EAGLE User Support (English) How to get a 100% scale to a pdf
  • Subscribers 178 subscribers
  • Views 1272 views
  I print the circuit layout for etching using photo paper through a
laser printer. While it is nice to print directly to the paper from
Eagle, I would like to send the copy to a pdf file. To save paper, I
have ran the same photopaper thru the printer several times moving the
circuit around on sheet till I fill the sheet up.  The bad part of this
is when I run the photo paper thru the printer several times, black
streaks appear. I have tried to save to a PDF file of which I could copy
the circuit several times on a blank sheet.  When I save a printed
circuit board as a pdf file, the size gets distorted and makes it
difficult to get the circuit back to the original size. How do you save
the circuit to a PDF as the same size?
    On Tue, 28 Oct 2008 20:46:57 -0400, cjolly wrote
    (in article <ge8bq2$8jm$1@cheetah.cadsoft.de>):
    A better format for doing that is EPS I think.  You'll need some s/w that can
    handle it.  Not a problem on Linux, you'll have to search for some on
    Windows.
    BTW, we typically like it if you use your real name on the forums.  It's a
    small community image
    Cheers,
    James.
     James Morrison  ~~~  Stratford Digital
     email:  sales@eagletoolkit.com
     fax:    888.701.8097
     web:    http://www.eagletoolkit.com
     Online EAGLE Dealer for US and Canada
     EAGLE Design Experts
     EAGLE Enterprise Toolkit
    Windows.
    Cheers,
    James.
    fax:    888.701.8097
    Thanks for the response.  I'll google EPS. BTW, C Jolly is my real name 8-)
    Printing from Eagle is the best way for this IMHO. Adding in a another step
    (format) will inevitably lead to errors creeping in.
    What you could to do is look how you can panelise your design in Eagle so
    that you have several PCB layout designs in the board editor window.
    This is trivial to do, by breaking one of Eagles golden rules.  You must
    close the sch window and work only on the board editor.  saving the board
    under a new name of course.  You can then Group, cut and paste your design
    You can also with some messing about cut and paste different designs into
    the same board window for printing.  I don't think it is ever a good idea to
    run the same paper/transparency/photo paper, as it again inevitabley leads
    tom poor pick up, or  small errors creeping in as the paper is heated sever
    times.
    cheers
    DAvid
    step (format) will inevitably lead to errors creeping in.
    so that you have several PCB layout designs in the board editor window.
    Tnanks for responding Dave. I tried that, but I am using the freeware
    version and I only have so much room to use.
    cjolly pravi:
    Did you try just export as image? You can arrange bitmaps in any graphic
    program and print. Of course use 1:1 scalling. 600 DPI is good enougth.
    Slavko.
    cjolly pravi:
    Slavko.
