EAGLE User Support (English) Eurocircuits and V6 .brd files
  • Replies 26 replies
  • Subscribers 180 subscribers
  • Views 2620 views
Just mailed two designs to Eurocircuits this afternoon made by Eagle V6.
Received a reject as 'does not look to be a valid .brd file'.
I wonder if they know about the changes in V6?
Robert
    Former Member over 14 years ago in reply to Former Member
    On 23/12/2011 09:24, Robert wrote:
    On 22/12/2011 23:17, Warren Brayshaw wrote:
    >> It also helps if you understand the order of the process steps the
    >> manufacturer uses. That way you don't flipout when you view a Gerber
    >> copper
    >> layer with no holes depicted.
    >> Eurocircuits have a page
    >> http://www.eurocircuits.com/index.php/technology-guidelines/pcb-layout-data/117-cadsoft-eagle-brd-to-gerber-conversion-guidelines
    >> All the best
    >> Warren
    Warren, thank you, that is a page I should have read first. Anyway, I
    think I followed the rules and submitted what was needed. The result
    will tell.
    Best wishes for Chrismas and the new year.
    Regards, Robert
    Well, the 4 layer boards came back with a layer missing. I used the ULP
    to generate the Gerber files for a 4 layer board and send it to
    Eurocircuits. When asking confirmation by mail, the answer was that it
    would be processed as a 4 layer board.
    I downloaded GC-Prevue, but can't make sense of it (it asks for file
    extensions that are not part of the many Gerber files I created). The
    HELP menu assumes that you know how to operate it.
    Is there a document that describes how to open Gerber files in GC-Prevue?
    Which board house accepts .BRD files of Eagle 6? I made 100+ boards this
    way, never a problem.
    Robert
    To use GC Prevue, open the program, then go to File>Import and select
    all of your gerber files and then you get a chance to select layer
    colors etc.
    colors etc.
    Doug, thanks. At least I see something, so I repeated the whole process:
    Followed Eurocircuits guidelines for a 4 layer board:
    - Ran CAM processor, selected gerb274x-4layer.cam, activated Dimension
    in every layer.
    - Processed the job
    - Did the same for the drill file.
    - Zipped it all up.
    Imported the zip file in GC Prevue.
    End up with 3 Hole/Rout layers (.dri, .drd, .gpi),
    and 10 Unknown physical layers P1-P10 with extensions .pls, .plc, etc.
    Displayed like:
    Physical layers
    (v)P1 Unknown "Qbus_V21.pls"
         +(v)P1.1 "Qbus_V21.pls"[a001]
    GC-Prevue reports 0 errors.
    Would this be related to gerb274x-4layer.cam not being compatible with
    Eagle V6?
    Robert
    >> colors etc.
    - Ran CAM processor, selected gerb274x-4layer.cam, activated Dimension in every layer.
    - Processed the job
    - Zipped it all up.
    Displayed like:
    Physical layers
    Would this be related to gerb274x-4layer.cam not being compatible with Eagle V6?
    Robert
    Im curious, what layers did you draw om and what layers does the cam file
    process?
    I would not recommend using any cam file unless you really know how it
    works.
    Op Sat, 14 Jan 2012 10:29:52 +0100 schreef Robert <Robert@nospam.ch>:
    >>> GC-Prevue?
    >> colors etc.
    in every layer.
    - Processed the job
    - Zipped it all up.
    Displayed like:
    Physical layers
    Eagle V6?
    Robert
    Hello Robert,
    You don't need to process the .dri file (= ASCII info file) or any of the
    .GPI files (same). All drill info is contained within the .drd file, at
    least when you use the EXCELLON drill device.
    In the Eagle documentation (help > generating output) you can find what
    the CAM extensions are used for:
    File   Layers               Meaning
    *.cmp  Top, Via, Pad        Component side
    *.ly2  Route2, Via, Pad     Inner signal layer
    *.ly3  Route3, Via, Pad     Inner signal layer
    *.ly4  $User1               Inner supply layer
    *.sol  Bot, Via, Pad        Solder side
    *.plc  tPl, Dim, tName,     Silkscreen comp. side
    *.pls  bPl, Dim, bName,     Silkscreen solder side
    *.stc  tStop                Solder stop mask comp. side
    *.sts  bStop                Solder stop mask sold. side
    *.drd  Drills, Holes        Drill data for NC drill st.
    The "unknown" layers in GC Prevue are just because you didn't gave them a
    name. While importing you are given the chance to name the layer and
    indicate it's purpose. 'signal', 'soldermask', etc. and 'top', 'bottom',
    etc. are indicated in drop lists.
