EAGLE User Support (English) Formatting Xref net labels
  • Replies 42 replies
  • Subscribers 192 subscribers
  • Views 7936 views
zainka
zainka over 13 years ago
Hi
Normally I have used only the text-based net labels on line that goes
from one sheet to another. My wish is to use the XREF option but I am
not comfortable with the format options.
My "big" problem is that the signal name for a given net label comes
inside the flag. I would prefer all symbols to be of equal size and to
have the text align on beside of the net flag instead.
not like this            but like this
   ______________________          _____
/NETLABEL_SIGNAL_NAME |       /     | NETLABEL_SIGNAL_NAME
  \______________________|        \_____|
If not existing as an option already I would recommend to make the order
of the label xref formatting tags relevant (as set in misc menu) to the
result. Se my examples below:
                  ________________
%F%N (%S)      / NETLABEL (1)  |
                 \________________|
                  _____
%N %F(%S)      / (1) | NETLABEL
                 \_____|
                  _____
%N (%S)%F      /     | NETLABEL (1)
                 \_____|
Here everything coming in front of the %F tag ends up outside the flag
and everything after %F ends up inside. The flag symbol would thus have
a minimum size like say 3 letters.
Second. Is it possible to have flags indicating direction of a net? I.e.
if signal is in, out or bidirectional. This should be possible to change
with a change command like for example CHANGE DIRECTION or CHANGE FLAG
if not existing as an option already somewhere.
input             bi              output
   _______          ______         ______
_/       |       /      \       |      \
  \_______|        \______/       |______/
NOTE: I asked this as an question in the support forum, but as mentioned
there I would put it here as a suggestion if it was not possible in some
other way already. As far as I can see, it is not, though I am using
glasses....!*
Breg
Vidar (Z)
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 12.05.2016 um 09:15 schrieb Morten Leikvoll:
    Just a comment to 1)
    I'd like to have the option for auto direction on this arrow. Since pin
    directions are defined in the devices, eagle can resolve wether the
    segment is connected to some output net, or only input nets, and choose
    direction according to this.
    That would be nice image
    However, not everyone is actively using pin directions on their devices
    (the lazy, sloppy and unskilled ones just set them to i/o or pas), so
    maybe there is a need for a manual direction too. The options for arrow
    direction should be:
    -Auto (based on segment pinrefs)
    -in (always pointing toward the end of the wire)
    -out (always pointing away from the end of the wire)
    -bidir (arrow in both directions)
    If the direction arrows are done correctly everything is nice.
    However (greetings from orcad) I once had to modify drawings and those
    people gave a damn on correct use of it. I ran into trouble until I
    completely ignored the directions.
    So I'm not  too eager on that, but would be nice to have.
    With auto, there is also some options for live ERC, like the ability to
    detect and show if the net is missing a driver or double driven by
    multiple outputs.
    Finally, I wouldn't mind of the xrefs got split into a new primitive
    called pageconnector, and get an attribute containing ALL the
    references. Also the full list of references should be shown at the
    tooltip on mouseover/hover event.
    I don't know if this is practical. Think  of a little project with 15 to
    20 pages and then select "GND"....perhaps it would be better in kind of
    an info line...
    Finally it should be possible to hook it to a bus too.
    Joern Paschedag
    multiple outputs.
    On 12.05.2016 00:19, Márton Miklós wrote:
    Hello all,
    Bumping again. After ~2 years...
    Is there any information about this feature?
    Is it planned, not planned, if not why, if yes to which version?
    Thanks in advance!
    Miklos Marton
    2014-03-12 08:48 keltezéssel, vidar vidnes írta:
    I think it's time to re-suggest the original request. Also called
    "bumping"
    1) To have the option to change the xref flag direction and shape
               That is: To choose which side the net attaches to the arrow,
    and to choose the shape of the flag (in and out are similar, but bidir
    needs arrow in both ends)
    2) One should be able to choose which data to be inside and which to be
    outside the flag by using the formatting options position relative to %F
    ., (Everything AFTER %F is inside the flag)
               thus having the possibility to have equally sized flags all
    over the schematic and the variable length text outside the flag.
