EAGLE User Support (English) Can't create PROJECT directory ???
  • Replies 8 replies
  • Views 1318 views
When I start my Eagle 5.11.0 I have to define the PROJECT directory every
time - it says it's not there, and when I click Yes to create, I get a
message that it can't be created.
When I go to Options/Directories then I CAN in fact see the right path, but
I HAVE to Browse and then click OK to get it to work right. When I do it
this way it works till the next time the machine has been shot down and
start again.
The project directory is on a NAS-drive and the other directories is on the
C-drive
What is wrong here ?
Best regards
KSor, Denmark
    Keld Sørensen schrieb:
    "...I do not know if this is a problem on newer windows versions. "
    It is  because I'm running af Windows 7 !
    Ok - I have to live with it OR move my Eagle data til the C-drive, but that
    was NOT the purpose of getting a NAS-drive ;-((
    I don't think there's no solution to this problem - we just pointed you
    at some details to look at.
    Try if you can access drive X: immediately after booting up the system
    (by command line or shell tool).
    Try if EAGLE can access that project path /after/ you first have
    accessed X: by any other means.
    Tilmann
    P.S. We are storing /all/ our data on a local network drive without any
    problems. Though we are currently still using XP Pro, I think this is so
    essential that it will be basically identical with 7.
    Best regards
    KSor, Denmark
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:j56lhl$le1$1@cheetah.cadsoft.de...
    Warren Brayshaw schrieb:
    >> You should verify that you can reach the X: project direatory, using
    >> explorer, before starting  Eagle.
    >> Doing that may wake up the connection to X: and then when you start Eagle
    >> it
    >> will find the project directory.
    >> If so, its a case of making the changes in Windows.
    Yes - I remember that when assigning a network drive letter, there's a
    checkbox for making it permanent...
    AFAIR, you can't change that setting later - you have to delete the
    assignment and freshly define it with that option applied.
    I have seen other similar problems on windows (xp). Network drives using
    password to logon doesnt seem to ask for password when accessed from 3rd
    party sw. They just claim the drive is not there, but when you ask for it
    through explorer, it will ask you for a password.
    I suspect this is the same network drive issue, with or without password,
    and maybe there is something cadsoft (and other sw) could do to prevent it.
    Doing that may wake up the connection to X: and then when you start Eagle it
    Tilmann
    Keld Sørensen wrote:
    That's what I did - here is my path to the MAS-drive:
    X:\PRIVAT\KELD\Hobby\Elektronik\Eagle\projects
    and here is the path seen in Option/Diretories:
    C:\Program Files\EAGLE-5.11.0\projects;
    and I HAVE tried to switch the 'C' and 'X' paths - same problem.
    If I leave out the 'C' it will still create on on the C-drive when
    started
    - never mind that !
    Best regards
    KSor, Denmark
    Warren
    news.cadsoft.de
    If I leave out the 'C' it will still create on on the C-drive when started
    - never mind that !
    looks like a Windows system (just as a remark, you'd better mentioned
    that in the first post).
    Did you check if you have full access (and permissions) to eaglerc.usr?
    That file is stored in $AppData/CadSoft/EAGLE, and that is where those
    directory settings (and many others) are stored.
    Are only the directory settings volatile, or do you have similar
    problems with other settings? What happens if you try to set the
    directory to somewhere else on the local drives?
    Tilmann
    P.S. In my experience, it's not good to include two paths there;
    further, it's better to completely separate program and data (so don't
    reference any data files in the programs installation path - if you want
    to use those files, copy them to your own paths).
    - never mind that !
    Best regards
    KSor, Denmark
    start again.
    C-drive
    Sounds like something with access permissions or non-permanent network
    addresses.
    Can you assign a (permantent) network drive letter to the path at the
    NAS that contains your data? Then use that to define the EAGLE directories.
    Tilmann
