EAGLE User Support (English) CAD ASCII
  • Subscribers 189 subscribers
  • Views 986 views
CAD ASCII
Is there a way I can export a CAD ASCII file from eagle?  Ive tried a few of the ULP's but they weren't what the board assembler was looking for.  Thanks for any help!
    On 1/17/2012 9:26 AM, Michael Lukehart wrote:
    Hi Mike,
    What is the file specifically for? Is your assembler asking for a pick
    and place file? If that's the case you mount-smd.ulp.
    Do they need a netlist? If that's the case then you would need to know
    what format they need. There are ULPs for Tango netlists and such.
    Will they use the file to setup their test rigs? In that case there is a
    GenCAD ulp (as Warren mentioned), fabmaster, and ipc-d-356.
    If your assembler can specify what they need from the file then it's
    more likely that you'll get a solution.
    Best Regards,
    Jorge Garcia
    Hi Michael
    This question has been asked before over the years and EagleCad does not
    provide a solution. I suspect V6's  XML  format will currently not suffice.
    The assembler must be able to make use of the format of the provided ASCII
    file.
    To date there are many ascii formats that an assembler can use. Take a look
    at this link http://www.eurolectron.com/Digitaltest-CADlst.htm
    So going forward we should learn what is the best approach to getting this
    functionality.
    With that in mind, who is the assembler you are dealing with? Their web site
    may list the ascii file formats they can accept.
    Having looked into this 'a little',  ODB++ will likely be desirable in the
    long term and would be a big nut to crack. GenCAD seems do-able sooner
    provided it is accepted by the majority of assemblers and provides
    sufficient information for them.
    Warren
    news.cadsoft.de
    0 e14 Contributor over 14 years ago in reply to CSWalt
    Im using version 5
  • CSWalt
    0 CSWalt over 14 years ago
    On 01/17/12 15:26, Michael Lukehart wrote:
    Did you know that Eagle Version 6 IS CAD ASCII ? XML, to be exact.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
