EAGLE User Support (English) Two components behave like one
  • Views 725 views
jan89
jan89 over 8 years ago
I created a schematic in Eagle using 6 pairs of PCIE slots (12 PCIE slots total). After neting them together and creating a board file from the schematic I discovered that each pair of the PCIE slots is treated in the board layout as one (I see only 6 slots in the board editor and they have doubled routes connected to them). When I try to rename one of the shots the second one from the pair gets the same name attached immediately. This messes the routing in the bord editor up. How can I rename the slots so that every single one will be treated individually and not as a pair?
Jan
  • rachaelp
    0 rachaelp over 8 years ago
    Hi Jan,
    I suspect the PCIE connector library part you are using has the connector defined such that it has two symbols per connector, i.e. one symbol per each side of the connector. When you place 12 connector symbols in your board you are in fact placing the two halves of 6 connectors. You will be able to tell this because pairs of symbols will have matching reference designators, maybe something like J1A, J1B, J2A, J2B, etc. So you've got half the connectors you think you have.
    Now, it could be a case that the reason this has happened is due to the way the symbol is drawn making it look like it should be a single symbol per part so thoroughly check the library part you've used. As Warren says, the easiest way for us to give you a definitive answer is to zip up your scb/brd files and share them here.
    Best Regards,
    Rachael
    0 autodeskguest over 8 years ago
    On 20/06/2018 9:41 p.m., Jan Kowalski wrote:
    Jan
    https://www.element14.com/community/message/241198
    Hi Jan
    Something has gone wrong and Eagle may not be innocent.
    As the behaviour seems totally abnormal, there is no standard fix.
    It normally pays to quote the version of eagle you are using as some=20
    versions should be avoided and readers can let you know if this is so.
    Additionally, mention where the library part you are using came from.=20
    Did it come with Eagle or did it come from elsewhere or did you create=20
    it? It all helps
    The fastest way to get an answer is to zip up the schematic/board and=20
    attach it here.
    Personally I would be looking at the XML of the board, locate the six=20
    pairs of sockets and verifying if the tags/elements are formed correctly
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Jan
    Hi Jan
    it? It all helps
    attach it here.
    HTH
    Warren
    Thunderbird!
