EAGLE User Support (English) Eagle only runs DRC once?
  • Replies 9 replies
  • Views 1379 views
  When I open my board and run a DRC for the first time, everything works
great, I get some errors that I need to address, etc. However, when I fix
those errors, then click the DRC button again, nothing changes. I have to
close the board, then re-open it to be able to repeat the process.
Nothing I've found online or in the manual suggests that this should be the
case. I should be able to just click the button when I'm ready to run
again. Does anyone know what might be happening? I'm running Eagle 5.11 on
Windows 7.
    warrenbrayshaw wrote on Tue, 06 December 2011 16:39
    Good point. I have posted a request for a link to access it.
    That said, the history notes don't mention a change/fix in the DRC area.
    I tried it with v5.11 and for me drc; runs the check and presents the
    error
    listing.
    Yes, I somehow got it into a state where drc; was only running the checks
    and not showing a dialog. This happened twice yesterday, but I cannot
    reproduce it today, so I'm just going to write it off as a fluke. Anyway,
    I'm very happy now with drc; it's exactly what I was looking for. Thanks
    also for requesting the 5.11.2 beta to be back up, I see that it's there
    now in the betatest area.
    S.C. wrote:
    warrenbrayshaw wrote on Tue, 06 December 2011 13:32
    Great to hear you have made progress.
    What version are you running? With v5.11.2 I only need to enter DRC;
    to run
    the check and have the error list displayed. The additional 'errors'
    command
    is not needed.
    I am using v5.11.0. I cannot find 5.11.2 in the download area
    anywhere. I am looking in
    ftp://ftp.cadsoft.de/eagle/program/5.11
    If I look in the betatest area, I see only 5.91, which I figured is
    the 6.0 beta release.
    I tried it with v5.11 and for me drc; runs the check and presents the error
    listing.
    Warren
    news.cadsoft.de
    What version are you running? With v5.11.2 I only need to enter DRC; to
    run
    command
    is not needed.
    I am using v5.11.0. I cannot find 5.11.2 in the download area anywhere. I
    am looking in
    If I look in the betatest area, I see only 5.91, which I figured is the 6.0
    beta release.
    S.C. wrote:
    try "drc;<return>" on the commandline or assigned to a hotkey or as an
    entry in the text menu.
    Ah, interesting, so I was just typing drc and that brought up the drc
    dialog. But if I add the semicolon, that actually just runs the check
    without bringing anything up. If I add 'errors' to the command, I get
    what I was after.
    So, Options->Assign... pick a hotkey, and use the string 'drc;
    errors'. Now I can tweak the board a little, hit the hotkey, see if I
    fixed it, hit escape, tweak, and repeat. Thanks all for the help.
    What version are you running? With v5.11.2 I only need to enter DRC; to run
    the check and have the error list displayed. The additional 'errors' command
    is not needed.
    Warren
    news.cadsoft.de
    try "drc;Assign... pick a hotkey, and use the string 'drc; errors'. Now
    I can tweak the board a little, hit the hotkey, see if I fixed it, hit
    S.C. wrote:
    >It'd be great if there was some way to get the drc to run and see the
    >results with a single mouse click,
    as it's an operation I repeat quite
    >often when finalizing a design, but right now I'm just happy I don't have
    >to keep closing and re-opening, so thanks.
    try "drc;" on the commandline or assigned to a hotkey or as an
    Lorenz
    warrenbrayshaw wrote on Mon, 05 December 2011 16:21
    Your description is lacking in detail. Please say what you mean by
    "nothing
    changes"
    You "click the DRC button again" . This statement is not complete and only
    the first of two clicks required to run a DRC. When, after correcting the
    errors, you click the DRC icon, does the DRC dialog open? Then do you
    procede by clicking 'OK' in the dialog to run the DRC test? What you are
    descibing is as if you have clicked 'canel'.
    Ah I understand now. I was using the tool incorrectly. I was thinking that
    clicking the button with the exclamation point was running a drc and
    showing me any errors, but of course it just shows the errors, which I can
    now see from looking at the tooltip. If however a drc has not yet been run
    since the board has been opened, clicking the show errors dialog actually
    does seem to run a drc for you, so I (erroneously) thought it should always
    do that.
    results with a single mouse click, as it's an operation I repeat quite
    Windows 7.
    Ok maybe nobody knows the answer but are others at least seeing this
    problem? Just looking at the number of folks that have viewed this
    post, it's the third most popular post on the main page now, so I'm
    wondering if that's because others are having the problem as well.
    Over the final phase of work on my board (2-3 days or so), I probably
    had to close and re-open the board editor at least 100 times to
    re-run the DRC, so I'd love to find a way to keep the board editor
    open and re-run DRC within it. Thanks.
    I don't think that others having your problem is the reason for no replies.
    Your description is lacking in detail. Please say what you mean by "nothing
    changes"
    Experiment with the following
    Open a new board that contains just two over lapping vias.
    Run a DRC test
    You should get one 'overlap' error (and maybe  a couple of drilll errors).
    Move the vias apart and run the DRC again. It should run with no errors this
    time .
    Let us know if that works correctly
    Warren
    news.cadsoft.de
    problem? Just looking at the number of folks that have viewed this post,
    it's the third most popular post on the main page now, so I'm wondering if
    Over the final phase of work on my board (2-3 days or so), I probably had
    to close and re-open the board editor at least 100 times to re-run the DRC,
    so I'd love to find a way to keep the board editor open and re-run DRC
    within it. Thanks.
