EAGLE User Support (English) Consistency errors
  • Replies 36 replies
  • Subscribers 189 subscribers
  • Views 3359 views
Consistency errors
maciv4
maciv4 over 10 years ago
I have 5 consistency errors, on sections of my board that I wired several days ago. One of the errors is on an airwire. Do I have to delete the entire net to find the offending trace. I also have missing airwires; parts with no airwires attached at one end. I also have airwires still in place after I have placed traces, that ratsnest won't clear. I assume that the consistency errors are preventing annotation between the schematic and the board. Can you help?
  • rachaelp
    0 rachaelp over 10 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Fri, 19 August 2016 21:06
    On 20/08/2016 7:32 a.m., rachaelp wrote:
    Hi Jim,
    The EAGLE Central/Element14 link is currently broken.
    Hi Rachael
    Do you know for sure that Element14 has begun mirroring the
    EagleCentral
    mirror of the Cadsoft Eagle forum. If not then it would be the
    Element14
    interaction with the Cadsoft forum that is broken.
    Warren
    Hi Warren,
    You are probably right, I was just using the term mirror for convenience.
    Best Regards,
    Rachael
  • rachaelp
    Hi Jim,
    Hi Rachael
    EagleCentral
    Element14
    Warren
    Hi Warren,
    Best Regards,
    Rachael
  • rachaelp
    Hi Jim,
    Hi Rachael
    EagleCentral
    Element14
    Warren
    Hi Warren,
    Best Regards,
    Rachael
    0 autodeskguest over 10 years ago in reply to maciv4
    Am 19.08.2016 um 19:41 schrieb Jim McAuley:
    I would that, where do I send the files, and which files would you need?
    https://www.element14.com/community/message/203978
    How far is the layout?
    If it is at the beginning one can think about deleting the board and
    generate a new board from the schematics. This method is sometimes
    faster than repairing the single errors if one is not so experimented.
    Joern Paschedag
    Joern Paschedag
    Joern Paschedag
    0 autodeskguest over 10 years ago in reply to rachaelp
    Hi Jim,
    Hi Rachael
    Do you know for sure that Element14 has begun mirroring the EagleCentral
    mirror of the Cadsoft Eagle forum. If not then it would be the Element14
    Warren
    Hi Jim,
    Hi Rachael
    Warren
    Hi Jim,
    Hi Rachael
    Warren
  • rachaelp
    0 rachaelp over 10 years ago in reply to maciv4
    Hi Jim,
    The EAGLE Central/Element14 link is currently broken. Jorge just replied on EAGLE Central so I have copied it below so you see it:
    Hi Jim,
    Send them to support@cadsoftusa.com. Send the .brd and the .sch files.
    I'll send them back once I have corrected them.
    Best Regards,
    Jorge Garcia
    Best Regards,
    Rachael
