EAGLE User Support (English) Library definitions in XML
  • Views 489 views
OK, lacking a diode quad symbol, I decided to make my own.  Or, rather, I stole a symbol from geda and converted it with an awk script.  But, when I try to read the library in with the <connects>, it objects.  Any ideas why this is?  And, just for amusement, here is my code:
<symbols>
<symbol name="SCHOTTKY-QUAD">
<wire x1="-0.800000" y1="0.600000" x2="-1.400000" y2="0.000000" width="0.254" layer="94"/>
<wire x1="0.800000" y1="0.600000" x2="1.400000" y2="0.000000" width="0.254" layer="94"/>
<wire x1="0.000000" y1="-1.400000" x2="0.500000" y2="-0.900000" width="0.254" layer="94"/>
<wire x1="0.500000" y1="0.300000" x2="1.100000" y2="0.900000" width="0.254" layer="94"/>
<wire x1="0.200000" y1="0.600000" x2="0.800000" y2="1.200000" width="0.254" layer="94"/>
<wire x1="0.200000" y1="0.600000" x2="0.800000" y2="0.600000" width="0.254" layer="94"/>
<wire x1="0.800000" y1="0.600000" x2="0.800000" y2="1.200000" width="0.254" layer="94"/>
<wire x1="-0.500000" y1="0.900000" x2="0.000000" y2="1.400000" width="0.254" layer="94"/>
<wire x1="0.200000" y1="-0.600000" x2="0.800000" y2="-1.200000" width="0.254" layer="94"/>
<wire x1="0.500000" y1="-0.300000" x2="1.100000" y2="-0.900000" width="0.254" layer="94"/>
<wire x1="0.500000" y1="-0.300000" x2="0.500000" y2="-0.900000" width="0.254" layer="94"/>
<wire x1="-0.800000" y1="0.600000" x2="-0.200000" y2="0.600000" width="0.254" layer="94"/>
<wire x1="0.000000" y1="1.400000" x2="0.500000" y2="0.900000" width="0.254" layer="94"/>
<wire x1="-0.600000" y1="-0.800000" x2="0.000000" y2="-1.400000" width="0.254" layer="94"/>
<wire x1="-0.900000" y1="-1.100000" x2="-0.300000" y2="-0.500000" width="0.254" layer="94"/>
<wire x1="-1.200000" y1="-0.800000" x2="-0.600000" y2="-0.200000" width="0.254" layer="94"/>
<wire x1="-1.200000" y1="-0.800000" x2="-0.600000" y2="-0.800000" width="0.254" layer="94"/>
<wire x1="-0.600000" y1="-0.800000" x2="-0.600000" y2="-0.200000" width="0.254" layer="94"/>
<wire x1="-1.400000" y1="0.000000" x2="-0.900000" y2="-0.500000" width="0.254" layer="94"/>
<text x="-1.40" y="0.00" size="1.0" layer="95">&gt;NAME</text>
<text x="0.00" y="-1.40" size="1.0" layer="96">&gt;VALUE</text>
<pin name="1" x="-1.40" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="2" x="0.00" y="-1.40" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="3" x="0.00" y="+1.40" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="4" x="1.40" y="0.00" visible="off" length="short" direction="pas" />
</symbol>
</symbols>
<devicesets>
<deviceset name="HSMS2828" prefix="D">
<description>&lt;b&gt;Silicon Schottky Diode Quad&lt;/b&gt;&lt;p&gt;
General-purpose diode for high-speed switching
</description>
<gates>
<gate name="G$1" symbol="SCHOTTKY-QUAD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT143-R">
<connects>
<connect gate="G$1" pin="AA" pad="3"/>
<connect gate="G$1" pin="AC" pad="1"/>
<connect gate="G$1" pin="CC" pad="2"/>
<connect gate="G$1" pin="CA" pad="4"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
    Mark Kahrs wrote:
    Warren --- thanks! Sometimes you just need another set of eyes.
    Now to get back to the work of trying to get the attachment points in
    the right place. Does anyone happen to know what (a) length="short"
    and (b) direction="pas" mean in the <pin> section?
    Sure
    Have a look at HELP / EDITOR COMMANDS / PIN
    Warren
    news.cadsoft.de
    Now to get back to the work of trying to get the attachment points in the right place.  Does anyone happen to know what (a) length="short"  and (b) direction="pas" mean in the <pin> section?
    my code:
    <symbols>
    width="0.254" layer="94"/> <wire x1="0.800000" y1="0.600000"
    x2="1.400000" y2="0.000000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="0.500000" y1="0.300000"
    x2="1.100000" y2="0.900000" width="0.254" layer="94"/> <wire
    layer="94"/> <wire x1="0.200000" y1="0.600000" x2="0.800000"
    y2="0.600000" width="0.254" layer="94"/> <wire x1="0.800000"
    width="0.254" layer="94"/> <wire x1="0.200000" y1="-0.600000"
    x2="0.800000" y2="-1.200000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="0.500000" y1="-0.300000"
    x2="0.500000" y2="-0.900000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="0.000000" y1="1.400000"
    x2="0.500000" y2="0.900000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="-0.900000" y1="-1.100000"
    x2="-0.300000" y2="-0.500000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="-1.200000" y1="-0.800000"
    x2="-0.600000" y2="-0.800000" width="0.254" layer="94"/> <wire
    width="0.254" layer="94"/> <wire x1="-1.400000" y1="0.000000"
    x2="-0.900000" y2="-0.500000" width="0.254" layer="94"/> <text
    x="-1.40" y="0.00" size="1.0" layer="95">&gt;NAME</text> <text
    x="0.00" y="-1.40" size="1.0" layer="96">&gt;VALUE</text> <pin
    rot="R180"/> <pin name="2" x="0.00" y="-1.40" visible="off"
    length="short" direction="pas" rot="R270"/> <pin name="3" x="0.00"
    direction="pas" /> </symbol> </symbols> <devicesets> <deviceset
    name="HSMS2828" prefix="D"> <description>&lt;b&gt;Silicon Schottky
    </description>
    <gates>
    </gates>
    <devices>
    <connects>
    </connects>
    <technologies>
    </technologies>
    </device>
    </devices>
    </deviceset>
    A quick look at the code
    The symbol pins are named 1 thru 4
    Later you try to connect pin names  AA,AC,CC,CA to pads
    That may well be the issue.
    Warren
    news.cadsoft.de
