EAGLE User Support (English) Expanded lock feature
  • Subscribers 189 subscribers
  • Views 1156 views
I'd like to be able to lock such things as board dimensions, specific
traces, drill holes, pads and polygons. Locking the board dimension wires
would be a great help if nothing else.
Thanks for listening
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    On 10/24/2012 12:18 AM, Petteri Matilainen wrote:
    Great suggestions. Sorry for jumping in on your thread but I have another
    lock feature request: Group unlocking. Currently one can only group lock
    but unlocking has to be made one by one. So if I have a board say 500 parts
    and by mistake I group all and then hit lock. Every part is locked but to
    unlock (yes, undo will help if not saved) I have to click every part one by
    one to unlock. I guess unlock should be added to the toolbar as new tool or
    expand the lock tool to select lock/unlock to it can be used when grouping.
    Good morning, Petteri,
    Group unlock is already present in Eagle.  Try this:
        group all;
        lock (CS>0 0);
    The "(CS>0 0)" is script for Ctrl-Shift-RightClick at coordinates 0,0.
    See the Eagle User's Manual under section 5.2.  Modifiers to coordinate
    clicks are explained on page 95 of the English version, and on page 97
    of the German version.
    Likewise,
        lock (C>0 0);
    will lock whatever group is currently selected.
    This can be done without using the command line by selecting the group,
    clicking the Lock icon, then Ctrl-RightClick to lock the group, or
    Ctrl-Shift-RightClock to unlock it.
    HTH,
        - Chuck
    8206.att1.html.zip
    On 2011-12-07 23:06:07 +0000, davem <imix@bigpond.net.au> said:
    I agree, this would be great,
    as a suggestion, I made a part for a M3 screw/hole and silk, so that I can
    easily place these on my board, It also shows which side to fasten on, and
    a keep out area,The silk has a small detail of an actual screw head. By
    using a part for this you can lock it in place, it also appears on your
    bill of materials!
    I agree that board outline, holes and other NON-PART items need to be
    locked .
    another option that would be great is a group feature, so that you can
    select any number of objects and then group them, give it an optional name
    , and then that group can be locked, or better yet just treat it as any
    other object.
    Dave M
    Yes, this would be very useful.
    Peter Rydesäter <noreply-82738@element14.com> wrote:
    Im looking for same feature: Locking any object. I couldent beleive that
    it was just implemented for components only and was trying and trying
    over and over again to lock outline and drills... Outline and drills are
    the first things that you want to lock.
    When can we espect to find this feature implemented for all object types?
    I have my outlines and drills as components, so I can lock them. A pcb as a
    physical component has several advantages, like appearing in the BOM.
    Im looking for same feature: Locking any object. I couldent beleive that it was just implemented for components only and was trying and trying over and over again to lock outline and drills... Outline and drills are the first things that you want to lock.
    bill of materials!
    locked .
    other object.
    Dave M
