It looks like the gerb274x-4layer.cam job has a bug, according to the
listing. When it processes layer 15, it only reads pads, vias and
dimension, but not the signals on layer 15.
Robert
Robert
On 18/01/2012 17:21, Walter Spermann wrote:
Hi Robert,
>>>> Robert
>>> Hi,
>>> I can't reproduce this problem. What EAHLE version do you use? Are
>>> you sure that in the layer 15 sections are activated layer 15 17 18 ?
>> Richard, take a look at the listing, below is the part that generates
>> layer 2 and layer 15, taken from the distribution that is in V6.1.0:
sorry, you must have changed something.
I attached the file gerb274x-4layer.cam that comes with 6.1.0.
It hasn't been changed since from us since a while.
Walter Spermann
Yes, that must have been the case. My separate Eagle 5 CAM files are
correct. Sorry about that.
Robert.
Robert
Lets get a misunderstanding out. When making 4 layer boards, the
innerlayers can in theory be at any layer between 2 and 15. You choose this
in the DRC window.The cam file needs to match your stackup configuration.
If the cam is made to use layers 1,2,15 & 16, it will fail on a board file
setup to use layers 1,2,3 & 16.
Hi Robert,
>>> Robert
>> Hi,
Walter Spermann
Name[de]="Innenlage - Layer2"
Name[en]="Inner layer - Layer2"
Prompt[de]=""
Prompt[en]=""
Device="GERBER_RS274X"
Wheel=".whl"
Rack=""
Scale=1
Output="%N.ly2"
Flags="0 0 0 1 0 1 1"
Emulate="0"
Offset="0.0mil 0.0mil"
Sheet=1
Tolerance="0 0 0 0 0 0"
Pen="0.0mil 0"
Page="12000.0mil 8000.0mil"
Layers=" 2 17 18 20"
Colors=" 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 6 6 4 8 8 8 8 8 8 8 8 8 8 8 8 8
4 4 1 1 1 1 3 3 1 2 6 8 8 5 8 8 8 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 4 3 6 6 1 1 1 1 1 1 1 1
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
1 1 1 1 1 1 0"
Name[de]="Innenlage - Layer15"
Name[en]="Inner layer - Layer15"
Prompt[de]=""
Prompt[en]=""
Wheel=".whl"
Rack=""
Scale=1
Output="%N.l15"
Emulate="0"
Sheet=1
Pen="0.0mil 0"
Layers=" 17 18 20"
1 1 1 1 1 1 0"
You will see that for layer 2, Layers=" 2 17 18 20" , is correctly
specified. For layer15: Layers=" 17 18 20", the layer 15 itself is missing.
Of course it is easy to correct, but distributed incorrect. I fell in
that trap processing my first 4 layer board...
Robert
Walter Spermann
Softwareentwicklung
CadSoft Computer GmbH
Pleidolfweg 15
84568 Pleiskirchen
Tel.: 08635/6989-10
www.cadsoft.de
| gerb274x-4layer.cam.zip |
>> Robert
Prompt[de]=""
Prompt[en]=""
Wheel=".whl"
Rack=""
Scale=1
Output="%N.ly2"
Emulate="0"
Sheet=1
Pen="0.0mil 0"
1 1 1 1 1 1 0"
Prompt[de]=""
Prompt[en]=""
Wheel=".whl"
Rack=""
Scale=1
Output="%N.l15"
Emulate="0"
Sheet=1
Pen="0.0mil 0"
Layers=" 17 18 20"
1 1 1 1 1 1 0"
Robert
Robert
Richard Hammerl
