Can anyone tell me how to apply thermals to isolated vias connecting ground
planes? I don't want to turn on "Generate thermals for vias" option in the
DRC. Thanks.
DRC. Thanks.
Hello Leo B !:
planes?
You can use some restricts and ignore some errors. Unfortunately all
wires you should create manually. With small clearance you can use some
arcs in restrict layer.
Really the option "thermals" for polygons is quite stupid because the
general option for vias overwerites it ... only pads are affected.
DRC.
Why ????? This is IMHO best way to create good boards.
regards
Grzegorz Zalot
complex ltd.
office tel/fax : +48 32 2505840
mobil : +48 501 301515
"Grzegorz Zalot" <complex@alpha.pl> schrieb im Newsbeitrag
news:g2l6bc$qe4$1@cheetah.cadsoft.de...
Hello Leo B !:
ground planes?
You can use some restricts and ignore some errors. Unfortunately all wires
you should create manually. With small clearance you can use some arcs in
restrict layer.
DRC.
regards
Grzegorz Zalot
Why argue with it? The user has the control. It should be possible to set
the VIA characteristics in a way that it 1. disables thermal generation
regardless of other settings, 2. enables them regardless of other settings,
and 3. enables or disables them according to "Global Design Rules" (note,
NOT the DRC). Another nice example for this is the STOP flag (see "Re: STOP
flag, vias with and without stop mask" in eagle.betatest) - same "ON -
AUTO - OFF" scheme here. Once more: if at all, such modifications need to be
controlled by "Global Design Rules", not by the "Design Rule Check". It's
about time to fix this terrible conceptual flaw!!
T.
Hello T.Strothmann !:
Why argue with it?
Me ?????
Yes.
It's
:-D ! IMHO last time ....
But the shortest way is possibility to disable the stupid global flag
for each polygon separately.
regards
Grzegorz Zalot
complex ltd.
Gentlemen,
I've only been using Eagle for a few months on some simple two-sided boards,
and I'm not sure I understand all the comments here. To clarify, here's my
situation:
I have a two-sided PCB with a ground plane on both sides (a wide-band
high-gain video amp). I use a large number of vias (without thermals) to
stitch the two ground planes together. I want to use a couple of vias for
ground test points, thus the desire for thermals on these vias only. It
won't break my design if I can't do it - I can always find a big soldering
gun! BTW I'm using Eagle 4.16r2.
Thanks for all the comments.
Leo B.
"Grzegorz Zalot" <complex@alpha.pl> wrote in message
news:g2lpl7$qmo$1@cheetah.cadsoft.de...
Why argue with it?
Me ?????
settings, and 3. enables or disables them according to "Global Design
Rules" (note, NOT the DRC). Another nice example for this is the STOP
flag (see "Re: STOP flag, vias with and without stop mask" in
eagle.betatest) - same "ON - AUTO - OFF" scheme here. Once more: if at
all, such modifications need to be controlled by "Global Design Rules",
Yes.
It's
But the shortest way is possibility to disable the stupid global flag for
regards
Grzegorz Zalot
complex ltd.
Why argue with it?
Me ?????
Well, yes, you wrote "Why ????? This is IMHO best way to create good
boards.". And my opinion was that everybody has his personal preference on
how a good board should look like. My suggestion with the "improved via
control" gives you full flexibility in this respect, and as far as the
discussed problem is concerned.
Again: if you can't handle the described automatic actions in a
"ON-AUTO-OFF" fashion you don't have full control.
Yes.
It's about time to fix this terrible conceptual flaw!!
Yes, I agree - but in combination with the "ON-AUTO-OFF" setting of each
individual via!
T.
regards
Grzegorz Zalot
complex ltd.
"Leo B" <leob001@gmail.com> schrieb im Newsbeitrag
news:g2m6o1$7cl$1@cheetah.cadsoft.de...
Gentlemen,
boards, and I'm not sure I understand all the comments here. To clarify,
here's my situation:
Leo B.
In short: no individual vias. There's only the global setting in the "DRC".
A workaround may be to specify devices with pads only, and use them as vias.
There's a different level of control for pads, local for each polygon.
T.
Leo,
I recommend you add "Testpins" connected to GND in your schematic. That way
you will have single pad components on your PCB that you can place anywhere
in your GND polygons with thermals enabled. That way you don't have to use
vias as test points.
(Obviously this applies to any other signal where you want to add a test
point)
Robert
"Leo B" <leob001@gmail.com> wrote in message
Gentlemen,
Leo B.
Why argue with it?
Me ?????
Yes.
It's
regards
Grzegorz Zalot
complex ltd.
"Robert" <rbeng@telenet.be> schrieb im Newsbeitrag
news:g2o5or$g66$1@cheetah.cadsoft.de...
Leo,
way you will have single pad components on your PCB that you can place
anywhere in your GND polygons with thermals enabled. That way you don't
have to use vias as test points.
point)
Robert
That's what I meant with the pad-only devices.
T.
P.S.: please don't post on top ("TOFU")
Thanks for the suggestion Robert. I thought of that idea also, but I didn't
want to clutter the schematic with extraneous symbols. But it looks like
that's the best solution for now.
Leo
"Robert" <rbeng@telenet.be> wrote in message
Leo,
point)
Robert
Gentlemen,
for ground test points, thus the desire for thermals on these vias only.
It won't break my design if I can't do it - I can always find a big
soldering gun! BTW I'm using Eagle 4.16r2.
Leo B.
Why argue with it?
Me ?????
Yes.
It's
regards
Grzegorz Zalot
complex ltd.
In my opinion you do have to show the test pins in the schematic. You
might want to know what you're testing...
Marco / iw2nzm
