EAGLE User Support (English) The Eagle Freemium license appears to have deactivated after a couple of days - Why & how to fix it?
  • Replies 12 replies
  • Subscribers 182 subscribers
  • Views 3517 views
  • eagle
  • deactivate
  • license
  • freemium
  • error
richjteel
richjteel over 12 years ago
I installed Eagle about a week ago and started working on a schematic. Now when I open Eagle, I am prompted with how I would like to run it just as it did the first time I ran it. I select the Freemium license button and enter my code again but I am prompted that the code has already been used and cannot be activated from this machine. I am trying to learn how to use Eagle and get a board made but this sure is not helping. I intend to purchase Eagle but I am loosing confidence in the product.
Fullscreen contentimage_35860.html Download
<html><head><title>Jive SBS</title></head>
<body><font face="arial,helvetica,sans-serif">
<b>Error</b><br><font size="-1">
An general error occurred while processing your request.
</font></font></body></html>
Fullscreen contentimage_35861.html Download
Is there a way to rectify this issue?
BTW: I requested another code from http://www.element-14.com/eagle-freemium and got the same one that was generated earlier. I have not changed any hardware configuration on my PC. The only software change that I am aware of is Java updated to version 7 update 51.
    0 autodeskguest over 11 years ago in reply to liverdonor
    On 8/13/2014 4:16 AM, Sam Felton wrote:
    If it's tied to the MAC address, I suppose that means that you can never
    run it in a VM.
    Tried to install into a VM myself (that's the "machine" we use for other
    CAD/CAM work - it runs on a Hyper-V Server). Unfortunately that's the
    only system we're allowed to install CAD software on.
    Would not install properly - gave me the error message that it "could
    not install the license, please contact CADSoft"
    I guess I can't use Eagle, then. We have a requirement that all software
    in our shop is desktop-virtualized.
    Hello Sam,
    The Freemium is tied to a MAC address none of our other versions of
    EAGLE are though. So if you want try the freeware and you'll see that it
    works just fine. The pro,standard, and Light versions will also work
    because they are not dependent on MAC address.
    Let me know if you need any help.
    Best Regards,
    Jorge Garcia
  • liverdonor
    0 liverdonor over 11 years ago in reply to autodeskguest
    Hello, Jorge.
    Just for grins, I decided to try again.
    This time, I copied the ZIP onto the virtual HD of the running machine and tried it from there.
    Well, it worked. Apparently, the "virtual" MAC address was enough to satisfy the installer after all.
    We'll see how it behaves when run in a virtual environment. That's the important test.
    ~Sam
