Can i draw a differential pair in eagle?
THX
THX
Minki wrote on Mon, 13 April 2009 16:05
Hello Minki,
I do this quite often in EAGLE. First off, the auto-router is going to be
no use here. So it will have to be done by hand. The good news it that
normally these are critical traces so they tend to get routed first when
there is very little interference.
The way to do this is to use the routing grid to your advantage. First
breakout from the pins if you need to and get to vias, preferably in a
symmetric fashion.
Then change the grid to
0.5 * (trace width + ( 2 * trace separation) )
Set the width to what you want and then route. If you place the traces
with one grid line between them then you'll have the exact separation you
need.
You can also put down restrict areas to give you the separation to all
other signals if you want. This is needed if you are going to use the
auto-router to route the rest, otherwise it will put traces or vias too
close and that will effect impedance. I think the rule of thumb is about
twice the separation to any other signals.
Cheers,
James.
James Morrison ~~~ Stratford Digital
email: sales2009@eaglecentral.ca
fax: 888.701.8097
web: http://www.eaglecentral.ca
Online EAGLE Dealer for US and Canada
EAGLE Design Experts
EAGLE Enterprise Toolkit
Thank for help first^^
But it seem like can't make the tracert with same length?
I want make the differential pair with same length.
How can i do that?
THX
"James Morrison" <james@eaglecentral.ca> ¼¶¼gó¶l¥ó·s»D:gs06su$atg$1@cheetah.cadsoft.de...
Hello Minki,
symmetric fashion.
need.
Cheers,
James.
fax: 888.701.8097
Minki wrote on Tue, 14 April 2009 01:44
How can i do that?
Hello Minki,
The only way to do that is manually. There is a ULP that will report the
total trace length for every signal on your board. You have to be careful
because it just adds the length of every copper trace and if you have some
overlap it won't be correct.
Nothing automatic about this, you have to do it manually. But it can be
done without too much effort once you get used to the process.
Cheers,
James.
fax: 888.701.8097
