EAGLE User Support (English) How to place holes under a angle
  • Subscribers 179 subscribers
  • Views 368 views
Hi group,
I have place 2mm holes in a 19 cm circle on a 20cm round  PCB at 7.5 degrees
increment.
Can anybody tell me how i could do that. The pattern looks like in this
documentd document www.harry-arends.nl/Eagle.pdf
Regards
Harry
    On Thu, 17 Jul 2008 Harry H. Arends wrote saying :
    Hi group,
    increment.
    It's probably not too hard with a ULP, but I'm not a ULP expert. I'd
    probably knock up a Python script to write an Eagle SCR consisting of
    lots of
        hole ();
    commands, then run that script.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
  • Richard_H
    Richard_H over 17 years ago
    Harry H. Arends schrieb:
    Hi group,
    increment.
    Regards
    Harry
    Set a relative origin with MARK in the center. Then use polar
    coordinates for placing holes.
      GRID MM;
      HOLE (P95 0)
      HOLE (P95 7.5)
      HOLE (P95 15)
      HOLE (P95 22.5)
    Richard Hammerl
    Where should i put them in. I am not a expert in ULP and SCR files
    "Richard Hammerl" <ric@cadsoft.de> schreef in bericht
    news:g5pfea$7u5$2@cheetah.cadsoft.de...
    Hi group,
    degrees
    increment.
    Regards
    Harry
    GRID MM;
    HOLE (P95 0)
    HOLE (P95 7.5)
    HOLE (P95 15)
    HOLE (P95 22.5)
    Richard Hammerl
  • Richard_H
    You don't need an ULP. Simply type the command once in the
    Layout Editor's commandline.
    Of cours you could also write a litte text (script) file with all
    the commands in it, like
      HOLE (P95 0) ;
      HOLE (P95 7.5);
      HOLE (P95 15);
      HOLE (P95 22.5);
    Save it with the file extension .scr and use the SCRIPT command in
    the Layout Editor to execute this script.
    Richard Hammerl
