EAGLE User Support (English) ASCII export ALL pcb information
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 2096 views
I see ulps for netlists, but our vendor wants a complete ASCII file  like a
PADS ASCII file that contains All the pcb information.  Is there a ulp or
anyway to create this file in Eagle 4.16?
    I think there are ULPs for exporting complete designs into script files
    (which are ASCII) in the download section of the CadSoft website.
    Tilmann
    There are some ULP's for various export/import in the CadSoft download
    directory.  You might find something there.
    We sell a tool (with support) that can export PADS ascii files from an EAGLE
    schematic (for use with an external layout tool) and import PADS ascii files
    into an EAGLE board file (for using an external schematic tool).
    These tools just deal with netlists.  It's not an import/export of a design.
    But if that is what you want then go to
    http://www.eaglecentral.ca/purchase/eet_pads.php?product=1&d=1
    Cheers,
    James.
     James Morrison  ~~~  Stratford Digital
     email:  sales2009@eaglecentral.ca
     fax:    888.701.8097
     web:    http://www.eaglecentral.ca
     Online EAGLE Dealer for US and Canada
     EAGLE Design Experts
     EAGLE Enterprise Toolkit
    I've been through all of the .ulp files online and found nothing to export a
    complete ASCII file.  I can't believe there isn't anything.  Most vendors we
    work with need this.
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:C596803D.5D6%james@eaglecentral.ca...
    a
    EAGLE
    files
    design.
    Cheers,
    James.
    fax: 888.701.8097
    I fear we are talking about completely different things.
    No board house needs any ASCII file containing the complete design.
    They only need the complete gerber files for PCB production. These are
    generated by the CAM processor.
    No parts vendor needs any ASCII file containing the complete design.
    They only need a complete part list. You can generate them with the
    EXPORT command, or (more comfortably) with some ULPs.
    No assembly house needs any ASCII file containing the complete design.
    They only need the parts plan (silk screen) and the part list, plus
    eventually some additional detail information that is not contained in
    the design anyway. You can even generate complete pick&place programs
    for automated SMD assembly by ULP.
    No customer of a design contract needs any ASCII file containing the
    complete design. They are lucky with the original EAGLE design files.
    So can you explain for what you need a "complete ASCII file", and what
    exactly you expect from this file?
    BTW, please don't top-post. Please read and understand
    <http://www.netmeister.org/news/learn2quote2.html>.
    Tilmann
    "Tilmann Reh" <user@domain.invalid> wrote in message
    news:gl4sgh$7ug$1@cheetah.cadsoft.de...
    export a
    we
    Tilmann
    We use contract manufacturers that do the entire process from making the pcb
    to testing the final product.  Here is text from an email requesting the
    ASCII file.
    "Besides being used for machine programming and for generating the images
    for our Manufacturing Process Instructions, the CAD data is also important
    to me for extracting component information for the labor quote.
    Per your e-mail sent on 11/11/08 that there was no ASCII file, so I went
    ahead and manually Digitized the board using the gerber files that were
    sent.
    The ASCII CAD file is basically the text file output from your CAD system of
    the board design.  This file allows us to quickly generate machine programs
    and work instructions using our CAM software.  If we don't have the ASCII
    CAD file, then we have to use your Gerber files to manually "digitize the
    board" within our software to achieve the same thing the CAD file does, but
    it adds 4-8hrs to our process and lends itself to error since it is a manual
    process.  This is why the ASCII CAD file is preferred.
    I've attached instructions on how to output the ASCII CAD file from multiple
    CAD systems.  Find the CAD system that you guys use in the document attached
    and then follow the instructions to output the ASCII CAD file."
    The attached instructions did not list EaglePCB.  I think what they are
    used to dealing with is the ASCII output from PADS and Protel inwhich you
    can select the entire design to export.  It would be like taking the Eagle
    .brd file and converting it to text.
    I can email you a sample file so you can see what data is included if you
    wish.  I would do that out of the news groups of course.
    Jim
    ASCII file.
    sent.
    So obviously they need the parts and their coordinates. Use EXPORT
    PARTLIST from the board editor window and ask them if that file is
    sufficient for them.
    You can also use one of the pick&place ULPs that generate several
    commonly used formats for assembly machines (but only for the SMD
    parts). Perhaps you use them all and provide all resulting files - and
    let your manufacturer choose the file he likes the most (i.e. which is
    easiest to use for him). If he still complains, let us know about the
    details.
    Let me note that the nomenclature of that contract manufacturer is
    somewhat strange and misleading. There is no common meaning of "ASCII
    CAD file".
    You can send me a file to my reply-to address if you want me to have a
    look at it. Did (or: can) the manufacturer also provide a sample file of
    the kind he is expecting from you?
    Tilmann
    Former Member over 16 years ago
    "jgraverholt" <jgraverholt@huntron.com> wrote in message
    news:gkqdhd$ktc$1@cheetah.cadsoft.de...
    I have used the Export_ProtelPCB.ulp for this purpose with some success. Our
    board assembler wants a .pcb file for doing manufacturing analysis before
    running the job.
    Doyle
