EAGLE User Support (English) Overlapping Pads
  • Views 629 views
Overlapping Pads
I have two problems that I need to solve, both involving high-current
circuits:
First, I'm going to be laying down some FETs in SO-8 packages, and I want
a good solid connection from the four drain pins to a surrounding
polygon, both for current flow and to provide a thermal path for heat
sinking.  For the same part I want the same solid connection to the
source pins, although I don't need a polygon.  Connections that allow
good wide traces (up to 200 mils would be nice) without stomping on the
gate connection would be nice.
Second, I'll be putting in some current sense resistors.  While I'm going
cheap and using 2-terminal resistors, I'd like to make a pseudo 4-
terminal device by laying the part out with four pads, but then
connecting pairs of pads with a polygon or some such so that it looks and
solders like a regular resistor, but so that I can have my nice high-
current connections going to it with honkin' big traces, and still have
some thin traces coming off of the pads -- independent of the big traces
-- in a "pseudo Kelvin" connection.
Has anyone solved this problem before?  Got any suggestions on how to
proceed?
My liberal friends think I'm a conservative kook.
My conservative friends think I'm a liberal kook.
Why am I not happy that they have found common ground?
Tim Wescott, Communications, Control, Circuits & Software
http://www.wescottdesign.com
    Tim Wescott wrote:
    On Tue, 07 Feb 2012 07:56:59 +1300, Warren Brayshaw wrote:
    >>> high-current circuits:
    >>> want a good solid connection from the four drain pins to a
    >>> surrounding polygon, both for current flow and to provide a thermal
    >>> path for heat sinking.  For the same part I want the same solid
    >>> connection to the source pins, although I don't need a polygon.
    >>> Connections that allow good wide traces (up to 200 mils would be
    >>> nice) without stomping on the gate connection would be nice.
    As you know that 4 pins on one side are common and three on the other are
    common I would make a library device that a single pad covering those
    regions, including the heat sink.
    That gives only 3 pins of the symbol to match with three pads of the
    package. When placed on the board, connect up with modest traces initially .
    Then plonk a polygon over the drain and source pins as required to get the
    copper coverage.
    Name these polygons to match the signal name at the drain and source as
    appropriate.
    Increase the sizes of the feeder traces as best you can.
    HTH
    Warren
    news.cadsoft.de
    On Tue, 07 Feb 2012 11:01:29 +1300, Warren Brayshaw wrote:
    Tim
    See this document
    http://www.irf.com/technical-info/appnotes/an-1154.pdf
    Do you want to achieve the land pattens they have for their SO8 Fig 4
    Pretty much, yes.
    Tim
    See this document
    Pretty much, yes.
    Tim
    See this document
    Fig 4
    Warren
    news.cadsoft.de
    >> circuits:
    >> want a good solid connection from the four drain pins to a surrounding
    >> going cheap and using 2-terminal resistors, I'd like to make a pseudo
    >> 4- terminal device by laying the part out with four pads, but then
    >> and solders like a regular resistor, but so that I can have my nice
    >> high- current connections going to it with honkin' big traces, and
    >> still have some thin traces coming off of the pads -- independent of
    >> the big traces -- in a "pseudo Kelvin" connection.
    >> proceed?
    Hi Tim
    Mock up an image of what you are attempting. That would make a
    potentially long reply more targetted.
    Warren
    SO-8 case (view in fixed-width):
       _________
      /         \________
    thermal  ________ thick drain trace to wherever
    pad
    chip
    \_____ thin gate trace
      \__   _/
          thick source trace to wherever
    R2512 case:
                     _____            _____
                ____|   .----
    .   |______
    part
    thick trace to wherever
    thick trace ____
    ______
    to wherever
                    \_____/\        /\_____/
                          thin traces to
                          voltage amplifier
    circuits:
    proceed?
    Hi Tim
    Mock up an image of what you are attempting. That would make a potentially
    Warren
    news.cadsoft.de
