename layer 43 to something other than vRestrict whenever it is found in a board file, and allocate the name vRestrict to a new layer number that behaves like the other restrict layer types.