    I don't think you should (need to) activate the dimension layer in every
    layer. At least I don't. I make one layer that I call .fab, where the
    'dimension' layer is included along with the 'drills' and 'holes' layer.
    When you plot every layer with the GERBER_RS274X device you should import
    them (as Doug said) as a "physical layer". The .drd file should be
    imported as a "hole /rout layer". When 'autoguessing' the settings in the
    drill file GC Prevue often get's it wrong. If hat happens, you'll see the
    drills plotted in (totally) wrong places. Just delete the hole/rout layer
    and the associated aperture file and start the import again. This time, in
    the "Import - Verify File Information" window, right click on the NC drill
    file and choose "Modify format parameters..." . look for the right
    settings, especially "whole digits" (2), "precision" (4) and the right
    format for the "embedded drill table units" (inches or mm).
    remember that the way gerber files are made are a bit 'loose', meaning
    things like file extensions are not defined (every program uses different
    ones) and PCB manufacturers sometimes have different idea's of what should
    be included in what layer and in what format. So it is always wise to see
    if your intended PCB manufacturer has an explanation of how he expects
    things and if not, give 'm a call.
    That said, I've made hundred's of PCB's with different manufacturers and
    never really had a problem. I've used GC Prevue for more than 10 years and
    it always worked fine. As said, it sometimes only needs a little attention
    when importing the drill file.
    Good luck,
    Richard
    On 14/01/2012 14:35, Richard Herman wrote:
    Hello Robert,
    the .GPI files (same). All drill info is contained within the .drd file,
    at least when you use the EXCELLON drill device.
    File Layers Meaning
    a name. While importing you are given the chance to name the layer and
    import them (as Doug said) as a "physical layer". The .drd file should
    be imported as a "hole /rout layer". When 'autoguessing' the settings in
    the drill file GC Prevue often get's it wrong. If hat happens, you'll
    see the drills plotted in (totally) wrong places. Just delete the
    hole/rout layer and the associated aperture file and start the import
    again. This time, in the "Import - Verify File Information" window,
    right click on the NC drill file and choose "Modify format
    parameters..." . look for the right settings, especially "whole digits"
    (2), "precision" (4) and the right format for the "embedded drill table
    different ones) and PCB manufacturers sometimes have different idea's of
    what should be included in what layer and in what format. So it is
    always wise to see if your intended PCB manufacturer has an explanation
    of how he expects things and if not, give 'm a call.
    and it always worked fine. As said, it sometimes only needs a little
    attention when importing the drill file.
    Good luck,
    Richard
    Richard, thanks a lot. I spend a lot of time trying to display a single
    layer in GC Prevue (an application from hell if you are new to this),
    but did not succeed. However I found a great viewer on the web,
    GerberLogix (free for non commercial use) which is a breeze to use.
    I see that layer 3 (in Eagle), which became .L15 in the Gerber files,
    was completely wrong, no wiring. This is probably because the quad layer
    board was defined in Eagle as (123*16). Have to read more about that.
    Anyway, thanks for the advice.
    Regards, Robert
    Robert wrote on Sat, 14 January 2012 11:33
    layer
    That sounds like you used layers 1, 2, 3 and 16, but wrote out layers 1, 2,
    15, and 16.  I always use consecutive layers from one except that the
    bottom layer is 16 to avoid any confusion.  Still, that should have been
    easily spotted when previewing the gerber files, so I still don't see how
    that could have happened.
    >> layer
    Well, I simply ran the gerb274x-4layer.cam job. It generates tabs for
    the internal layers .ly2 and .l15 with above Eagle layer definition. No
    idea that that was wrong. Will investigate.
    Robert
    >>> layer
    Well, I simply ran the gerb274x-4layer.cam job. It generates tabs for the
    internal layers .ly2 and .l15 with above Eagle layer definition. No idea
    Robert
    I suspected that. Maybe a future cam proc could warn about data in copper
    layers that isnt associated with a job?
    >>>> layer
    >> Robert
    Morton, after some testing I found where the problem is. The
    gerb274x-4layer.cam only looks at top, bottom, layer 2 and 15. I have
    not found out how I can get it to look at my layer 3.
    Furthermore, it will only deal with layer 2 and 15 as signal layers, and
    I have my layer 2 defined as ground plane. Since I got my design error
    free after some manual work, I'd like to keep it. Is there a way in
    Eagle to move the layers to match gerb274x-4layer.cam or another way to
    create Gerber files from my current design?
    Regards, Robert
