EAGLE User Support (English) Consistency errors
  • Replies 36 replies
  • Subscribers 181 subscribers
  • Views 2737 views
Consistency errors
maciv4
maciv4 over 9 years ago
I have 5 consistency errors, on sections of my board that I wired several days ago. One of the errors is on an airwire. Do I have to delete the entire net to find the offending trace. I also have missing airwires; parts with no airwires attached at one end. I also have airwires still in place after I have placed traces, that ratsnest won't clear. I assume that the consistency errors are preventing annotation between the schematic and the board. Can you help?
  • maciv4
    0 maciv4 over 9 years ago in reply to rachaelp
    I now have the following errors:
    Different connections on R48 pin 2 and pad 2 (-12V/$$1)   2
    Different connections on R84 pin 2 and pad 2 (-12V/$$1)   3
    Different connections on U15P pin V- and pad 4 (-12V/$$1)    2
    Different connections on U17P pin V- and pad 4 (-12V/$$1)    3
    Different connections on U20P pin V- and pad 4 (-12V/$$1)    3
    Part R46 has different values in schematic and board (2.61k Ohms/2.61K)
    Part R48 has different values in schematic and board (2.2k Ohms/2.2K)
    Part R84 has different values in schematic and board (2.2k Ohms/2.2K)
    what should I try now?
  • rachaelp
    0 rachaelp over 9 years ago in reply to maciv4
    So I don't think you've done it right. What the first 5 errors are saying
    is that on the schematic the pins of those parts listed are connected  to
    -12V whereas on the board they are not connected to that net. There may be
    a different named net on those pads in the board, I can't tell. So you need
    to totally remove the nets in the schematic that connect to those 5 pins.
    In the board you need to go find the pads and make sure there are no nets
    connecting to them either. If you do that these errors WILL go away. They
    are still there because you still have mismatching things connected to
    the,
    The new 3 errors is because you have added values in the schematic and in
    the board separately and you have a difference in the case i.e. k vs K.
    Best Regards,
    Rachael
  • rachaelp
    0 rachaelp over 9 years ago in reply to rachaelp
    In fact, you also have Ohms in one and not in the other. Both need to be
    EXACTLY the same.
    0 autodeskguest over 9 years ago in reply to maciv4
    | Different connections on R48 pin 2 and pad 2 (-12V/$$1)    |  2 |
    | Different connections on R84 pin 2 and pad 2 (-12V/$$1)    |  3 |
    https://www.element14.com/community/message/203902
    Hello Jim,
    I hope you're doing well. If you can send me the files for review and
    I'll correct them if you wish. In this case you would have to delete the
    nets on both the schematic and the board to get them back to a normal state.
    Here's how you could make sure you are not burying yourself deeper into
    a hole. In the schematic delete the -12V net from R48 pin 2. Now go to
    the board and delete the $$1 trace from pad two of resistor R48. Now run
    the ERC. You should have 1 less error. Rinse and repeat to get of the rest.
    The different values error can be corrected by running the
    make-value-consistent.ulp in the editor that contains the values you
    want on both the schematic and the board.
    Remember to constantly run the ERC to make sure you are making progress
    and not going backwards.
    hth,
    Jorge Garcia
  • maciv4
    0 maciv4 over 9 years ago in reply to autodeskguest
    I deleted the source on the schematic as directed then went to the board and deleted the trace. Consistency  error is still there and now I have a warning about unconnected pin on R48.
  • maciv4
    0 maciv4 over 9 years ago in reply to maciv4
    I reconnected the -12V source to R48 and reconnected the trace on the board. Warning is gone error remains.
  • rachaelp
    Hi Jim,
    The warning was fine and to be expected as you had deliberately
    disconnected the pin.
    Was the error message exactly the same after you deleted the net?
    I suspect there was some net remaining connected to the pin which retained
    the net name. You need to remove the net that connects directly to the pins
    in the schematic. If you do this correctly the errors WILL go away.
    As Jorge says, it's often safer to try one at a time, running ERC after
    every change. With the limited number and type of errors you had I wasn't
    worried about things being made worse by doing it all at once but as a
    matter of good practice Jorge is right on that front so do the changes one
    at a time, running ERC after every change to verify.
    If you are still having issues then please include screen shots of the
    sections of the schematic / board so we can see what's going on as well as
    the exact wording of the very latest messages.
    Best Regards,
    Rachael
  • rachaelp
    Hi Jim,
    Best Regards,
    Rachael
  • rachaelp
    Hi Jim,
    Best Regards,
    Rachael
  • rachaelp
    Hi Jim,
    The warning was fine and to be expected as you had deliberately disconnected the pin.
    I suspect there was some net remaining connected to the pin which retained the net name. You need to remove the net that connects directly to the pins in the schematic. If you do this the errors WILL go away.
    As Jorge says, it's often safer to try one at a time, running ERC after every change. With the limited number and type of errors you had I wasn't worried about things being made worse by doing it all at once but as a matter of good practice Jorge is right on that front so do the changes one at a time, running ERC after every change to verify.
    If you are still having issues then please include screen shots of the sections of the schematic / board so we can see what's going on as well as the exact wording of the very latest messages.
    Best Regards,
    Rachael
