EAGLE User Support (English) Remember ALL window positions when QUITTING.
  • Replies 20 replies
  • Views 1495 views
HI,
I am not sure if this has been asked before..
When opening EagleCad, the Control panel appears in the middle of the
screen. ( yep that's about it!)
I would like to have Eaglecad remember EVERY WINDOW and its POSITION SAVED,
when eagle cad quits. then when you re-open EagleCad, all your windows will
be as they were when you last left it!
Its very annoying at the moment..
especially when writing ULP's that I have to open a project ( for testing)
place it and resize it where I last left it.Open the help window, place it
and resize it where I last left it. reposition the Control panel resize it
where I last left it.open up my last ULP ( and maybe a few more), resize it
and position it. click though the menus of the control panel to find my
last project.. etc
this gets tedious.
I see no reason why, when eagle cad quits , it just records ..
1) The window(s) that were opened
2) The size of each window
3) the position of each window.
4) the stacking order
5) The current state of the hierarchy menus in the control panel.
This should be done for ALL windows ( including help, ulps, etc)
This should not effect anyones workflow, only improve it.
What do you guys think?
thanks
Dave M
    eSilviu wrote:
    "Joerg" <invalid@invalid.invalid> wrote in message
    news:j3880a$mfn$1@cheetah.cadsoft.de...
    >>> news:j345hh$lo9$1@cheetah.cadsoft.de...
    >> However, I make sure that I buy name-brand systems with well-validated
    >> drivers. Software that is of questionable quality gets voted off the
    >> island almost immediately. With a lesser quality system I don't doubt
    >> that there could be massive problems.
    From my experience, problems with drivers are easiest to solve. The hardest
    part is to configure the software and services that you will use, and to
    choose good antivirus/firewall/etc software. In my case, system will either
    not enter into hibernation, either locked my keypad after resume... changed
    Kaspersky for an other security software and problems are gone.
    A lot of times it's also that people think "Oh dang, it trashed this or
    that". For example, in the morning when I turn it on it first fails to
    recognize the office file server. All you have to do to "fix" this is
    get a coffee (I have one anyhow every morning), come back and ... voila
    ... all servers are now there.
    Regards, Joerg
    >> Oliver Betz wrote:
    >>> Joerg wrote:
    >>>> Another option is what I do: My PC goes to "Hibernate" instead of off.
    >>>> So Eagle and all other programs are always exactly where they were
    >>>> yesterday evening. Plus it starts a lot faster.
    >>> Things can go wrong with hibernate, I disapprove your suggestion.
    >> Nothing has ever gone wrong with hibernate here. I started doing that
    >> with the first PC I bought that offered it, a Compaq laptop. That was
    >> almost 20 years ago and I never looked back.
    I think that is very related to the software installed and
    running. There are many bad drivers out there and there are many bad
    programs that run in the background. If one fails the hibernate cycle, you
    end up with a messed up system.
    Then you can just restart. Very little time lost.
    As I wrote, I do this since the early 90's and never had problems. I
    remember sitting next to folks on very long flights and their Thinkpads
    took forever to boot. Their eyes popped wide open when they saw me
    typing away 15sec after the stewardess had cleared our tray tables.
    Regards, Joerg
    no need to be against the idea,
    There is no reason that the positions cannot be saved, along with the
    screen size, this is VERY SIMPLE PROGRAMMING, and if the project is opened
    on a different sized screen then it could be saved for that screen size and
    or proportionally adjusted for either. its just a few X & Y digits to deal
    with.
    boy, I could write some "DUMMY" CODE to show the maths if you wish?
    regards
    dave M
    I use hibernate both at work and home and I had no problems with it in
    years. I typically restart my computer every two weeks or so for
    updating drivers or various software components.
    Regarding the windows positioning issue I have to be against it as I
    work on the same project on different computers (work & home computers
    and a laptop) and everything will be messed up.
    My advice was addressed to the other readers.
    My suggestion was as well.
    Your systems are known to behave different from average.
    Yeah, they tend to work nicely when the software running on them is of
    good quality. Such as Eagle image
    Regards, Joerg
    Regards, Joerg
    Oliver
    Regards, Joerg
