EAGLE User Support (English) Auto-place, or at least "semi-automatic"
  • Replies 12 replies
  • Subscribers 187 subscribers
  • Views 7529 views
In the spirit of the Thanksgiving holiday tomorrow first of all a major
thank-you to Cadsoft for introducing a hierarchical schematic sheet
structure. This will hopefully bring Eagle more into the mainstream and
it was "the" reason why I bought V7 (I was a V4 hold-out).
Since Eagle does not have an auto-place routine and Jorge Garcia said in
another forum that there aren't any really suitable algorithms for that
I have a suggestion for a simpler fix:
When switching to board view for the first time let Eagle scatter the
components the same way they are on the schematic, with multiple pages
in sub-groups. It's ok if that occupies a large area because people will
then be able to concentrate on one stage at a time, drag that over as a
group and arrange the parts as need. Then the next cluster. And so on.
Right now Eagle just plops the parts down in a willy-nilly fashion. It
looks like neat rows but the designators are all mixed up, the ratsnest
is a mess. This lengthens the placement job because one has to search
for many parts.
Also, I strongly suggest to let the "lesser versions" such as Eagle
Standard pre-group clusters outside the board area just to get a grasp
of what belongs together. Right now it refuses with an error message
"objects outside allowed board area". You cannot move one little thing
unless you move it into the board area. You can't even move it back out
if you grabbed the wrong part. Just let people arrange parts outside the
board area wherever they want but without routing permission. That will
uphold the license limitations because they can only route after the
affected parts have been moved inside the board area.
Regards, Joerg
    autodeskguest over 11 years ago in reply to autodeskguest
    On 2014-11-28 22:05:23 +0000, Olin Lathrop said:
    But you never go "finding" components out in the Ort Cloud.  You bring them
    in as necessary to where you are currently working on placement.  When you
    reference a component, it attaches to the mouse cursor.  It doesn't matter
    at all where it was before that.  You don't need to know, in fact don't
    want to know, where it came from.
    That's exactly what I do when placing specific components or
    rearranging things. In fact, this is the fastest way to "find" a
    component in a layout or schematic even if it's been routed since
    Eagle's find function is so anemic.  "mov r3" and it snaps and you can
    see where it came from while zooming out. Escape cancels the move and
    puts the component back where it was.
    You seem to be imagining picking thru the cloud of components looking for
    the right one visually.  That would be very tedious and is not how it's
    done.  Get some experience with Eagle and learn to use it well before
    asking for new features.
    I'm not the original poster, but my experience with Eagle spans more
    than a decade. Eagle needs better grouping and searching. I don't know
    that a semiautomatic placer will be super helpful but the scripting
    function might be able to help considerably since I think all the info
    is there.
    One thing I do is to "pre-place" components by grouping them off-board.
    I tend to do it similar to what you've described, building approximate
    placement subcicuits then grouping and moving the entire lot to their
    destination. A preplacement autoassist wouldn't be a bad thing but
    again, something probably able to be done in a ULP/SCR combo.
    Quote:
    Auto-placement algorithms don't really work with current
    technology.
    I can't find any rational explanation for why you'd state such a thing.
    Higher density components have the same kind of placement requirements
    of your typical passives and simple active components. It's typically
    these smaller components which give the most placement trouble anyway
    since there's so many of them.
    -A.
    warrenbrayshaw wrote:
    On 27/11/2014 2:02 p.m., Joerg wrote:
    .........Also, I strongly suggest to let the "lesser versions" such as
    Eagle
    (1) If you pick up a part and realise it is the wrong part before
    dropping it onto the board simply hit ESC and the move command will be
    cancelled and the part will go back into the heap.
    (2) If you have just dropped it onto the board, Undo (CTL-Z) will put it
    back into the heap. If its a few actions back you can select from the
    undo list and undo everything back to that move that took the part out
    of the heap and then re-do everything after that point manually again.
    Ok, but that method would be rather clunky.
    (3) I created a ULP a while back (for these "lesser versions") that lets
    you remove a single element, automatically placing it below and left
    aligned with the heap. If there is no heap then it is placed left
    aligned with the origin and below it.  It works well but needs a review.
    I'll endeavour to upload it before Christmas(this Christmas) so keep an
    eye out for it.
    Thanks, I will keep an eye out. If it can drop it back outside the board
    that would be great.
    Regards, Joerg
    .........Also, I strongly suggest to let the "lesser versions" such as Eagle
    eye out for it.
    Regards
    Warren
    Olin Lathrop wrote:
    Joerg wrote on Thu, 27 November 2014 13:39
    I don't see any point to this.  The initial placement outside the
    board
    area is irrelevant, so code to arrange it any particular way would
    be a
    waste of effort.
    Not at all, it will make it much easier to find stuff.
    For example, I have F12 in the board editor set up to do "ratsnest; move".
