EAGLE User Support (English) Selecting objects in dense areas (Eagle 8)
  • Subscribers 187 subscribers
  • Views 1290 views
  • eagle 8
isaacws
isaacws over 9 years ago
In previous versions of Eagle, when selecting objects with other objects close by, you would be prompted: "Select highlighted object? (left=yes, right=next, ESC=cancel)".
I'm no longer getting this even if the origin of the object is right over another origin.  Was this feature changed or disabled?  It is still described in the help docs.
    0 autodeskguest over 9 years ago in reply to autodeskguest
    On 06.03.2017 18:11, Jorge Garcia wrote:
    On 3/3/2017 12:59 PM, Klaus Schmidinger wrote:
    Just curious: what's the benefit of breaking such a basic method of
    operation?
    Cycling through a densely populated area with the right mouse button
    used to be doable
    with one hand. Now it requires two hands! Is that Autodesk's idea of
    "improvement"?
    Is there at least a switch that allows the user to fall back to the
    original method?
    Nice to hear from you again. First off, this is an alternative group paradigm, and you can get the old behavior back by going to Options > Set > Misc Tab uncheck the group default on option.
    Thanks for the info. The most important thing here is that it can be
    disabled and one can get back the original behavior - assuming they
    didn't break anything in the process ;-).
    For me personally it doesn't really matter, because V7 will probably
    work just fine for anything I'll ever do, and I wouldn't even touch a
    subscription license with a ten foot pole...
    Klaus
    0 autodeskguest over 9 years ago in reply to geralds
    On 3/3/2017 4:11 PM, Gerald Schwarz wrote:
    Hi Jorge,
    hm..., if i holding down the alt key and press left mouse button, there is no actions as you mentioned.
    the alt key not works?
    if the group is active, an i klick though to the selected parts there comes on a rubber band and after an double klick
    the selected will be highlighted.
    with alt key or without i get the same result.
    hm.... the "clicking turn around" seem a little bit tricky. Or I misunderstood  something.
    Best Regards,
    Gerald
    https://www.element14.com/community/message/217439
    Hi Gerald,
    If you are used to the old way of working with EAGLE you can get it back
    following the directions I gave Klaus.
    For the new behavior try this hold the alt key and then left-click where
    ever you have the multiple items overlapping (my assumption here is that
    you are using the group command).
    Just left click a whole bunch of times while holding down the Alt key
    and you should see it cycle.
    Best Regards,
    Jorge Garcia
    We have a new forum here <http://forums.autodesk.com>
    operation?
    used to be doable
    "improvement"?
    original method?
    And what does "This assumes the group command is active" mean? Does this
    not work if
    the group command is not active?
    Klaus
    Hi Klaus,
    Basically under this paradigm the GROUP command behaves like a select
    tool in photoshop or similar graphical programs. The idea is that this
    behavior for many new users will seem more natural and will lower the
    learning curve to get up to speed with EAGLE. Following this paradigm,
    if no other command is active then GROUP is active, it has quite a few
    other changes to it. For example, if you have a group defined and hit
    the delete key on the keyboard those objects will be deleted. Also if
    you have group defined if you left-click and hold you can immediately
    move the group. There's a few more updates which as you know you can
    check in the Update file.
    Best Regards,
    Jorge Garcia
  • geralds
    0 geralds over 9 years ago in reply to autodeskguest
    Hi Jorge,
    Best Regards,
    Gerald
    Hello Isaac,
    In the latest versions of EAGLE this feature has been modified. Do perform a cycle selection, hold down the alt key and left click to cycle through the various nearby items. This assumes the group command is active.
    Just curious: what's the benefit of breaking such a basic method of operation?
    Cycling through a densely populated area with the right mouse button used to be doable
    with one hand. Now it requires two hands! Is that Autodesk's idea of "improvement"?
    Is there at least a switch that allows the user to fall back to the original method?
    And what does "This assumes the group command is active" mean? Does this not work if
    Klaus
    https://www.element14.com/community/message/217309
    Hello Isaac,
    Best Regards,
    Jorge Garcia
