EAGLE User Support (English) Vista- files missing when searched for.
  • Subscribers 178 subscribers
  • Views 530 views
I just installed EAGLE on a Windows Vista Home Premium laptop.
I can create projects and schematics, boards, and gerber plots. However,
when I try to find them in explorer, they are gone. I open eagle and they
are there.
Also, any library files I create are there for editing. I then go to
Libraries - Use to add them. The operation appears to complete, but when I
try to use them, to add the parts to the schematic, they are not .in the
list. I can find the libraries in EAGLE, but they will not load as active.
I did find an answer to the help files not working. It works on my machine:
"Thank you for contacting Microsoft Customer Service.
I understand that you would like to know which WinHlp32.exe file you should
download.
I would like to inform you that x86 or x64 are platform for Windows Vista.
To find out the platform of the Windows Vista, please perform the following
steps:
- Click on "Start"
- Type in "System" in the Start Search box
- Click on System Information in the Programs list
- The "System type" option has the platform you are using
Jeffrey, for more information about finding the platform please visit the
article "How to determine whether your computer is running a 32-bit version
or a 64-bit version of the Windows operating system":
http://support.microsoft.com/kb/827218
After you determine the platform you are using, you may download the
appropriate WinHlp32.exe file from the web link below:
http://www.microsoft.com/downloads/details.aspx?FamilyId=6EBCFAD9-D3F5-4365-8070-334CD175D4BB&displaylang=en
    Jeffrey Moore wrote:
    they are there.
    I try to use them, to add the parts to the schematic, they are not .in
    the list. I can find the libraries in EAGLE, but they will not load as
    active.
    should download.
    Vista. To find out the platform of the Windows Vista, please perform the
    following steps:
    - Click on "Start"
    the article "How to determine whether your computer is running a 32-bit
    version or a 64-bit version of the Windows operating system":
    I don't use Vista, but I wonder if Vista "thinks" your files are somehow
          special and has hidden them?  Try displaying hidden files and
    see waht happens.
    HTH
    -Dave Pollum
    they are there.
    active.
    should download.
    following steps:
    - Click on "Start"
    Vista is very protective of the Program Files directory. You're not
    supposed to store data there, such as your Projects directory.
    Your projects are most likely under 'Users\your_name\'. Use the Search
    to look for them, but be sure to choose the Advanced search, and Search
    the entire drive. Otherwise they will be missed. You may have to add the
    paths to your Options->Directories window just off the opening screen.
    Jack Butler
    "Jack" <jb46nospam@woh.rr.com> wrote in message
    news:fpka49$fu1$1@cheetah.cadsoft.de...
    are there.
    active.
    machine:
    should download.
    following steps:
    - Click on "Start"
    http://www.microsoft.com/downloads/details.aspx?FamilyId=6EBCFAD9-D3F5-4365-8070-334CD175D4BB&displaylang=en "
    Your projects are most likely under 'Users\your_name\'. Use the Search to
    look for them, but be sure to choose the Advanced search, and Search the
    entire drive. Otherwise they will be missed. You may have to add the paths
    Jack Butler
    You got it!  I will try changing the paths to be specific instead of
    "$EAGLEDIR\
    Tried:   c:\program files\eagle-rev\ for all directory settings. Still saves
    any
    and all new files in the 'Users\your_name\VirtualStore\Program Files\
    eagle-rev directory.
    Will try various configurations and get back to you.
    Jeffrey Moore
    However, when I try to find them in explorer, they are gone. I open
    eagle and they are there.
    when I try to use them, to add the parts to the schematic, they are
    not .in the list. I can find the libraries in EAGLE, but they will
    not load as active.
    machine:
    should download.
    the following steps:
    - Click on "Start"
    32-bit version or a 64-bit version of the Windows operating system":
    Search the entire drive. Otherwise they will be missed. You may have
    to add the paths to your Options->Directories window just off the
    opening screen.
