EAGLE User Support (English) Internet request whenever Eagle is launched
  • Views 579 views
  • eagle
With all of the illicit Internet activity these days, I was concerned when Eagle5.11 requested internet access whenever it was launched.  After discussions with Tech Support, I found that this is due to the "Daily" default setting in Help - Check for Updates.
Now that I know that this is why an Internet request was made, there are no problems.  Therefore, for the peace-of-mind of new users, I would suggest that the same "Checking for Updates" window that appears when you manually select Check-for-Updates is also launched whenever the program Automatically checks for updates.
    e14 Contributor over 14 years ago in reply to Richard_H
    Richard Hammerl wrote on Tue, 26 July 2011 03:32
    If you prefer you could switch off these checks. Go to the menu
    Help/Check for Update and set it to "never".
    That should be the default.  I really don't like it doing automatic stuff
    behind my back, especially going outside my network, unless I explicity
    gave it permission to do so.
    We have enough nagware and nannyware all around us as is.  Please not Eagle
    too.
    Perhaps a compromise,  When the software is first installed, usually from the website, it does not have to look for updates.  Why not just leave the checkmarks OFF.  Let the user determine when to look for updates.
    e14 Contributor over 15 years ago in reply to Richard_H
    Am 26.07.2011 09:32, schrieb Richard Hammerl:
    Am 22.07.2011 17:39, schrieb Doug:
    >> I would rather it didn't.
    >> I don't like distractions.
    Addition: in control panel image
    Joern Paschedag
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    Richard Hammerl