    3) Not so important.
          *Flag fontsize must be able to change
          *Flag minimum/maximum size should be possible to be configured by
    setting number of characters allowed inside flag
          *Text should be centered along the midline of the flag.
          *wire width the flag is drawn width should be editable
    And as the years has passed, I see more and more customer drawings which
    is designed using different tools which have this feature. And to read
    customer drawings where I know the intentional direction by just looking
    at the flag makes things a whole lot more simple. Also when discussing a
    design with someone which is not so skilled in electronics I see how
    much easier it is for them to understand the  designers intention when
    having flags that are pointing out the signals direction.
    Breg
    Vidar
    http://www.element14.com/community/message/106051
    multiple outputs.
    Hello all,
    Thanks in advance!
    Miklos Marton
    "bumping"
    Breg
    Vidar
    multiple outputs.
    Hello all,
    Thanks in advance!
    Miklos Marton
    "bumping"
    Breg
    Vidar
    autodeskguest over 10 years ago in reply to zainka
    Hello all,
    Thanks in advance!
    Miklos Marton
    "bumping"
    Breg
    Vidar
    Hello all,
    Thanks in advance!
    Miklos Marton
    "bumping"
    Breg
    Vidar
    Hello all,
    Thanks in advance!
    Miklos Marton
    "bumping"
    Breg
    Vidar
    autodeskguest over 12 years ago in reply to zainka
    Am 12.03.2014 08:48, schrieb vidar vidnes:
    "bumping"
    Breg
    Vidar
    I repeat here myself just wishing a separate xref-size independent from
    normal text size.
    Joern Paschedag
  • zainka
    zainka over 12 years ago in reply to k.portman
    I think it's time to re-suggest the original request. Also called "bumping"
              That is: To choose which side the net attaches to the arrow, and to choose the shape of the flag (in and out are similar, but bidir needs arrow in both ends)
    2) One should be able to choose which data to be inside and which to be outside the flag by using the formatting options position relative to %F .., (Everything AFTER %F is inside the flag)
              thus having the possibility to have equally sized flags all over the schematic and the variable length text outside the flag.
         *Flag minimum/maximum size should be possible to be configured by setting number of characters allowed inside flag
         *If the feature is carefully implemented, one should be possible to choose from a set of different shaped flags, not only the three mentioned already, and more could be added in the future.
    And as the years has passed, I see more and more customer drawings which is designed using different tools which have this feature. And to read customer drawings where I know the intentional direction by just looking at the flag makes things a whole lot more simple. Also when discussing a design with someone which is not so skilled in electronics I see how much easier it is for them to understand the  designers intention when having flags that are pointing out the signals direction.
    Breg
    Vidar
  • k.portman
    k.portman over 13 years ago in reply to zainka
    In fact, I also wish for hierarchical schematic blocks (HSB) to be
    implemented, but they are longer down on my list than directional flags.
    HSB is also useless, imho, if they do not show the signal directions.
    Thus implementing directional flags is a step towards getting HSB and
    should therefore be on the wish list for all of us. image
    I would like to re-animate the discussion on Xref net labels. Since the
    Xref labels were introduced to Eagle I have been using them, and even
    modifying some older schematic drawings to use them for better visual
    appearance. BUT I have all the time been missing the directional option
    on them, all my signals are not inputs as the Xref arrow direction would
    imply. What I would like to achieve is something like the attached
    drawing (taken from http://www.ti.com/lit/an/slva444/slva444.pdf)
    I hope there would be some comment from Eagle developer side to state if
    this opton is considered for future releases. I would suggest that 3+1
    options is sufficient (iput/output/bidirectional) added with the 4th
    Xref-Off. Don't care for the out-of-arrow label option, but someone
    might need that. Also make the default text size to 0.05 on Xrefs to
    make the arrows align on 0.1" grid. My vote for these features!!!
    Kim
