EAGLE User Support (English) Eagle 5.4.0 started crashing, Windows SP sp3
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 1536 views
blewis999
blewis999 over 17 years ago
Eagle has started terminating, I have loaded no new programs or
drivers. I tried rolling windows back to when the system was stable.
Only Eagle is crashing, none of the other programs have this problem.
Has anyone else encountered this, and if so what can be done. I tried
re-installing but same problem. Although I did install into the same
directory and just overwrote the files.
  • kcadsoft
    kcadsoft over 17 years ago
    On 03/20/09 00:39, blewis999 wrote:
    After much grief I am back again.
    I reverted to my windows restore point of three weeks ago which was
    well before I installed Eagle 5.4.0... to make sure that the OS was
    solid then. I did not install any software and ran the system for
    several days doing a lot of intense CPU work with videos and audio;
    there wasn't a single problem. I also did not re-install Agent News
    Reader so was unable to post, thinking that maybe Agent was the
    problem.
    Today I re-installed Eagle 5.4.0 and it crashed on right clicking on
    an existing file in the 'open a file' dialog. I think there are
    problems with the file access interface. This is where I have seen it
    terminate before.
    The 'open a file' dialog is the native Windows file dialog.
    - What are you trying to achieve by right clicking on an item
      in that dialog?
    - When you right click, does a menu pop up, or does it crash
      before that menu pops up?
    - If a menu pops up, can you send me a screen shot of the dialog
      with that menu?
    - If you get as far as clicking on a menu option, which one is
      it, and does EAGLE crash immediately after you click on that
      option, or is there some more activity (like a screen redraw
      or something like that) before the crash?
    - Does ist also crash if you don't right click on an item, but
      rather double click with the left mouse button?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • blewis999
    problem.
    terminate before.
    Here is the question! Is there anyway to export my libraries or board
    and go back to Eagle 4.16r1? That was stable and I can get by without
    the new features for the present, but I can't get by with not getting
    the work done!!
    Robert
  • kcadsoft
    On 03/13/09 15:30, Brownie wrote:
    I hope this provides some insight Klaus.  This problem has happened several
    times over the last couple of months while running Eagle.  It may fall in
    line with some conversation we had several months ago regarding Win Crashes
    while doing Manual File Saves.
    There was an occasional problem with renaming temporary files on Windows in
    case the new file name already exists. This has been fixed in version 5.4.3.
    Other than that I'm not aware of any file saving problems on Windows.
    If find a reproducible set of actions that cause a problem, please
    let me know.
    Klaus Schmidinger
  • blewis999
    Unfortunately, Eagle 5.4.0 just terminated again but this time there
    are no events in the system log.
    I am not sure what to do... I do not have any other app's terminating.
    I just upgraded from Eagle 4.16r1 and have never had that version
    crash. I used 4.16r1 up to the time I installed 5.4.0 without problem
    and did no system upgrades between the install of 5.4 and using 4.16.
    Can I export my libraries from 5.4.0 and re-import them into 4.16r1?
    Or even copy them?
    Robert
    On Fri, 13 Mar 2009 10:30:01 -0400, Brownie <nomail00@worldpath.net>
    wrote:
    Klaus Schmidinger wrote:
    On 03/13/09 05:15, Robert Lewis wrote:
    I found the problem; this is not Eagle at all but Windows XP. The
    problem was when I did a file operation such as search for a directory
    inorder to open a new schematic or to save a schematic or board. The
    error is
    " Event 8003
    The master browser has received a server announcement from the
    computer nnnn-PC that believes that it is the master browser for the
    domain on transport NetBT_Tcpip_{50BFAA9C-4CFA-44FE-B. The master
    browser is stopping or an election is being forced." Then the file
    operation fails, probably due to a network connection check and
    then Eagle terminates. I think Eagle should do a check on the return
    status from a file operation and not exit but notify and continue. A
    more graceful method in my estimation.
    Actually we do check the return codes of all file operations, so
    I wouldn't know what to change in that area.
    Are you getting any more specific error messages? Something that
    could indicate a problem in EAGLE?
    Klaus Schmidinger
    Hi Klaus and all
    Firstly we are all probably in the Wrong area for Bug discussion, but to
    keep the thread unbroken I return this comment here. Previous reply is
    above - Brownie - with system details.
    I just installed 5.4.4 and decided that since the Win system should always
    be rebooted after any software install - even if it does no Registry
    entry - we should run through a system cleanup - delete Junk Files.
    In looking under the root there was a File000.chk.  These are generated when
    there has been a system scan done - usually after some crash and reboot.
    We looked at the files with X-Tree Gold (very old Dos file manager that one
    must use with extreme caution under Win) binary viewer.  Both of the files
    were orphaned BUT complete files (based on the file sizes compared to Good
    files in the Project folder) generated from Eagle.  I'm sure that Eagle
    does NOT leave Loaded Files OPEN as some windows programs do.  There for my
    only best guess is that Eagle may have been trying to do an Auto-Save when
    Win took it's vacation.  This may fall in line with Mr. Lewis's comment
    above here.
    Win does perform sporadic disk writes of it's own - anyone know why?
    Maybe this problem is so unpredictable because it's'  such a crap shoot to
    know if Win is about to do a disk write.  I don't think Win cares what else
    is going on so there could be some conflict if programs that do writes
    don't delay a bit if Win is busy.  Just a long-shot Guess.
    Thanks for allowing me the privilege to express my hopefully not too
    ignorant viewpoint.
    Regards All,
    Brownie
    this doesn't apply to Eagle IMO. You can unpack the Eagle archive and
    just start Eagle - no installation needed at all.
    You don't want to reboot Windows after each program start?
    BTW: Since using W2K, I reboot Windows every month or so - in the
    mean, I just "hibernate" the system (staying logged in, of course).
    There is a good change that your Windows installation is broken.
    This doesn't seem to be Eagle related.
    Oliver
    error is
    " Event 8003
    Klaus Schmidinger
    Hi Klaus and all
    above here.
    ignorant viewpoint.
    Regards All,
    Brownie
  • kcadsoft
    error is
    " Event 8003
    Klaus Schmidinger
    I too have had Win XP SP2 totally crash while running Eagle but have
    attributed the crash to another of Win's' goofy frailties.  BUT...  the
    systen is used to do many other tasks and has not crashed.
    Win XP-SP2
    2 Gig Ram
    Sata 140 Gig
    Pent core 2 2.6Ghz
    On Motherbd Display using shared ram
    The only thing I can think that might make Eagle crash is some memory leak
    in the C-code.  Knowing the attention to detail by the Eagle team this does
    not seem to be a likely cause.
    I submit this just in case someone else had this and did not know why.
    It's a very infrequent occurrance and I can not easily duplicate it.
    Brownie
  • blewis999
    error is
    " Event 8003
    Now to find out why the event is occuring. Someone could make some
    serious money if they could design a windows system that worked and
    didn't die with these bizarre errors for no reasonable reason at all.
    Thank you for the help.
    It should be mentioned that this can happen on WinXp if registry is
    corrupted. It didnt crash until a spesific key was touched. I had this issue
    with some other sw.
    I could create the crash by starting regedit.exe, search for a value that
    doesnt exist (F3, then type some crap).. If it crashes, the registry is
    corrupt.
    I had to go way back in system restore to recover this.