    I hit F12, then enter the component designator, like "R27", and poof, it's
    attached to the mouse cursor.  Where it was before this operation is
    completely irrelevant.  It was just "out there" somewhere.  There is never
    a need to look at the Ort Cloud during placement.  Sometimes when I think
    I'm close to done with placement I'll do a "window" to see if there are any
    stragglers I missed.
    done. ...
    That's how I saw many layouters do it. It was very easy when the SW
    clustered the parts roughly right. Then you could drag a whole section
    over, move individual parts a bit, rotate here and there, and route. No
    need to type in R27, Q34, C159, C112, D38 and hundreds of others.
    I am using Eagle since about 10 years and CAD in general since about 30
    years. Back when layouts were usually done on mainframes.
    Generally I farm out layouts but often sit next to the layouter during
    critical placement and routing. Sometimes I take over for a while. In
    recent times we occasionally did that via online conferencing. You can
    hand off mouse control there.
    technology.
    So why do even lower cost CAD programs such as Diptrace have it and
    people use it?
    Because the world has a large supply of marketing people and gullible
    users.
    I am sure there are layouters who would disagree.
    Quote:
    And that's exactly the problem. You are constantly zooming in and out
    to locate parts, especially if you do not have super-duper monitor
    resolution combined with the eyes of an eagle (the real ones, soaring
    high in the sky and able to spot a mouse a quarter mile below them).
    Again, you need to first learn to use Eagle effectively.  You don't ever
    drag parts from the cloud to the board.  That would be very tedious,
    regardless of how organized the cloud of parts might be.  Using Eagle right
    is quicker, less tedious, and doesn't require and new organization of
    unplaced parts.
    Quote:
    Imagine this process in a cramped coach class seat on a >10h
    international flight where your "work space" is the size of a letter A
    sheet and all you have is a netbook. I had four of those flights over the
    last couple of months.
    Then you especially don't want to do it the way you describe.
    Nope, it's especially where you need it. Because you don't have enough
    screen space and also no other space to display a schematic. Unless you
    can convince your seat neighbor to not watch the movie and tape the
    schematic over his IFE screen. It's hard to do a layout without seeing
    the schematic all the time but I've done it. If you are the designer of
    the circuitry it isn't that tough as long as the parts are grouped
    somewhat together so you don't have to squint and follow air wires much.
                                                        ... A printout
    is still useful because it allows you to cross off parts as they are
    placed, making it easier not to miss any.  But either way, not dragging
    parts from off-board reduces the need for panning and zooming more than any
    organization of the unrouted parts would allow.
    Without a schematic visible all the time that only works if you have
    photographic memory image
    Regards, Joerg
    autodeskguest over 11 years ago in reply to anweid
    Andreas Weidner wrote:
    Am 27.11.2014 19:39, schrieb Joerg:
    You're going to place every component manually anyway.  It doesn't
    matter
    where it comes from outside the board area when you bring it into the
    board
    area to place it.  You would typically be zoomed in to the area of the
    board you are working on, or at least zoomed to just the board if the
    board
    is small.
    Yes, this is EXACTLY how to create a nice layout.
    There is another method to create nice layouts and I've seen that many
    years ago on a large mainframe system (late 80s!). The layout software
    clustered the parts somewhat similar to the schematic. That is much more
    intuitive to many people including me and the layouters at that company
    preferred this method greatly over the command line.
    And that's exactly the problem. You are constantly zooming in and out to
    No, you do NOT need ANY zooming, and you don't need to have good eyes,
    either. But, to make that clearer: Olin is a professional long-term user
    who surely knows EAGLE by heart and, above all, USES THE COMMAND LINE.
    For placing components on board, the command line is absolutely
    gorgeous, and you use it as follows:
    1. Make a printout of your schematics. That's not STRICTLY necessary,
        but - believe it or not - the quality of your routing DEFINITELY
        improves if you have a printout available and do NOT have to
        constantly switch screens between schematics and board. If you use
        TWO monitors (one for the schematics, one for the board), a
        printout is NOT necessary.
    Funny that you mention it, this morning I ordered a new PC and also a
    second 27" monitor with exactly such purposes in mind.
    2. Zoom into a completely EMPTY space where you later want to place
        your components.
    3. Do NOT try to zoom back to where the components actually ARE
        placed right now - just completely ignore their current positions
        (you don't know these positions, anyway).
    4. Do NOT try to move components by trying to find them on screen
        and clicking on them - that's INCREDIBLY difficult and
        time-consuming.
    5. Instead, decide which component you WANT to move by consulting the
        schematics and then TYPE the corresponding command into the board's
        command line. E.g., if you want to move R1, type 'mov r1' (+ENTER),
        and immediately you have the desired component at your mouse tip,
        INDEPENDENT of where it was located previously! You do NOT need to
        search OR zoom OR pan, so you can find and move your components
        approximately twenty times faster than by just using the mouse.
