EAGLE User Support (English) Eagle PCB check
  • Replies 12 replies
  • Subscribers 179 subscribers
  • Views 989 views
Eagle PCB check
anshulsanam
anshulsanam over 12 years ago
I'm a beginner in eagle and I designed a PCB and I am ready to send it off to the PCB fab house.
but I need to make sure the board is gonna work cause I dont wanna spend 40 dollars on the PCB and have it short or not work.
So could you guys check the schematic and board file.
http://www.fast-files.com/getfile.aspx?file=63502                   -            schematic
http://www.fast-files.com/getfile.aspx?file=63503                   -             board file
  • anshulsanam
    0 anshulsanam over 12 years ago
    What do you guys think
    0 autodeskguest over 12 years ago in reply to anshulsanam
    Am 13.06.2013 08:49, schrieb anshul sanam:
    http://www.element14.com/community/message/79705#79705
    Link doesn't work!
    Joern Paschedag
  • anshulsanam
    0 anshulsanam over 12 years ago in reply to autodeskguest
    here it is both the schematic and board file
    http://www.mediafire.com/view/czx9fo052bcbncd/anshuluino1.schhttp://www.mediafire.com/download/czx9fo052bcbncd/anshuluino1.sch
    http://www.mediafire.com/download/wh9b3tj7bjv0loo/anshuluino1.brd
    Things I would change
    1) The tPlace font is Proportional, make it Vector so you get what you see.
    2) Move the text off the pads, The board house will chop the characters to
    bits to satisfy this. Best you move the text so its readable when the board
    comes back.
    3) Text like R4 will not come back readable as it is to thin. Currently the
    characters are 16mil high and the strokes of the chars  are 8% of that,
    about 1.2mil. Your board house likely has a >5mil  recomendation  for
    printed objects
    4) All the servo connectors have power connections with only three spokes of
    the thermal connected. with some shifting of nearby traces they could have 4
    spokes giving greater strength and current capability.
    5) Reduce the wire size for the polygon pours to 10mil, It gets rid of a few
    unclosed regions.
    6) Move R8 further left, its quite near the board edge. Align it with R5
    pad.
    Last thing. When you generate your gerbers, view them in a gerber viewer
    before you send them off.
    HTH
    Warren
    news.cadsoft.de
  • anshulsanam
    thanks a lot for the suggestions i didnt understand how you could get 4 thermal spokes do i just move nearby traces further away, also do you think everything else is fine, and is there a good chance I will get it working after i get the real PCB back
  • anshulsanam
    do you think the voltage dividers for the sensors are proper
    http://www.element14.com/community/message/79921#79921
    Hi
    The thermal spokes are formed when the polygon pour fills. Currently the
    pour, made with the same width wires as you define the polygon outline with
    (your 10 or 16 mil wires), cannot fit all the way around certain places so
    you have to make it possible for them to get in there. You need to move
    traces, or other objects that  require clearances, out of the way for that
    to happen. From what I could see that would be an easy job.
    I can't comment on whether every thing else is fine or that it will all work
    when the PCB comes back, that depends on your electrical design. If the
    schematic was wrong then the circuit may not work. Ensure you run an ERC
    check  That should pick up any missing connections.
    What I'm helping you here with is applying better PCB design practice,
    hence reducing the chances that the PCB will contribute to any problem
    initially or during its life.
    The end goal for any PCB is one that is electrically correct and strong so
    that it resists the abuse it will be subjected to during assembly
    (soldering) and during it's life.
    All the best
    Warren
    news.cadsoft.de
  • anshulsanam
    I have made a final revision which Im confident on. I just want to know if you guys think it correct
    schematic - http://www.mediafire.com/download/qq1kudnnalgebel/anshuluinonewnew.sch
    board - http://www.mediafire.com/download/2ld2l1ijhulftk7/anshuluinonewnew.brd
    thanks image
  • fritzz
    0 fritzz over 12 years ago in reply to anshulsanam
    I get
    Loading C:/Program Files/EAGLE-6.2.0/projects/someone elses/anshuluinonewnew.brd ...
    Warning(s):
    line 356: unknown attribute 'name' in tag <designrules>
    when I try to load this.
  • fritzz
    0 fritzz over 12 years ago in reply to fritzz
    Text of that LED is overwriitne by another text.
    Maybe add a bypass cap on chip's VCC also?