    Jack Butler
    "$EAGLEDIR\
    saves any
    Jeffrey Moore
    Jeffrey...
    I wasn't at my Vista machine when I wrote the last message - this time I am.
    On my installation, the CAM, DOC, DRU, LBR, ULP, SCR directories are in
    the Program Files directory (not a good idea, but DOC is probably OK).
    Eaglerc.usr.beta is in C:\Users\your_name\AppData\Roaming\CadSoft\Eagle.
      The project files are in C:\Users\your_name\Documents\Eagle\Project.
    This last location requires that you add '$HOME\EAGLE' to your
    Options->Directories pop-up in Eagle (in the Project window).
    The problem with having libraries, scripts etc. in the Program Files
    directory is that Vista will refuse to download new libs or ulps etc.
    from the CadSoft website (or anywhere else for that matter). On-line or
    network access to Program Files is forbidden. The only way to get them
    downloaded is to make the download to another directory (I use
    'doctemp') and then copy or move them to the Program Files directory.
    Just a little added fuss.
    I'm going to try to move all of the auxiliary directories to the same
    location under Users with the Projects. Should work (I hope).
    HTH,
    Jack Butler
    not load as active.
    machine:
    should download.
    - Click on "Start"
    visit the article "How to determine whether your computer is running
    a 32-bit version or a 64-bit version of the Windows operating system":
    Search to look for them, but be sure to choose the Advanced search,
    and Search the entire drive. Otherwise they will be missed. You may
    have to add the paths to your Options->Directories window just off
    the opening screen.
    Jack Butler
    "$EAGLEDIR\
    saves any
    Jeffrey Moore
    Jeffrey...
    am.
    HTH,
    Jack Butler
    OOPS!!! I just realized that I gave locations for the Beta version of
    Eagle. I don't have 4.16r2 installed on the Vista machine. (I'm
    currently moving everything from an 8 yr old laptop to a new one.)
    I think the file locations above should still be basically correct as
    the Beta version hasn't really changed the file access behavior from
    4.16. The big changes are in Vista's file structure.
    Ignore the location for eaglere.usr.beta. You won't have that file.
    Jack Butler
    news:fpo72c$576$1@cheetah.cadsoft.de...
    when I try to use them, to add the parts to the schematic, they are not
    .in the list. I can find the libraries in EAGLE, but they will not load
    as active.
    machine:
    should download.
    - Click on "Start"
    Jack Butler
    "$EAGLEDIR\
    saves any
    Jeffrey Moore
    Jeffrey...
    am.
    The project files are in C:\Users\your_name\Documents\Eagle\Project. This
    directory is that Vista will refuse to download new libs or ulps etc. from
    the CadSoft website (or anywhere else for that matter). On-line or network
    access to Program Files is forbidden. The only way to get them downloaded
    is to make the download to another directory (I use 'doctemp') and then
    copy or move them to the Program Files directory. Just a little added
    fuss.
    HTH,
    Jack Butler
    Got it figured out. EAGLE runs fine as is.
    1. However, all modified files are stored in:
    "C:\Users\Jeff\AppData\Local\VirtualStore\Program Files\EAGLE-rev\"
    I can get at them there, but what a hassle.
    2.Another way to get EAGLE to work in the usal way is to give it admin
    rights.
    Right click on the exe file in "c:\Program Files\EAGLE-rev\bin\eagle.exe"
    and select "Run as administrator." Still a hassle.
    3. This is great! Permanent admin rights and can be started from the usual
    desktop icon or start menu.
    and select Properties, then the security tab, then edit and accept the
    anoying dialog box if it pops up, last click on Users (computer name\users)
    check the full control box and the apply button. Exit out and viola, the
    program runs as it always did in previous Windows Versions.
    I know, it is not advised to run it this way, but I am used to EAGLE
    running as it was designed.
    Hope this is useful to others.
    Jeffrey Moore
