EAGLE User Support (English) Consistency errors
  • Replies 36 replies
  • Subscribers 181 subscribers
  • Views 2739 views
Consistency errors
maciv4
maciv4 over 9 years ago
I have 5 consistency errors, on sections of my board that I wired several days ago. One of the errors is on an airwire. Do I have to delete the entire net to find the offending trace. I also have missing airwires; parts with no airwires attached at one end. I also have airwires still in place after I have placed traces, that ratsnest won't clear. I assume that the consistency errors are preventing annotation between the schematic and the board. Can you help?
  • maciv4
    0 maciv4 over 9 years ago in reply to rachaelp
    I managed to get two of the errors cleared. R48 and R84 both were completely isolated and the error went away. As soon as I tried to reconnect the two parts the errors came back.  I gave up and went home for the night. I tried again this afternoon and connected both parts. One of the parts has no error, but now I get a warning that one of the pads, on each parts I have connected, is not connected, even though I have now connected both pads on both parts.
    I still have problems with the other three pins. If I try to delete any part of the -12V node, I loose the entire node for almost half the board. Reconnecting to U15.4 doesn't seem to be recognized by eagle at all.
    I have other projects that I need to work on the rest of the week, I will try again next week and see if I have any luck then.
  • rachaelp
    0 rachaelp over 9 years ago in reply to maciv4
    Hi Jim,
    Unless there is a really good reason not to do so, like needing an NDA or there being a security clearance issue relating to your project, your quickest route to getting this resolved would probably be to send the design files to Jorge at CADSoft. It's the sort of issue he should be able to fix quite quickly and it seems you spent quite a lot of time on this already.
    Best Regards,
    Rachael
  • maciv4
    I would that, where do I send the files, and which files would you need?
    0 autodeskguest over 9 years ago in reply to maciv4
    https://www.element14.com/community/message/203978
    Hi Jim,
    Send them to support@cadsoftusa.com. Send the .brd and the .sch files.
    I'll send them back once I have corrected them.
    Best Regards,
    Jorge Garcia
    Hi Jim,
    Best Regards,
    Jorge Garcia
    Hi Jim,
    Best Regards,
    Jorge Garcia
  • rachaelp
    Hi Jim,
    The EAGLE Central/Element14 link is currently broken. Jorge just replied on EAGLE Central so I have copied it below so you see it:
    Hi Jim,
    Best Regards,
    Jorge Garcia
    Best Regards,
    Rachael
    0 autodeskguest over 9 years ago in reply to rachaelp
    On 20/08/2016 7:32 a.m., rachaelp wrote:
    Hi Jim,
    Hi Rachael
    Do you know for sure that Element14 has begun mirroring the EagleCentral
    mirror of the Cadsoft Eagle forum. If not then it would be the Element14
    interaction with the Cadsoft forum that is broken.
    Warren
    Hi Jim,
    Hi Rachael
    Warren
    Hi Jim,
    Hi Rachael
    Warren
