EAGLE User Support (English) Eagle 7.6.0 constantly crashing - what to do?
  • Replies 39 replies
  • Answers 4 answers
  • Subscribers 193 subscribers
  • Views 7269 views
  • 7.6.0
  • crash
  • crashing
  • 7.6
  • mac
tomstorey
tomstorey over 10 years ago
Hi everyone. I'm at a loss as to how to handle this situation.
I'd been using Eagle freeware for about a month flawlessly, but over the last two weeks or so I can barely do more than 5 minutes of work without it crashing and burning (well, not exactly burning.)
Simple things like zooming in and out of a schematic, scrolling in a schematic, or even clicking on a button on a toolbar will cause it to crash. So far I've spent most of my time in the schematic editor, so I'm not 100% sure if it also happens in the PCB editor.
I'm running it on a Mac (10.10), and I was also seeing the same problem with 7.5.0. Rather conveniently 7.6.0 came out not long after I started seeing the crashes with 7.5.0, so I upgraded hoping that might help, but alas, 7.6.0 had the exact same problem.
I tried restarting, I completely deleted the Eagle application folder and re-installed, but neither of those did anything to help. Can anyone suggest anything else?
The first tell-tale signs its about to happen are when I start to see graphical glitches, like that in the attached screenshot. Then, a couple of clicks later, boom - crash. I'm at the stage where I'm constantly saving my work in fear of losing it.
I'm really really liking Eagle, and Ive been considering purcashing a license, but if its going to behave like this, I dunno ....... image
Many thanks.
Tom
  • vintagesynthlab
    0 vintagesynthlab over 10 years ago
    I found that Ken Tyler's suggestion (above) actually worked for me.  While it is a "workaround" solution, I'm finding that after resizing both the schematic and PCB layout windows, I am usually able to start using Eagle CAD normally and with no hang-ups. Fortunately, this has allowed me to continue to be productive!  Thanks, Ken!
  • vintagesynthlab
    0 vintagesynthlab over 10 years ago in reply to autodeskguest
    Hi Jorge,
    I do not have Roboform or Conduit installed.
    I will consider running it under windows, as I do use Parallels for Mac and have a stable ver of Win-7 installed... that is an idea for a medium-term solution until the root cause of the issue is resolved.
    -Eric
  • mrmarple
    0 mrmarple over 10 years ago in reply to doubletop
    doubletop wrote on Tue, 12 July 2016 05:28
    The other thing was all the drop downs were greyed out.
    I had something similar to this today, autorouter was doing "Top" variant
    when I cancelled it, it didn't cancel but ran to completion. All dropdown
    menus greyed out, didn't respond to close button, only way out was to kill
    Eagle.app task in a terminal.
    Tried several times to repeat but it cancelled properly every time.
    Eagle 7.6.0 OSX 10.10.5
  • mrmarple
  • mrmarple
    0 autodeskguest over 10 years ago in reply to vintagesynthlab
    On 8/19/2016 1:52 PM, Eric H wrote:
    I downloaded the 7.6.2 and am still experiencing the crashing.
    Hi Eric,
    I may have asked you this before so I apologize if that's the case. Do
    you have Roboform or conduit installed? These programs are known to
    interfere with EAGLE.
    Another idea, because I know you've been following this issue for a while.
    Try installing the Windows version of EAGLE and running it under
    XQuartz. I know it doesn't feel right but it should at least allow you
    to continue working on your files while we get this sorted out.
    Best Regards,
    Jorge Garcia
    Hi Eric,
    Best Regards,
    Jorge Garcia
    Hi Eric,
    Best Regards,
    Jorge Garcia
  • vintagesynthlab
  • mrmarple
    Eagle 7.6.0 running on a Hac (yes Hac) with OSX 10.10.5 Yosemite and two
    monitors is stable here, no unexpected crashes. I can crash it, I avoid the
    one situation that I know is a problem.
    Starting eagle from the desktop by double clicking on a board icon, it
    might be a downloaded board, or a board not in a project. The board
    opens but a mouse wheel zoom kills Eagle, resize the window before zooming
    and all is fine.
    If do anything unusual in Eagle I quit and restart.
    I turned file locking off early on, what is the intent of this feature?
