EAGLE User Support (English) Bottom layer view
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 1058 views
Bottom layer view
skyflyrr
skyflyrr over 14 years ago
Here is another suggestion I feel would help when laying out boards. While I do like the mirror command and view, it would be very helpful to be able to flip the board in layout mode to be able to see the back side without having to see everything backwards.
Thanks again,
Bob Moreno
    Am 17.07.2012 20:24, schrieb Jorge Garcia:
    We don't include it in the DRC, because the general recommendation is to
    run the DRC often and this would generate many nuisance errors.
    Some suggestions for this:
      1. It is NOT necessary for the DRC to show all unrouted airwires
         as SEPARATE errors. This doesn't make any sense, anyway, because
         a RATSNEST might move the errors to some different location.
         But showing ONE error like '21 unrouted airwires left' (or
         similar) would be a real help. Clicking on this error could
         do
          - either nothing at all (because there might be billions
            of airwires), or
          - switch off all other layers and ONLY show the 'unrouted'
            layer.
      2. About 'nuisance' errors (I refer to version 5.12 now, because
         we do not yet use version 6):
          - It should be possible to disable 'Layer Setup' checking.
            Since EAGLE doesn't support jumper wires, the only
            possibility to do this is via an inner layer abused for
            routing these jumper wires. Of course, this then introduces
            lots of DRC errors that need to be ignored. It would be
            nice if either the 'Layer Setup' checking could be disabled,
            or a selectable LAYER could be ignored by the DRC.
    Andreas Weidner
    e14 Contributor over 14 years ago in reply to skyflyrr
    On 7/17/2012 1:29 PM, Bob Moreno wrote:
      why does the program not alert you that not all routing is not done?
    Hi Bob,
    The DRC doesn't tell you that there are unrouted airwires that's true,
    however there is a means to check. If you click the Ratsnest button look
    at the bottom left of your screen EAGLE will tell you the number of
    airwires remaining. If you've routed everything then it will say
    "Nothing to do".
    Maybe this is something we can address in a future release of EAGLE.
    In the meantime use the ratsnest command to make sure you don't have any
    airwires left.
    Best Regards,
    Jorge Garcia
  • skyflyrr
    skyflyrr over 14 years ago in reply to e14 Contributor
    I wish I knew how the softwqare works, so all I can do is make suggestions. One program I use often is WinQcad (no longer supported). It can flip boards and back with just a menu command. It can also make custom packages (pads) of any kind with just telling it the X and Y sizes and how many rows or colums you need. No need to change grid sizes back and forth. One other thing on my wish list is for the board view to highlight (only highlight) unrouted wires. I just found out you can use your cursor to locate unrouted wires, but by doing that the router starts routing. And by the way, why does the program not alert you that  all routing is not done? Besides the line way down on the bottom left. Too easy to forget/miss. Yes, I did send a board out that was not 100% routed!
    I know a lot off the original subject sorry.
    On 7/16/2012 3:09 PM, Markus Rudolf wrote:
    Am 16.07.2012 19:53, schrieb Jorge Garcia:
    >> See mirror-board.ulp and the new
    >> mirror-board-remirror-element-swap-layer.ulp.
    >>   Not an ideal solution but shows why the multiply by -1 and shift
    >> viewport might not work, since that's exactly what it does.
    >> hth,
    >> Jorge Garcia
    mirror-board.ulp works OKish, but as it is a ULP, you cannot undo the
    mirroring by just pressing UNDO.
    You can undo the mirror by running the ULP again, no need for UNDO, you
    can attach the ULP to a shortcut for easy flipping.
    The other ULP I wasn't aware of yet doesn't work on my 4 Layer board
    complaining only Layer 1 & 16 supported.
    I saw this one yesterday when I was researching for the reply. I'm not
    sure yet how it works but I think it's purpose is drastically different
    to that of mirror-board.ulp.
    ULP won't help anyhow, it's a function that needs to be implemented in
    the program logic. I don't think it has to be very fancy, even I don't
    think it needs support for editing.
    In 95% of the cases I just wanna know how the board would look like from
    the backside for fine adjusting silkscreen and such. Printing mirrored
    everytime is not very effcient, and with the ULP I cannot go back and
    forth with a button click. Plus it works on the board's data structures
    permanently.
    Just give us a button somewhere which does what the ULP does without
    messing with the board itself.
    Agreed it could definitely be cleaner, especially avoiding the
    actual(parts actually get moved to make the view) flipping the ULP does
    to create the view. But as noted above with proper setup it can be a
    decent workaround while we wait for a native implementation.
    hth,
    Jorge Garcia.
    hth,
    Jorge Garcia
    permanently.
    Markus
    On 7/14/2012 8:04 AM, Markus Rudolf wrote:
    >> This is a very long standing wish, yet unsupported. :-\
    >> Tilmann
    Obviously it's very complicated to multiply the X Coordinate of each
    primitive by -1 and shift the viewport....
    I can remember wanting this since the DOS age (must be around 1996....)
    Markus Rudolf
    hth,
    Jorge Garcia
    Tilmann
    Markus Rudolf
    Tilmann
    I agree, that would be very useful when manually assembling or
    inspecting a board.
    Zoran
