EAGLE User Support (English) Preventing stubs
  • Views 367 views
Preventing stubs
Often when routing wide (.04"+) traces I'll end up with a stub where the
end of one trace extends beyond the edge of the one it's joining (see
above).  Is there a way to fix or prevent this?
    Thanks.
    the end of one trace extends beyond the edge of the one it's joining
    (see above).  Is there a way to fix or prevent this?
    That happens when a wide trace ends on a narrower trace.
    The trace paths and their connections to other traces are really in the
    centre of the traces and 'fatten' in all directions with WIDTH. Hence a
    wider trace meeting a thinner trace will protrude.
    When the difference between the widths is not to much you can fix it the
    following way.
    Referring to your image.
    Use SPLIT on the vertical trace to make it a trace of two sections and then
    make the section that attaches to the horizonatal trace the same width as
    the horizonatal trace.
    Move the upper end of the wider vertical trace up onto the horizontal trace
    until it looks good..
    You will likely find you need to make the grid finer to place the trace end
    accurately.(Type in the command line GRID FINEST, position the  trace and
    then type GRID LAST to restore your grid setting).
    When the difference between the trace widths is large this technique needs
    an additional step.
    Use a polygon with the same NAME as the traces over the juction to make it
    look correct. You can even make the polygon shape such that the junction is
    blended (mitred).
    HTH
    Warren
    Obviously, this happens when that trace is wider than the one it's
    joining. EAGLE simply puts the endpoints of the tracks at the same
    coordinate - so from there, they each extend by half of their width.
    If you don't want to match trace widths, you can route a (really) short
    stub of the smaller width first, and then the rest of the trace in your
    larger width. Take care that with extreme width differences, the result
    may not look more beautiful than now...
    Generally, the simplest solution is to use the same trace width for that
    complete signal.
    Tilmann
