EAGLE User Support (English) locking something other then componets in eagle
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 895 views
  • locking eagle
Is there a way to lock track or wires in eagle PCB ?
I have created a new layer and drawn lots of mechanical information. Think of it as a DXF import layer. Can I lock all the positions and information on this layer so that i cannot be selected or moved ?
When I come to use the move (and move group) command it moved component but also my accurately placed DXF.
If I switch this layer off completely it solves the problem, but since the layer is invisible I don't know where to place my components.
The Help command for lock mentions components only.
Any ideas please ???
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14 Contributor
    Nope you aren't missing anything sadly. The only thing you can currently lock is components.
    Best Regards,
    Rachael
    0 e14 Contributor over 10 years ago in reply to rachaelp
    Has anyone found a way of locking polygon pours ? More then often then not when I try to move a track it gets confused and moves the polygon definition- then chaos ensues and frustration levels rise.
    Am I missing something or is there no way to lock the polygon ?
    Hamish
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    Thanks for the suggestion- I may try it.
    This does however seem a very long winded way of doing things. The option of a lock feature would be a wonderful feature that I have come to use extensively in other packages.
  • rachaelp
    I'm with you on this one. You should be able to lock any object not just components. You could then lock particular areas of placement including any routing which is useful in several ways. Additionally any holes etc you've placed based on your imported dxf file should be lockable so you can accurately place anything that has mechanical dependancies and then lock them all down.
    Best Regards,
    Rachael
    Hi Warren,
    That does not work since if I turn the layer off then I can't see were to put my component placements. If it is invisible then you can't see it to know where to place !
    This seems to be a major shortcoming in eagle.
    Hamish
    On 14/06/2016 5:07 p.m., Hamish Dublon wrote:
    .....I have created a new layer and drawn lots of mechanical information. Think of it as a DXF import layer. Can I lock all the positions and information on this layer so that i cannot be selected or moved ?
    If I switch this layer off completely it solves the problem, but since the layer is invisible I don't know where to place my components...........
    Turn off the dxf layer you don't want to move.
    Group the items you wish to move.
    Turn on the dxf layer
    Move group
    HTH
    Warren
    On 14/06/16 06:07, Hamish Dublon wrote:
    I don't think so as it doesn't fit the way that feature was thought of
    when introduced.
    OK, I can see why you'd want to do that.
    Well, when I had a board with specific mechanical constraints, I
    designed those constraints as a library part. It should be possible to
    do a package only, or you could associate a symbol that documents the
    installation that imposes those mechanical constraints. When you place
    that part, not only are all your DXF elements grouped into a single
    object, but that object is a component and can therefore be locked.
