EAGLE User Support (English) Eagle: How to convert a 2 layer board to 4 layer?
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 9455 views
  • eagle cad
  • 4-layers
dlchambers
dlchambers over 9 years ago
I have a 2 layer design in Eagle 7.7.0
I want to convert it to 4 layer - basically insert 2 inner layers (power, ground).
Can this be done, and if so, how is it done?
-Dave
    0 autodeskguest over 9 years ago in reply to dlchambers
    On 10/23/2016 10:57 AM, Dave Chambers wrote:
    the Element14 web interface interprets the asterisks in newsgroup
    postings as "change to bold"
    Yes, that would explain it - I've noticed the bold/italics and was
    puzzled by them. So all along you've been saying "1 star 1 star 15
    star 16" ?
    For Sunstone (prepreg - core - prepreg), I'd use "1 plus 2 star 15 plus
    16", which is exactly what
    you surmised.
    For Advanced circuits (core - prepreg - core), "1 star 2 plus 15 star
    16" is correct.
    As Jorge pointed out, if you're using through vias it's mostly
    irrelevant. And unless you have real need to use blind or buried vias,
    through vias are what you want to use.
  • dlchambers
    0 dlchambers over 9 years ago in reply to autodeskguest
    > the Element14 web interface interprets the asterisks in newsgroup postings as "change to bold"
    Yes, that would explain it - I've noticed the bold/italics and was puzzled by them.
    So all along you've been saying "1 star 1 star 15 star 16" ?
    0 autodeskguest over 9 years ago in reply to autodeskguest
    On 10/22/2016 10:50 PM, Reece R. Pollack wrote:
    On 10/22/2016 02:32 PM, Dave Chambers wrote:
    "(12*1516)"  (w/o quotes) is not a valid setup string. Eagle
    complains that layer 1516 is an invalid layer. Need some sort of
    separator between each number.
    I'm using Sunstone, which has core between 2 and 15, then prepreg
    between 1&2 and 15&16 So, for the simplest stack-up, that would be
    (12*1516) That isn't really what I initially was looking for, but
    as @JorgeGarcia said, Eagle will automatically connect the layers, so
    take that as an answer.
    I'm confused. I don't see any difference between what I wrote and what
    you say works. Both read "(12*1516)" on my screen and is exactly what
    I've used with Eagle versions 6 and 7 (w/o the quotes, of course) for
    production by PCB Pool.
    If you want through vias that connect to all layers, this works just
    fine. It's when you get into blind and buried vias that only connect
    certain layers that things get interesting and the Eagle layer setup
    really becomes critical.
    I suspect the problem is the Element14 web interface. It interprets the
    asterisks in newsgroup postings as "change to bold" indicators and
    doesn't show them. The EagleCentral.ca web interface shows the posts
    properly.
    Is the Element14 web interface going to go away now that Farnell sold
    CadSoft to Autodesk? Please?
  • omega-5
    0 omega-5 over 9 years ago in reply to dlchambers
    Am 22.10.2016 um 20:32 schrieb Dave Chambers:
    Eagle complains that layer 1516 is an invalid layer. Need some sort of separator between each number.
    I'm using Sunstone, which has core between 2 and 15, then prepreg between 1&2 and 15&16
    So, for the simplest stack-up, that would be (12*1516)
    That isn't really what I initially was looking for, but as @JorgeGarcia said, Eagle will automatically connect the layers, so take that as an answer.
    Thanks to all for their input & patience.
    https://www.element14.com/community/message/207869
    Hi Dave,
    what do you think about this? ((12)*(1516))
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • dlchambers
    So, for the simplest stack-up, that would be (1+2*15+16)
    On 10/21/2016 03:25 PM, Dave Chambers wrote:
    Excellent info - thanks.
    So then which setup is the "standard" 4-layer rule:
    (12)+(1516)     (2 cores with prepreg in between)
    or
    (12)(15+16)  (3 cores)
    The stack-up depends entirely on who is making the boards, and whether
    you're looking for a quick-turn prototype or making a large production run.
    Advanced Circuits advertises their quick-turn 0.062" 4-layer board as
    being two cores with prepreg between them. Without blind/buried vias
    this is properly entered as "(12+1516)".
    However, AP Circuits, Sunstone, PCB-Pool, and OshPark stack-ups are one
    core with prepreg layers added to either side. Without blind/buried
    vias, this is properly entered as "(12*1516)".
    If you're not doing blind or buried vias it doesn't make much difference
    which way you enter the stack-up into Eagle. If you ARE doing
    blind/buried, the pluses, asterisks, and extra parentheses tell Eagle
    where you can and can't place vias between the various layers.
  • dlchambers
    (1*2)+(15*16)     (2 cores with prepreg in between)
    or
    (1+2)+(15+16)  (3 cores)
    -Dave
    On 10/21/2016 12:28 PM, Dave Chambers wrote:
    OK, that helps a bit.
    played with the layer setup editor, and I understand what "*" and "+" mean, but the ascending rule is a bit odd.
    I want to be able to connect 1 and 2, 1 and 3, 1 and 4. No need to connect 2 or 3 or 4 to each other.
    How do I specify that?
    https://www.element14.com/community/message/207844
    Hi Dave,
    It is important to understand that you likely don't need to have to many
    different via configurations. The default through hole via, can reach
    all the layers. EAGLE will automatically isolate the via from any layers
    it is not supposed to connect to.
    Using blind and buried vias increases the cost of the board
    substantially. So unless you have a super tight layout I would
    discourage their use.
    hth,
    Jorge Garcia
  • dlchambers
