EAGLE User Support (English) Schematic Editor;  Board Editor >> “Pan” the screen
  • Subscribers 187 subscribers
  • Views 2820 views
  • board_editor
  • schematic_editor
  • pan
seebobsee
seebobsee over 14 years ago
Need to incorporate the ability to “Pan” the screen in the “Schematic Editor” and the “Board Editor”
Adobe products use the Spacebar to change the curser to a hand, then you left click and drag the screen to where you want it.
Another method would be to allow use of the arrow keys to pan the screen. up, down, left, right.
    Jorge Garcia wrote on Tue, 06 November 2012 15:08
    On 11/6/2012 12:51 PM, Bob See wrote:
    Need to incorporate the ability to "Pan" the screen in the
    "Schematic Editor" and the "Board Editor"
    Hi Bob,
    Click and hold your center mouse button or scroll wheel to pan.
    hth,
    Jorge Garcia
    There is another option that everyone is forgetting.  It's old so maybe
    many don't remember or ever knew about it.
    From "help set", scroll to the bottom and look at the option
    "Interface.UseCtrlForPanning".  EAGLE used to use the CTRL key for panning
    and you can get that functionality back.  To do so you would just enter the
    following in the command line:
    set Interface.UseCtrlForPanning 1
    and to turn that off
    set Interface.UseCtrlForPanning 0
    This setting is "sticky" so EAGLE will continue to behave like that until
    you undo it with the above command (even through exiting the program).
    I haven't done this recently and it may mess up newer functionality that
    uses the middle button, but it's worth a try.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    0 shabaz over 13 years ago in reply to e14 Contributor
    As a suggestion, a gaming mouse.. really improves productivity for applications like EAGLE. It has a smoother (therefore quicker therefore more productive!) scroll wheel, more adjustment options and additional buttons for customization. Plus it's comfortable.
    Am 09.01.2013 08:13, schrieb db:
    Is there a way to assign this to a key?
    I just have a two button mouse.
    Using EAGLE with only a two-button mouse is a VERY, VERY, VERY, VERY,
    VERY bad idea, because it TREMENDOUSLY slows down the drawing process.
    It is possible, of course, but using the middle mouse button for panning
    AND THE SCROLL WHEEL for zooming is MUCH, MUCH, MUCH, MUCH, MUCH more
    useful and more than ten times as fast! AND you'll produce designs with
    MUCH less errors, because with a scroll-wheel mouse, you always zoom in
    sufficiently, because it's SO easy and SO fast and SO useful.
    Buy a scroll-wheel mouse immediately. If you don't want to do this,
    EAGLE will NOT be fun to use, because you always have to use some
    buttons to zoom and scroll bars for panning. That's a REAL pain and
    EXTREMELY slow working.
    Andreas Weidner
    "Bob See" <noreply-139799@element14.com> wrote in message
    news:1201579530.7481352224294453.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Need to incorporate the ability to "Pan" the screen in the "Schematic
    Hi Bob,
    hth,
    Jorge Garcia
    Depressing a mouse center button/wheel and dragging does this .
