EAGLE User Support (English) Auto-Smash
  • Subscribers 189 subscribers
  • Views 538 views
  • eagle
  • smash
Auto-Smash
It is quite rare that a symbol, both on the schematic and on the PCB, can actually be placed without moving the name and values.  Is there a possibility that a check-markable item under the View menu could be added the "Auto-Smash" or "Smash ALL" ?
Yes, I know that a parts can be quite easily smashed in multiple ways,  but this gets a little old after a while.
    Then you need to take more care building your libraries if you have this
    problem often in schematics.  This is really quite rare for me in
    schematics.  I do, however, have different parts for different
    orientations.  For example, a horizontal resistor is different from a
    vertical one, precisely so that the text can be sensibly arranged around
    each.
    On the board it's different because you can't predict layout and placement
    of vias when you make the package.  There, smashing everything and cleaning
    up the silkscreen is just part of the process of making a board.  However,
    even then you only do a single smash once.
    Yes, like group everything and then smash.
    HI,
    I agree, It would make sense to have an option in the USER PREFERENCES that
    parts added via SCH or BRD are "AUTO SMASHED".
    thanks
    Dave M
  • jeromeabcpcb
    0 jeromeabcpcb over 14 years ago
    "jhannas@jrh1.us"  a écrit dans le message de groupe de discussion :
    1604068559.3921314706654090.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Your symbol part (library) should have a proper design so that you almost
    never need to move the texts. Personally, I only move resistors names when
    they are stacked too close.
    For the layout, that's another story. I usually hide the names layer and
    focus on a proper electrical routing. Then when all is done, I show the
    tNames and tOrigin, select all, smash all. So I only need to do it once.
    Jerome
