EAGLE User Support (English) How do I realign a component/dimension in eagle?
  • Subscribers 189 subscribers
  • Views 2028 views
  • eagle 8
  • autodesk eagle pcb design software
  • pcb board design
rishabhsharma9393
rishabhsharma9393 over 9 years ago
I need to realign a board dimension that I imported through a DXF file. It is not straight, can i realign it to be straight? Please see the attached image.
    0 autodeskguest over 9 years ago in reply to dukepro
    On 27/07/2017 12:50 a.m., Chuck Huber wrote:
    Rishab,
    What Warren writes will get you there.  However, there is an easier and
    more exact method to accomplish this goal.
    Right-click on the wire in question to bring up the context menu, then
    select Properties.
    If the line is not a straight line, then the Curve property will be
    displayed.  Set it to 0 to straighten it out.
    Since you're referring to a board dimension, you probably also want to
    make sure that the line is either exactly vertical or exactly horizontal.
    Near the top of the dialog box are From and To properties that represent
    the start and end points of the line.  Each point is defined using
    Cartesian coordinates with an X-value and a Y-value.  (The X and Y are
    not labeled.)
    If the line is to be horizontal, then set both of the Y-values of the to
    the same value.
    If the line is to be vertical, then set both of the X-values to the same
    value.
    Click "Ok" and you're done.
    Chuck's method is flawed. It will make the bottom line level but the
    rest of the object will not have been rotated so the object as a whole
    is not the shape you started with.
    There are other considerations as well.
    The ends of the wire in question will likely not end at the same points
    as the arcs so the board outline is not continuous which may cause it to
    be rejected by the boardhouse.
    HTH
    Waren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Rishab,
    select Properties.
    not labeled.)
    the same value.
    value.
    HTH
    Waren
    Thunderbird!
    support forums.
  • dukepro
    0 dukepro over 9 years ago in reply to autodeskguest
    Rishab,
    select Properties.
    not labeled.)
    the same value.
    value.
    HTH,
        - Chuck
    the attached image.
    https://www.element14.com/community/message/225887
    Hi
    There is a manually way but you have to eyeball it level and its not
    that simple. The following give you more control
    As the shape needs to rotated, you first need to find out many degrees
    to rotate it.
    Click the 'Information' icon and then click on the straight line along
    the bottom.
    In the information box that appears you can read the angle of that
    line which is likely to be about 355.55 degrees
    Subtract this from 360 degrees and that's your rotation angle.
    Rotation will be anticlockwise for positive numbers.
    Next, turn off all layers except the dimension layer so you don't
    rotate something else in error.
    Click the Group icon an draw the rectangle around the shape.
    Click the 'Rotate' icon  and observe in the toolbar the 'Angle' is 90
    Type in your calculated angle and hit enter.
    Then, apply the rotation to the group and it will rotate it to where
    you need it.
    Now it may not be exactly horizontal due to rounding errors in the
    angle. Verify this by observing the information of that wire as you
    did at the start.
    HTH
    Warren
    2313.att1.html.zip
  • rishabhsharma9393
    0 rishabhsharma9393 over 9 years ago in reply to autodeskguest
    Thank you so much. It worked!
  • geralds
    0 geralds over 9 years ago
    The best way is to create your board in Eagle.
    Then you have your correct grid also dimension.
    DXF importing, i do it just for image logos, images that are not under strict component behavior.
    And its a lot faster if you create it with Eagle.
    -> if you must import the dimension shape you can create a new layer "shape" then you can
    import it to this layer and then you can draw your board on the "dimension" layer along your
    shape. After that you can easily correcting if something was wrong on the dimension layer.
    Gerald
    Hi
    to rotate it.
    the bottom.
    In the information box that appears you can read the angle of that line
    Next, turn off all layers except the dimension layer so you don't rotate
    Then, apply the rotation to the group and it will rotate it to where you
    need it.
    angle. Verify this by observing the information of that wire as you did
    at the start.
    HTH
    Warren
    Thunderbird!
    support forums.