    6. After placing the component where you want it, the MOVE command is
        STILL active, so you don't even need to type it in again, so you
        just type 'N3' and have N3 at your mouse tip for easy placing.
    7. Quite often, do a RATSNEST to improve airwire display.
    8. For even quicker access, create key combinations for the MOVE
        command (e.g. CTRL+M) and RATSNEST.
    Sure you can do that. You could even use the mouse for the move command
    like Olin said. I am used to the command line from the Orcad SDT days.
    Still, not all layouters work that way. Many do not even want the
    keyboard on the desk during placement and routing.
    This is one of the few tasks where a paper printout is still useful.
    After
    finishing the schematic, I print it out and put it on my desk.
    Yes. As already mentioned, this creates the best routing results.
    the last couple of months.
    With the above method, you can easily ignore ANY default positioning of
    components, because you ONLY work with the area where you desired that
    components SHOULD go. You don't have to search and find and click.
    In my opinion, EAGLE's command line is its best feature and certainly
    time-saver no. 1. One just has to overcome the sometimes available
    personal reluctance to use it ('typing? no - we did that with MS-DOS,
    now we want to use the mouse instead').
    I grew up with DOS. Ok, now I've given my age away. Still, when it comes
    to layouts I prefer not to have to use the keyboard much. I don't do
    layouts much but I sometimes take over when very critical RF stuff must
    be placed and routed.
    Regards, Joerg
    board
    be a
    waste of effort.
    technology.
    people use it?
    users.
    unplaced parts.
    Then you especially don't want to do it the way you describe.  A printout
  • anweid
    anweid over 11 years ago in reply to autodeskguest
    Am 28.11.2014 18:25, schrieb Joerg:
    Yes, that's what I meant with "without routing permission". It would be
    perfect. From a code point of view it should be fairly simple for
    Cadsoft. Just warn about or, better yet, delete all routed traces the
    millisecond they are dragged outside the licensed board limit. That
    would allow situations like "Oh, I think I should have done the RF
    section first so lets just scrap all this stuff over here and move it
    back out for now". Then you could even move routed parts back out, with
    the understanding that they'd lose all trace connections.
    Won-der-ful. Let's do it like that. I'll just look into the source
    and... ah, what a pity, I don't HAVE any source. Well, so we probably
    just have to wait...
    Andreas Weidner
  • anweid
    You're going to place every component manually anyway.  It doesn't matter
    where it comes from outside the board area when you bring it into the board
    board you are working on, or at least zoomed to just the board if the board
    is small.
         your components.
         time-consuming.
    This is one of the few tasks where a paper printout is still useful.  After
    Andreas Weidner
    Am 27.11.2014 02:02, schrieb Joerg:
    Since Joerg's idea is a good one, let me elaborate on that a bit more to
    (hopefully) prevent misunderstandings:
    1. YES, it REALLY is a nuisance that, once you moved a part inside the
        routing area, you cannot move it back outside anymore due to the
        size limitations. Especially for limited-sized boards, one often
        wants to try better placements, and this is often quite hard for
        the "non-profit" users who cannot move components back outside.
    That limitation also goes for the not so cheap standard version. I
    bought that because I normally do not do layouts myself but for one
    upcoming project must likely crank out a few small-size 4-layer fast shots.
    2. If CadSoft would let people 'move' everything everywhere, but not
        'route' everywhere, some people would surely place and route a
        small area, move that outside the allowed area, route the next
        small chunk, move it outside, etc. All in all, users could then
        easily create and route large boards, just separated in smaller
        chunks. This is quite probably NOT what CadSoft wants...
    3. Therefore, my own suggestion would be to:
         a) Allow MOVING of UNrouted components (that are NOT connected
            to ANY copper, but just to 'unrouted' signals) everywhere.
         b) Disallow MOVING of ROUTED components (that have at least
            one copper track attached) outside the allowed area.
         c) Disallow ROUTING and WIRING outside the allowed area.
         d) Disallow MOVING of copper tracks or other wires outside
            the allowed area.
        This should take care of (2) and additional tricksters who
        would otherwise do one of the following things:
         - Route copper in a way that the copper overlaps the corresponding
           pads, but is not EXACTLY positioned on top of the pad center, so
           it would be 'unrouted' mathematically, but correctly routed
           mechanically.
         - Use self-defined layers for the copper and not ROUTE tracks,
           but just WIRE them.
        (The above restriction for MOVE would also apply for COPY and
        PASTE)
    The net benefit for non-profit users would be that they could really
    FULLY use the allowed area, including trying differently routed designs,
    which could be ripped up and placed outside the allowed area again.
    Probably this is exactly what Joerg meant, but just to clear things up...
    Regards, Joerg
  • anweid
             the allowed area.
            mechanically.
            but just WIRE them.
         PASTE)
    Andreas Weidner
