EAGLE User Support (English) Pin with no pad
  • Subscribers 179 subscribers
  • Views 291 views
Pin with no pad
I will try phrasing my earlier question about off board connections
differently.
Is there a way to define a device that has pins with no corresponding pads?
I have several panel switches that connect to a board through a multipin
connector. I want to show the connectivity of the switch to the
connector in the schematic, but I do not want pads to be generated for
the switch.
  • WestfW
    WestfW over 17 years ago
    the switch.
    Just design the "package" to be your multi-pin connector instead of the
    actual switch footprint.  I've got a lot of packages like that for
    things like batteries, speakers, switches, flash tubes.  They all look
    like two pins with 0.1inch spacing...
    Alternately, leave the package outside the board area and don't connect
    to it when you design the board...
    BillW
    Ultimately I decided to go with putting the off board devices into a
    dummy board area. I do not like this. I think it looks tacky and
    unprofessional, but that seemed to be the best option for me.
    Maybe Eagle will take note of this and and provide some way to not
    require a pin to have a pad. Maybe make a hidden pad option that does
    not generate a line in the rats nest.
    Bill Westfield wrote:
    pads?
    multipin connector. I want to show the connectivity of the switch to
    the connector in the schematic, but I do not want pads to be generated
    for the switch.
    BillW
  • esilviu
    esilviu over 17 years ago
    why not you use a bus for those wires?
    or place net names on the wires. look in library "frames"- maybe you could
    use something from there
    "DB" <javaguy11111@yahoo.com> wrote in message
    news:fng93f$ruv$1@cheetah.cadsoft.de...
    differently.
    pads?
    connector. I want to show the connectivity of the switch to the connector
    in the schematic, but I do not want pads to be generated for the switch.
