EAGLE User Support (English) Cannot backannotate VIA
  • Views 972 views
I added a via (which came up square instead of round ??) to a board, now I cannot remove it as I get 'cannot backannotate this operation. Please do this in the schematic!'.
Well I added it on the board layout editor and there is NO visible via on the schematic :-O.
Please advise how I am supposed to remove this unwanted item ??.
Many Thanks
Graham
    Original Message -
    From: "grahamst" <communitymanager@premierfarnell.com>
    I can ADD a via but I cannot DELETE one - who's idea of user-friendly' is
    that ???.
    Its just because of the sch-brd consistancy connection. If you close your
    schematics, you can delete it, but you loose consistancy. You can also
    delete wires on a standalone board, but when you do this, you split the net
    in two different names. Same happens if you delete a via. each end of the
    via gets different netname (via is just a wire going into the screen).
    Now, you could suggest to Cadsoft to replace the deleted wire/via with an
    airwire. That would probably work, but also cause confusion as long as ripup
    exist and does the same. Next Q would be to merge delete with ripup... I
    won't try to defend that right now. Maybe someone can see if it will work or
    not?
    Guys,
    Thanks for the help - youp I did find this out.
    You might guess that I am a newbie to Eagle CAD - and am finding it a little 'strange' to work with - whats its background ???, did it come from a Linux app originally maybe ??.
    i like the command line (once I start to learn the commands better), but the graphical UI has some very strange interpretations.
    I can ADD a via but I cannot DELETE one - who's idea of user-friendly' is that ???.
    I also tried to find a version comparison for Eagle - to see what version I have to buy for backannotate to work - can't find this anywhere :-((.
    Graham
    undo
    ripup
    info
    change shape
    are some of the possibilities to get rid or modify the via
    Lorenz
    You can't DELETE a via, but you can RIPUP it.
    See the manual or the built-in help.
    Tilmann
    Ahhhh - managed to get rid of it by completely deleting the net, and recreating it in schematic editor, then ripup on the board, then a DRC :-O.
    What a pain :-O.
    Graham
