EAGLE User Support (English) Move Part / Device to Other Layer (Bottom)
  • Replies 12 replies
  • Views 5575 views
phased
phased over 8 years ago
I have been working on a PCB design which is intended to use an edge card connector. I first created a package / symbol / device which represented this connector as having copper (fingers) on both the top and bottom layers. However, when attempting to export the routing files to a manufacturing house, I got a failure message with errors such as: Your project doesn't contain a bottom copper file and Your project doesn't contain a bottom solder mask.
So this made me realize that, even though I created the package to have copper on both Top and Bottom layers, the board layout kept both sets of copper on the Top layer.
After this, I attempted to create a device which had only one set of fingers so I could put device on the Top layer and another on the Bottom layer. However, apparently Eagle will not allow me to put a device on the Bottom layer.
Can anyone tell me if there is something special I need to do to accomplish this or if I am going about the process of adding edge connector fingers to a board incorrectly and how I may do it differently?
Thank you very much in advance!
Troy.
  • phased
    0 phased over 8 years ago in reply to autodeskguest
    Hello Paul,
    Thank you very much for your reply. I was able to mirror the part I was having trouble with after moving it to an area of the board that allowed for it to not go 'out of bounds'.
    I appreciate your help!
    Troy.
    0 autodeskguest over 8 years ago
    You have set up your board to have a top and a bottom layer in DRC?
    Lorenz
    Lorenz
    Lorenz
    0 autodeskguest over 8 years ago in reply to phased
    On 03/23/2018 02:08 PM, Troy Whipple wrote:
    Some objects extend outside the allowed board area. Just for reference, my device is only about .9 inch wide by about .2 inches long and my board is about 1 inch wide by 3 inches long.
    Seems like the origin of the part is such that when mirrored it extends
    out of bounds.
    Paul R.
  • phased
    Hi Werner,
    Thanks for the follow up. My version of Eagle is 8.3.2. And, yes I can do a mirror on another device on the board. I should mention that when I tried to do the mirror on the device that it did not recognize before, I got an alert saying the free version of Eagle can't perform the requested action. Some objects extend outside the allowed board area. Just for reference, my device is only about .9 inch wide by about .2 inches long and my board is about 1 inch wide by 3 inches long.
    Any help is appreciated.
    Troy.
    Am 23.03.2018 um 13:52 schrieb Troy Whipple:
    Hello Werner,
    Thanks for your reply! Unfortunately, when I attempt to use the mirror function on this, Eagle does not recognize the device as an object it can mirror. Eagle does recognize the device when I use the move function so I find this strange.
    Of course, I have attempted to move the device to another layer but that does not work. I am open to any suggestions.
    Hello Troy,
    some Questions:
    Eagle Versiom?
    Can you try a "mirror" on an other device on the Board?
    Its only for testing to look is the issue in eagle or the device.
    Werner
    Hello Werner,
    Hello Troy,
    some Questions:
    Eagle Versiom?
    Werner
  • phased
    Hello Werner,
    Am 22.03.2018 um 17:30 schrieb Troy Whipple:
    Troy.
    https://www.element14.com/community/message/237262
    use the "Mirror" command to put a device from
    top-layer to bottom-layer(or back)
    This will switch the layers of the device
    1,21,23,25,27,29,31,33,35,37,39,41 to
    2,22,24,26,28,30,32,34,36,38,40,42
    HTH
    Werner
