EAGLE User Support (English) APPCRASH EAGLE 6.4 on WIN 7 64
  • Replies 34 replies
  • Subscribers 195 subscribers
  • Views 5058 views
  • eagle
terje
terje over 13 years ago
Dear the support team at Cadsoft!
I have just purchased and installed Eagle pro shematic and layout package on to my brand new win 7 64 computer.
I'm now trying to design some new components with the library editor but every 3 to 10 minutes the application crashes and the work is lost.
To me it appears that the crash happens randomly. It can happen when I'm resizing the window, moving a element, copy a element, changing the grid. pushing the undo button  etc. etc.
For now the Eagle is useless as this happens too frequently.
The eagle program is installed under C:\eagle
The version is 6.4.0.
What did I do wrong?
Is this a known issue?
Windows crash report:
Problem event name: APPCRASH
Programname: eagle.exe
Programversion: 0.0.0.0
Timestamp for program: 50eaf0df
Error module name: ntdll.dll
Error module version: 6.1.7601.17725
Timestamp on error module: 4ec49b8f
Exeption code: c0000005
Exeption scew: 0002e3be
OS-versjon: 6.1.7601.2.1.0.256.48
ID for national setting: 1044
Additional information 1: 0a9e
Additional information2: 0a9e372d3b4ad19135b953a78882e789
Additional information3: 0a9e
Additional information4: 0a9e372d3b4ad19135b953a78882e789
Best Regards
Terje
  • wardelder
    wardelder over 13 years ago in reply to auspoundy
    I can make 6.4 crash every time by doing the following:
    - Open a board file
    - Hit F1 for the help screen
    - Close the help screen
    - Crash
    Win 7 x64
  • auspoundy
    auspoundy over 13 years ago in reply to autodeskguest
    I'm happy to take process monitor traces and help out if you want !
    autodeskguest over 13 years ago in reply to matriedel
    On 3/14/2013 6:17 PM, Matthias Riedel wrote:
    Hi Jorge
    I also installed version 6.3.0 and I see the same problem.
    The first crash took quite a while until it happened. But after the
    first time it is totally unstable.
    Best regards
    Matthias
    I am using 2 monitors but I think this should be not the cause of the
    problem
    http://www.element14.com/community/message/71997#71997
    Thanks Matthias,
    We're looking into these issues. I'll keep you guys posted.
    Best Regards,
    Jorge Garcia
  • matriedel
    matriedel over 13 years ago in reply to matriedel
    Hi Jorge
    The first crash took quite a while until it happened. But after the first time it is totally unstable.
    Best regards
    Matthias
    I am using 2 monitors but I think this should be not the cause of the problem
  • matriedel
    matriedel over 13 years ago in reply to e14 Contributor
    Hi Jorge
    I see the same chrasing  problem.
    I am using windows 7 64bit
    Best regards
    Matthias
    e14 Contributor over 13 years ago in reply to auspoundy
    On 3/11/2013 4:12 AM, Brett Pound wrote:
    Any feedback so far Jorge?
    http://www.element14.com/community/message/71666#71666/l/re-appcrash-eagle-64-on-win-7-64
    Hi Brett,
    I have tried reproducing it on our Windows 7 machine and was unable to
    reproduce the error. My conclusion now is that it must be a 64-bit
    related issue so I have forwarded my conclusions along with the
    procedure you've provided to Germany so that they can try to recreate
    the bug.
    I will keep you posted, in the process of attempting to recreate the
    crash I stumbled on to a minor bug which I have also reported to the
    developers.
    Best Regards,
    Jorge Garcia
  • auspoundy
    auspoundy over 13 years ago in reply to e14 Contributor
    e14 Contributor over 13 years ago in reply to Krycek
    On 03/01/2013 05:32 AM, Krycek wrote:
    Having followed Brett's instructions my Eagle 6.4.0 will crash the exact same way under Windows 7 64 Bit.
    My Eagle 6.3.0 works fine following the exact same instructions.
    Also I can get the schematic editor in Eagle 6.4.0 by doing the following.
    New schematic
    Add text (I placed "test text" on layer 97 info).
    Right click and select properties on the text.
    Do nothing with the dialog box that pops up, just click ok.
    App crash.
    http://www.element14.com/community/message/71008#71008/l/re-appcrash-eagle-64-on-win-7-64
    Thanks Guys,
    If anyone else can provide a procedure, please do so. I'm collecting as
    much data as I can and I plan to test these in the coming days.
    Best Regards,
    Jorge Garcia
  • Krycek
    Krycek over 13 years ago in reply to auspoundy
    New schematic
    App crash.
  • auspoundy
    Hi Jorge,
    Mine was a simple repro.
    create a new schematic.
    add a resistor or two
    create the board from the schematic
    rearrange parts into board area
    add text item
    write text into it
    place text twice
    press escape twice
    info
    click one of the text items
    change the layer
    click OK
    crash...
    The same issue could be repro-ed on a board that I created with 6.3.0 some months back. Open the project, go to the board, info, click a text item, change from tnames to bnames layer, click OK, bam.
    note, I am running on Windows 8 (x64) not Windows 7.
    I am now back to running 6.3.0 and those steps above are now working as expected, no crash.  I tried uninstalling 6.3 and reinstalling 6.4 and it didn't clear up the issue so I uninstalled 6.4 again and put 6.3 back.
    But, because I'm a troubleshooter at heart, I will be happy to put 6.4.0 back on and capture any info you can use.
