EAGLE User Support (English) Is it possible to create a "area" of VCC or GND in the PCB?
  • Subscribers 180 subscribers
  • Views 474 views
Is it possible to create a "area" of VCC or GND in the PCB? My objective is to create this area like a breadboard, where it has 2 lines (VCC and GND)
  • dukepro
    0 dukepro over 11 years ago
    GND)
    Have you tried a polygon?  Be sure to name it VCC or GND appropriately.
    2260.att1.html.zip
    0 dougw over 11 years ago
    On the layout - create as many through hole pads using the Via tool as you want, then rename all the pads you want to be ground or VCC with the Name tool.
    Also, if you "Clone" any pad, the new pad will retain the same net name as the parent pad, so cloning a ground pad multiple times will create a bunch of ground pads.
