EAGLE User Support (English) Trying to create a circular shaped PCB
  • Replies 7 replies
  • Subscribers 190 subscribers
  • Views 1149 views
tomshong
tomshong over 14 years ago
Hi all,
I am a newbie to EagleCad. I am using 6.2.0 Lite version.
I am trying to build a PCB around a CR-2325 battery holder similar to one shown in the link.
http://shop.vetcosurplus.com/catalog/images/PH-BH2038-1.jpg
Here are the problems I got
  1. How do I place the component on the layout such that the part will go on the ‘bottom’ layer of the PCB?
  2. How do I create a circular PCB? I’d like to make my PCB slightly bigger but about the same shape as the battery holder shown.
Tom
    0 e14 Contributor over 14 years ago in reply to tomshong
    On 7/21/2012 6:03 PM, Tom Hong wrote:
    Thanks.
    does the EagleCad know it's suppose be on the bottom layer just by 'flipping/mirror' it?
    Thats the point of the mirror command.   If you take an smt component
    and mirror it,  then turn off the display of the top layer you will find
    that all the pads for the component are still visible because its now on
    the bottom layer.    You will see that all the associated text (value,
    name) have also been mirrored.
    Jim
  • tomshong
    0 tomshong over 14 years ago in reply to e14 Contributor
    Thanks.
    does the EagleCad know the part is suppose to go on the bottom layer just by 'flipping/mirror' it?
    Tom Hong wrote:
    Thanks.
    Can you elaborate on how to layout PCB viewed from the other side? I can
    create a custom library part that's mirrored to the original dimension,
    but how do I tell EagleCAD that I want it to be on the 'bottom' layer?
    I tried your suggestion for 2) and I think I am good on that one. image
    No need for a custom library part. Chuck gave you the answer in hist first
    post: just place the part, then use the Mirror command/icon to flip the part
    over to the bottom layer.
    I hope this is a circuit board you intend to route out yourself, because
    just about every board house I know is going to charge you a fortune for
    milling round boards, particularly when they're that small.
  • tomshong
    Thanks.
    Can you elaborate on how to layout PCB viewed from the other side? I can create a custom library part that's mirrored to the original dimension, but how do I tell EagleCAD that I want it to be on the 'bottom' layer?
    0 e14 Contributor over 14 years ago in reply to dukepro
    Chuck Huber wrote:
    >> Delete the rectangular board outline from the Dimension layer and
    >> replace it with a circle.
    >I might add that if you make the line width of the circle zero, it will
    >fill in, which is NOT what you want.  Instead, make the line width some
    >arbitrarily small value, like 1 mil, or 0.1mm.
    or use the wire command with curve or radius options to draw two 180°
    arcs
         wire (x1 y1) +180 (x2 y2) +180 (x1 y1);
    where +180 defines the angle between arc start and end point.
    Lorenz
  • dukepro
    0 dukepro over 14 years ago in reply to dukepro
    HTH
        - Chuck
  • dukepro
    Hi all, I am a newbie to EagleCad. I am using 6.2.0 Lite version.
    Here are the problems I got 1. How do I place the component on the
    Mirror the component.
    Enjoy,
        - Chuck
