EAGLE User Support (English) Formatting Xref net labels
  • Replies 42 replies
  • Subscribers 192 subscribers
  • Views 7905 views
zainka
zainka over 13 years ago
Hi
Normally I have used only the text-based net labels on line that goes
from one sheet to another. My wish is to use the XREF option but I am
not comfortable with the format options.
My "big" problem is that the signal name for a given net label comes
inside the flag. I would prefer all symbols to be of equal size and to
have the text align on beside of the net flag instead.
not like this            but like this
   ______________________          _____
/NETLABEL_SIGNAL_NAME |       /     | NETLABEL_SIGNAL_NAME
  \______________________|        \_____|
If not existing as an option already I would recommend to make the order
of the label xref formatting tags relevant (as set in misc menu) to the
result. Se my examples below:
                  ________________
%F%N (%S)      / NETLABEL (1)  |
                 \________________|
                  _____
%N %F(%S)      / (1) | NETLABEL
                 \_____|
                  _____
%N (%S)%F      /     | NETLABEL (1)
                 \_____|
Here everything coming in front of the %F tag ends up outside the flag
and everything after %F ends up inside. The flag symbol would thus have
a minimum size like say 3 letters.
Second. Is it possible to have flags indicating direction of a net? I.e.
if signal is in, out or bidirectional. This should be possible to change
with a change command like for example CHANGE DIRECTION or CHANGE FLAG
if not existing as an option already somewhere.
input             bi              output
   _______          ______         ______
_/       |       /      \       |      \
  \_______|        \______/       |______/
NOTE: I asked this as an question in the support forum, but as mentioned
there I would put it here as a suggestion if it was not possible in some
other way already. As far as I can see, it is not, though I am using
glasses....!*
Breg
Vidar (Z)
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    martonmiklos wrote on Mon, 20 February 2017 22:17
    2017-02-15 00:38 keltezéssel, Jorge Garcia írta:
    Hi Jorge,
    How about having a way to be able to define our own XREF symbols so
    they
    match how we like to define our own schematics? Simply add a new
    pin type
    in the library editor so we can define a symbol and give it a pin
    with a
    type of XREF which will then allow the part to be placed without
    having a
    corresponding package and will trigger the schematic editor to
    treat it
    like a regular XREF. That would give lots of flexibility I think.
    Best Regards,
    Rachael
    Hello Rachael,
    I've added enhancement requests for both suggestions and linked
    them so
    at some point they'll be discussed together.
    Thanks for the suggestion.
    Best Regards,
    Jorge Garcia
    Rachael:
    Yeah that would also makes sense. Mentor DxD have had implemented it in
    the same way (or at least it was a way to such a symbol if I remember
    well).
    Yes you might be right. It's been a while since I looked at how I set up
    DxD when I was using it regularly, I don't think it was the way it worked
    with the version I've used but it's likely something they added as I think
    I made a similar suggestion to them back in 2009 when I was using it
    heavily.
    I'm hoping that this suggestion is something that they can achieve really
    easily so they can get it implemented without any impact to anything else
    Best Regards,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    Hi Jorge,
    How about having a way to be able to define our own XREF symbols so they
    match how we like to define our own schematics? Simply add a new pin type
    in the library editor so we can define a symbol and give it a pin with a
    type of XREF which will then allow the part to be placed without having a
    corresponding package and will trigger the schematic editor to treat it
    Best Regards,
    Rachael
    Hello Rachael,
    I've added enhancement requests for both suggestions and linked them so
    Best Regards,
    Jorge Garcia
    Rachael:
    the same way (or at least it was a way to such a symbol if I remember well).
    autodeskguest over 9 years ago in reply to rachaelp
    Hi Jorge,
    Best Regards,
    Rachael
    Hello Rachael,
    Best Regards,
    Jorge Garcia
    We have a new forum here <http://forums.autodesk.com>
    Hi Jorge,
    Best Regards,
    Rachael
    Hello Rachael,
    Best Regards,
    Jorge Garcia
  • rachaelp
    Jorge Garcia wrote on Fri, 10 February 2017 17:29
    Is there any update on this one? The v8 is out but this issue
    still
    unsolved.
    Any plans implementing this soon?
    Hello Marton,
    All of these discussions were done prior to our purchase by Autodesk.
    With that said an enhancement request was made for the feature, however
    like I said previously it's low Priority for now.
    I'll go ahead and bump the feature request again to see if I can get
    our
    new devs to look at it and see their opinion.
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    Best Regards,
    Rachael
  • rachaelp
    still
    unsolved.
    Hello Marton,
    our
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    Best Regards,
    Rachael
    Is there any update on this one? The v8 is out but this issue still
    unsolved.
    Hello Marton,
    I'll go ahead and bump the feature request again to see if I can get our
    Best Regards,
    Jorge Garcia
    2016-05-13 10:33 keltezéssel, Richard Hammerl írta:
    Am 12.05.2016 um 14:51 schrieb Joern Paschedag:
    Am 12.05.2016 um 09:15 schrieb Morten Leikvoll:
    Just a comment to 1)
    I'd like to have the option for auto direction on this arrow. Since pin
    directions are defined in the devices, eagle can resolve wether the
    segment is connected to some output net, or only input nets, and choose
    direction according to this.
    That would be nice image
    currently there are no concrete plans. It's in the todo list, but
    with low priority. I will bring this up for V8 again.
    - Direction for xref labels
    - xref for a bus
    However, not everyone is actively using pin directions on their devices
    (the lazy, sloppy and unskilled ones just set them to i/o or pas), so
    maybe there is a need for a manual direction too. The options for arrow
    direction should be:
    -Auto (based on segment pinrefs)
    -in (always pointing toward the end of the wire)
    -out (always pointing away from the end of the wire)
    -bidir (arrow in both directions)
    If the direction arrows are done correctly everything is nice.
    However (greetings from orcad) I once had to modify drawings and those
    people gave a damn on correct use of it. I ran into trouble until I
    completely ignored the directions.
    So I'm not  too eager on that, but would be nice to have.
    With auto, there is also some options for live ERC, like the ability to
    detect and show if the net is missing a driver or double driven by
    multiple outputs.
    Finally, I wouldn't mind of the xrefs got split into a new primitive
    called pageconnector, and get an attribute containing ALL the
    references. Also the full list of references should be shown at the
    tooltip on mouseover/hover event.
    I don't know if this is practical. Think  of a little project with 15 to
    20 pages and then select "GND"....perhaps it would be better in kind of
    an info line...
    It's planned to show the occurences of the net in the info dialog.
    Finally it should be possible to hook it to a bus too.
    unsolved.
    - xref for a bus
    multiple outputs.
    an info line...
    unsolved.
    - xref for a bus
    multiple outputs.
    an info line...
    unsolved.
